电子发烧友论坛|
我买了一台二手HP 85054B校准套件,S / N 3101A09342。
我附上了几张与我的查询相关的图片,以及手册中相关页面的副本。 我有点担心如何使用滑动负载,因为手册中有一些奇怪的东西,它可能适用于我的套件,也可能不适用于我的套件,因为滑动负载的部件号不同于 手册中的那些。 根据手册,*假设*覆盖前缀为3101或更高的序列号,滑动负载为* 85054-60035(公滑动负载)* 85054-60036(母滑动负载)但是,部件号在 我的套件不同,尽管序列号前缀是3101.这不是因为有人替换了负载,因为它们与盒子底部列出的部件号相同(见图片)。 我的零件号是:* 85054-80009(公)* 85054-80010(母)这些负载和安捷伦手册中提到的负载之间是否有任何差异? 目前的850504B说明书将滑动环移动到以下位置*位置1 *位置2 * 0.2“*超出*位置3 *位置4 *位置5 *位置6我很困惑为何HP / Agilent / Maury Microwave / Keysight (其他人???)没有将第3位置进一步推进。 但更重要的是,我想知道这个0.2“的东西是否适用于我的负载,因为它们与安捷伦手册中的部件号不同,尽管手册应该适用于我的套件的序列号。有没有人有 一本涵盖滑动负载的手册85054-80009(男)和85054-80010(女)?DaveEdited:drkirkby于2014年1月11日上午10:31 kit-contents.jpg207.7 KBkit.jpg438.7 KB 以上来自于谷歌翻译 以下为原文 I've bought a used HP 85054B cal kit, S/N 3101A09342. I've attached a couple of pictures which are relevant to my query, along with a copy of the relevant page from the manual. I'm a bit concerned about exactly how to use the sliding loads, as there is something a bit odd in the manual, and it may or may not apply to my kit, as the part numbers of the sliding loads are not the same as those in the manual. According to the manual, which is *supposed* to cover serial numbers with a prefix of 3101 or later, the sliding loads are * 85054-60035 (male sliding load) * 85054-60036 (female sliding load) However, the part numbers in my kit are different, despite the serial number prefix is 3101. It is not because someone has substituted the loads, because they are the same part numbers as listed on the bottom of the box (see picture). The part numbers I have are: * 85054-80009 (male) * 85054-80010 (female) Are there any differences between these loads, and the loads mentioned in the Agilent manual? The current 850504B manual says to move the sliding ring to the following positions * position 1 * position 2 * 0.2" *beyond* position 3 * position 4 * position 5 * position 6 I'm puzzled why HP/Agilent/Maury Microwave/Keysight (anyone else???) did not put the 3rd position 0.2" further along. But more importantly I'm wondering if this 0.2" thing applies to my loads or not, since they are of a different part number to that in the Agilent manual, despite the manual should apply to the serial number of my kit. Does anyone have a manual which covers the sliding loads 85054-80009 (male) & 85054-80010 (female)? Dave Edited by: drkirkby on Jan 11, 2014 10:31 AM 附件
2个回答
你好Dave,-80009/10数字是-60035/36滑动负载的替换部件。
它们是相同的部分。 第二和第三环之间的奇怪滑动位置旨在提供更坚固的圆配合位置。 所有环之间的间距不应相等或倍数。 如果使用最小数量的幻灯片,原始设计会产生该错误,并且可能在某些频率下引起问题。 肯 以上来自于谷歌翻译 以下为原文 Hello Dave, The -80009/10 numbers are replacement parts for the -60035/36 sliding loads. They are the same parts. The odd sliding position, between the 2nd and third ring is intended to provide a more robust circle fitting position. The spacing between all the rings should not be equal or multiples. The original design made that error and can cause problems at certain frequencies if the minimum number of slides are used. Ken |
60user22 发表于 2019-2-14 10:53 > {quote:title = kenwong写道:} {quote}> Hello Dave,>> -80009/10数字是-60035/36滑动负载的替换部件。 它们是相同的部分。 谢谢。 >第二和第三环之间的奇怪滑动位置旨在提供更稳健的圆形配合位置。 所有环之间的间距不应相等或倍数。 如果使用最小数量的幻灯片,原始设计会产生该错误,并且可能在某些频率下引起问题。 好的,这是有道理的。 戴夫 以上来自于谷歌翻译 以下为原文 > {quote:title=kenwong wrote:}{quote} > Hello Dave, > > The -80009/10 numbers are replacement parts for the -60035/36 sliding loads. They are the same parts. Thank you. > The odd sliding position, between the 2nd and third ring is intended to provide a more robust circle fitting position. The spacing between all the rings should not be equal or multiples. The original design made that error and can cause problems at certain frequencies if the minimum number of slides are used. OK, that makes sense. Dave |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 01:50 , Processed in 0.521818 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2403
