电子发烧友论坛|
我在N9912A上遇到QuickCal问题。
当我拿到仪器时固件是5.x,我相信在这一点上VNA至少在某种程度上起作用。 在我将固件升级到最新版本(A.07.32 build 2014-03-1.16:32)之前,我并没有使用它,但是自升级以来,事情似乎已经变得很糟糕。 我为照片的质量道歉 - 光线在这里快速消失。 1)选择QuickCal时,我可以选择测量负载或跳过负载(参见第一张照片)。 这是我的预期。 2)如果我跳过负载(第二张照片),仪器将报告“执行校准... 100%”,然后一行中最右边的6个键显示“完成”。 按下似乎导致校准,但我不相信它运作良好 - 但这是另一回事。 我在这篇文章中报告的问题是下一点。 3)如果不是在QuickCal期间跳过负载,而是测量它,仪器需要更长的时间来测量开路和负载。 在测量负载结束时,它显示“执行校准... 100%”但是任何按钮都没有文本。 当我跳过负载时,有*不*工作“完成”。 从本质上讲,如果测量负载,我认为QuickCal根本不工作。 执行QuickCal并测量负载后,唯一似乎响应的按钮是ESC键。 如果我然后按ESC,然后按CAL,我可以看到错误纠正已关闭。 我不相信QuickCal已经完成。 这是固件错误,硬件错误,还是我的脑细胞无法正常工作? Dave编辑:drkirkby于2014年4月20日9:47 PM编辑:drkirkby于2014年4月20日下午10:05 QuickCal-completed-if-load-is-skipped.jpg590.5 KBQuickCal-seem-to-hang-if -load-is-measured.jpg768.0 KB 以上来自于谷歌翻译 以下为原文 I have a problem with QuickCal on the N9912A. When I got the instrument the firmware was at 5.x, and I believe at that point the VNA in this was working at least to some extent. I did not use it much before I upgraded the firmware to the latest (A.07.32 build 2014-03-1.16:32), but since upgrading, things seem to have gone pear shaped. I apologize for the quality of the photos - light was fading fast here. 1) When selecting QuickCal, I get the choice to measure the load or skip the load (see first photo). This is what I expected. 2) If I skip the load (second photo), the instrument reports "Performing calibration... 100%" and then the right-most of the 6 keys in a line shows "Finish" above it. Pressing that appears to result in a calibration, though I am not convinced it has worked well - but that is another matter. The problem I am reporting in this post is in the next point. 3) If instead of skipping the load during QuickCal, I measure it, the instrument takes a bit longer as it measure both the open and load. At the end of measuring the load it says "Performing calibration... 100%" But there is no text by any of the buttons. There is *not* the work "Finish" as there was when I skipped the load. Essentially, I don't think the QuickCal is working at all if the load is measured. The only button that seems responsive after doing a QuickCal and measuring the load is the ESC key. If I then press ESC, followed by CAL, I can see the error correction is off. I do not believe the QuickCal has completed. Is this a firmware bug, hardware bug, or my brain cells not working properly? Dave Edited by: drkirkby on Apr 20, 2014 9:47 PM Edited by: drkirkby on Apr 20, 2014 10:05 PM 附件 |
1个回答
您应该看到我使用固件A.07.29完成了它的最终选择,并且出现了最新的固件和选择,然后我可以看到校正ON。
尝试再次重新加载固件。 以上来自于谷歌翻译 以下为原文 You should see the finish choice I did it in mine with the firmware A.07.29 and the latest firmware and the choice finished appears, then I can see correction ON. Try reloading the firmware again. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 02:20 , Processed in 0.694960 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1538
