你好:
我是一个购买的帐户,所以我的许可证应该允许访问所有内容。 但是当我使用System Generator for DSP时,系统说我的SysGen签出许可证失败了。 有人知道怎么解决吗? 谢谢 ! -------------------------------------------------- -------------------------------------------------- ---------------------- 错误:System Generator for DSP(SysGen)的许可证签出失败。 无法联系Xilinx许可证管理器。 请检查以下内容:(1)XILINX环境变量指向有效的ISE安装(2)$ XILINX / lib / lin64在LD_LIBRARY_PATH环境变量上报告:未指定 -------------------------------------------------- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi: I'm a purchased account, so my license should allow access everything. But when I was using the System Generator for DSP, the system said my license for SysGen checked out failed. Can somebody know how to solve it ? Thanks ! -------------------------------------------------------------------------------------------------------------------------- ERROR: A license checkout has failed for System Generator for DSP (SysGen). Failed to contact the Xilinx license manager. Please check the following: (1) The XILINX environment variable points to a valid ISE installation (2) $XILINX/lib/lin64 is on the LD_LIBRARY_PATH environment variable Reported by: Unspecified -------------------------------------------------------------------------------------------------------------------------- |
1个回答
目前尚不清楚“购买的帐户”的含义。
如果您的公司购买了System Generator的许可证,您应该已经收到了该软件的许可证,它应该在许可证文件中。 您是否使用Xilinx许可证配置管理器验证您的许可证信息是否正确? ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 It isn't clear what you mean by a "purchased account". If your company has purchased licenses for System Generator you should have received a license for the software and it should be in the license file. Have you used the Xilinx License Configuration Manager to verify that your license information is correct? ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
只有小组成员才能发言,加入小组>>
2220 浏览 7 评论
2642 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2124 浏览 9 评论
3197 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2248 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
494浏览 1评论
1573浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2218浏览 0评论
544浏览 0评论
1710浏览 0评论
GMT+8, 2024-6-30 23:07 , Processed in 1.124740 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
