扫一扫,分享给好友
嗨,
我正在尝试为vcu108开发板合成示例projectvcu108_ipi。 我在Ubuntu 16.04上使用Vivado 2016.2。 大约10分钟的合成后,我收到以下错误: 信息:[Synth 8-638]合成模块'system_v_tpg_0_0'[/home/tlupick/projects/vcu108_ipi/vcu108_ipi.srcs/sources_1/bd/system/ip/system_v_tpg_0_0/synth/system_v_tpg_0_0.v:57] 致命错误。 功能'v_tpg'的安全IP的许可证检查失败。 退出Synthesis.License检查诊断:,------------------------------------------ ---------------------------------------已完成的RTL详细说明:时间:cpu = 00:08:11; 逝去了= 00:08:12。 记忆(MB):峰值= 2430.809; 增益= 1538.824; free physical = 25702; free virtual = 60654 Vivado许可证管理器会显示所有节点锁定的许可证。 有任何想法吗? 谢谢, TL 以上来自于谷歌翻译 以下为原文 Hi, I am trying to synthesize the example project vcu108_ipi for the vcu108 development board. I am using Vivado 2016.2 on Ubuntu 16.04. After about 10 minutes of synthesis I get the following error: INFO: [Synth 8-638] synthesizing module 'system_v_tpg_0_0' [/home/tlupick/projects/vcu108_ipi/vcu108_ipi.srcs/sources_1/bd/system/ip/system_v_tpg_0_0/synth/system_v_tpg_0_0.v:57] Fatal Error. License Check failed for secure IP for feature 'v_tpg'. Exiting Synthesis. License Check diagnostics : , --------------------------------------------------------------------------------- Finished RTL Elaboration : Time (s): cpu = 00:08:11 ; elapsed = 00:08:12 . Memory (MB): peak = 2430.809 ; gain = 1538.824 ; free physical = 25702 ; free virtual = 60654 The Vivado License Manager shows all of the nodelocked licenses as okay. Any ideas? Thanks, TL |
7个回答
嗨@ tlupick,
这是Vivado Design Suite提供的免费许可证,但您需要先签署核心许可协议。 单击本页右侧的核心许可协议以获取许可: http://www.xilinx.com/products/intellectual-property/tpg.html 或联系您的FAE获取免费许可证:http://www.xilinx.com/about/contact/authorized-distributors.html 然后加载此许可证并使用它。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @tlupick, This is a free license provided with Vivado Design Suite, but you need to sign the core license agreement first. Click on Core License Agreement on the right side of this page to get the license: http://www.xilinx.com/products/intellectual-property/tpg.html Or contact your FAE for the free license: http://www.xilinx.com/about/contact/authorized-distributors.html Then load this license and use it. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).View solution in original post |
嗨@ tlupick,
你能分享下面命令的输出 - report_environment -file /xinfo.txt 还要共享您正在使用的许可证文件。 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @tlupick, Can you share the output of below command - report_environment -file Also share the license file which you are using. Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
Vivado似乎无法获得v_tpg系统的许可证。
许可证只是vcu108板卡套件的标准证书许可证。 以下是check_ip输出的一部分: + ----------------------------------- + ------------- --------- + --------------------- + ----------- ------ + -------------- + --------- + --------------- + --------- --- + ---------------------- + | system_v_axi4s_vid_out_0_0 | 最新的| 无需更改| *(72)| AXI4-Stream到| 4.0 | 4.0(Rev。3)| 包括| xcvu095-ffva2104-2-e | | | | | | 视频输出| (Rev. | | | | | | | | | | 3)| | | | + ----------------------------------- + ------------- --------- + --------------------- + ----------- ------ + -------------- + --------- + --------------- + --------- --- + ---------------------- + | system_v_tc_0_0 | 最新的| 无需更改| *(73)| 视频时间| 6.1 | 6.1(Rev。8)| 包括| xcvu095-ffva2104-2-e | | | | | | 控制器| (Rev. | | | | | | | | | | 8)| | | | + ----------------------------------- + ------------- --------- + --------------------- + ----------- ------ + -------------- + --------- + --------------- + --------- --- + ---------------------- + | system_v_tpg_0_0 | 未找到IP许可证| 检查IP许可证| *(74)| 视频测试模式| 7.0 | 7.0(Rev。3)| 需要| xcvu095-ffva2104-2-e | | | | | | 发电机| (Rev. | |购买| | | | | | | | 3)| | | | + ----------------------------------- + ------------- --------- + --------------------- + ----------- ------ + -------------- + --------- + --------------- + --------- --- + ---------------------- + 以上来自于谷歌翻译 以下为原文 Vivado doesn't seem to be able to get a license for the v_tpg system. The license is just the standard certificate license from the vcu108 board kit. Here is part of the check_ip output: +-----------------------------------+----------------------+---------------------+-----------+--------------------+---------+---------------+------------+----------------------+| system_v_axi4s_vid_out_0_0 | Up-to-date | No changes required | *(72) | AXI4-Stream to | 4.0 | 4.0 (Rev. 3) | Included | xcvu095-ffva2104-2-e || | | | | Video Out | (Rev. | | | || | | | | | 3) | | | |+-----------------------------------+----------------------+---------------------+-----------+--------------------+---------+---------------+------------+----------------------+| system_v_tc_0_0 | Up-to-date | No changes required | *(73) | Video Timing | 6.1 | 6.1 (Rev. 8) | Included | xcvu095-ffva2104-2-e || | | | | Controller | (Rev. | | | || | | | | | 8) | | | |+-----------------------------------+----------------------+---------------------+-----------+--------------------+---------+---------------+------------+----------------------+| system_v_tpg_0_0 | IP license not found | Check IP license | *(74) | Video Test Pattern | 7.0 | 7.0 (Rev. 3) | Needs | xcvu095-ffva2104-2-e || | | | | Generator | (Rev. | | Purchase | || | | | | | 3) | | | |+-----------------------------------+----------------------+---------------------+-----------+--------------------+---------+---------------+------------+----------------------+ |
以下是许可证字符串:
增益Xilinx_XCVU095_DesEd xilinxd 2017.06永久不计数 包装Xilinx_XCVU095_DesEd xilinxd 2017.06 E61C90A5XXXX COMPONENTS =“SDK模拟实施分析器综合 xcvu095”OPTIONS = SUITE 以上来自于谷歌翻译 以下为原文 Here are the license strings: INCREMENT Xilinx_XCVU095_DesEd xilinxd 2017.06 permanent uncounted PACKAGE Xilinx_XCVU095_DesEd xilinxd 2017.06 E61C90A5XXXX COMPONENTS="SDK Simulation Implementation Analyzer Synthesis xcvu095" OPTIONS=SUITE |
和xinfo许可证文件。
xinfo.txt 37 KB 以上来自于谷歌翻译 以下为原文 And the xinfo license file. xinfo.txt 37 KB |
嗨@ tlupick,
这是Vivado Design Suite提供的免费许可证,但您需要先签署核心许可协议。 单击本页右侧的核心许可协议以获取许可: http://www.xilinx.com/products/intellectual-property/tpg.html 或联系您的FAE获取免费许可证:http://www.xilinx.com/about/contact/authorized-distributors.html 然后加载此许可证并使用它。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @tlupick, This is a free license provided with Vivado Design Suite, but you need to sign the core license agreement first. Click on Core License Agreement on the right side of this page to get the license: http://www.xilinx.com/products/intellectual-property/tpg.html Or contact your FAE for the free license: http://www.xilinx.com/about/contact/authorized-distributors.html Then load this license and use it. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
谢谢Nupur!
这解决了许可问题。 / TL 以上来自于谷歌翻译 以下为原文 Thanks Nupur! That fixed the licensing issue. /TL |
只有小组成员才能发言,加入小组>>
2322 浏览 7 评论
2734 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2369 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
656浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
463浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
223浏览 1评论
669浏览 0评论
1864浏览 0评论
GMT+8, 2024-10-1 11:33 , Processed in 1.393693 second(s), Total 90, Slave 74 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
