电子发烧友论坛|
你好!
我试图通过系统生成器生成FFT的组件。 我浏览了.mdl文件中的Stystem Generator块,但是当我尝试生成时,我收到以下错误消息。 我不明白为什么它无法连接到许可证管理器。 我已经通过浏览器中的导航尝试了%XILINX%变量,它是正确的。 输入%XILINX% lib nt64时,至少我会找到正确的路径。 我也有许可证,可以毫无问题地启动ISE模拟和综合。 有人可以向我解释有什么问题吗? ---------------------------------版本日志--------------- ------------------- Version PathSystem Generator 12.3 H:/Xilinx/12.3/ISE_DS/ISE/sysgenmatlab 7.12.0.635(R2011a)C:/ Program Files / MATLAB / R2011aISE H:/Xilinx/12.3/ISE_DS/ISE ---------------------------------------- ----------------------------------------错误摘要:错误0001:错误:A System Generator的许可证签出失败...阻止:未指定------------------------------------- -------------------------------------------错误0001:报告人:UnspecifiedDetails :错误:System Generator for DSP(SysGen)的许可证签出失败。无法联系Xilinx许可证管理器。 请检查以下内容:(1)XILINX环境变量指向有效的ISE安装(2)%XILINX% lib nt64在PATH环境变量上---------------- -------------------------------------------------- -------------- 以上来自于谷歌翻译 以下为原文 Hello! I am trying to generate the component of an FFT through system generator. I went through the Stystem Generator block in the .mdl-file but when I try go generate I get the following error message. I do not understand why it cannot connect to the license manager. I have tryed out the %XILINX% variable by navigation in the explorer with it, and it is correct. At least I will come to the correct path when typing %XILINX%libnt64. I also have the license and can start ISE with simulation and synthesis without any problem. Could someone please explain to me what is wrong? --------------------------------- Version Log ----------------------------------Version PathSystem Generator 12.3 H:/Xilinx/12.3/ISE_DS/ISE/sysgenMatlab 7.12.0.635 (R2011a) C:/Program Files/MATLAB/R2011aISE H:/Xilinx/12.3/ISE_DS/ISE--------------------------------------------------------------------------------Summary of Errors:Error 0001: ERROR: A license checkout has failed for System Generator... Block: Unspecified-------------------------------------------------------------------------------- Error 0001: Reported by: Unspecified Details:ERROR: A license checkout has failed for System Generator for DSP (SysGen). Failed to contact the Xilinx license manager. Please check the following: (1) The XILINX environment variable points to a valid ISE installation (2) %XILINX%libnt64 is on the PATH environment variable -------------------------------------------------------------------------------- |
4个回答
你有什么版本的许可证?
Xilinx许可证配置管理器(XLCM)窗口是否显示您的DSP许可证? 以上来自于谷歌翻译 以下为原文 What edition of License do you have? Does Xilinx License Configuration Manager (XLCM) window show your DSP license? |
有什么问题吗?
XLCM显示有效的sysgen许可证。 以上来自于谷歌翻译 以下为原文 Any fixes on this? XLCM shows a valid sysgen license. |
您使用的是哪个版本的SysGen?
你能附上一张显示SysGen许可证的XLCM快照吗? ying-wah.wu写道: 有什么问题吗? XLCM显示有效的sysgen许可证。 干杯,吉姆 以上来自于谷歌翻译 以下为原文 Which version of SysGen are you using? Can you attach a snapshot of XLCM showing the SysGen license? ying-wah.wu wrote: Cheers, Jim |
ying-wah.wu写道:
有什么问题吗? XLCM显示有效的sysgen许可证。 如果您有一个有效的sysgen许可证并且该功能显示在XLCM中(确保hostID匹配),则可能是因为启动了Matlab独立版本。 要解决此问题,请运行System Generator(开始 - >所有程序 - >“Xilinx ISE设计套件” - >系统生成器 - >系统生成器)以打开Matlab。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 ying-wah.wu wrote: ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3115 浏览 7 评论
3405 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2870 浏览 9 评论
3961 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3055 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1324浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1166浏览 1评论
/9
GMT+8, 2025-12-1 16:23 , Processed in 0.659743 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1207
