我们最近遇到了Xilinx许可证的问题。
从Linux与Windows检查时,我看到了不同的许可证状态。 我不知道它是怎么发生的,但我想知道许可证服务器是否有不同的视图或许可证状态缓存,具体取决于它检查的机器类型或检查的机器类型。 此时,Linux上的lmstat表明Vivado_System_Edition和SDK的所有许可证都在使用中,但是从WinPC中它表示没有签出许可证。 现在,我无法使用Linux中的工具,因为它报告“找不到有效的功能许可”综合“......” 有没有其他人经历过这个? 谢谢 以上来自于谷歌翻译 以下为原文 We have been having trouble with the Xilinx licenses lately. I see different license status when checking from Linux vs. Windows. I don’t know how it can happen, but I wonder if somehow the license server has a different view or cache of license status depending on what type of machine it is checking from or what type of machine it was check out from. At this moment, lmstat on Linux is indicating that all licenses of Vivado_System_Edition and SDK are in use, but from WinPC it says no license are checked out. Right now, I can not use the tools from Linux since it is reporting “A valid license was not found for feature “Synthesis”…" Anybody else experiencing this? Thanks |
1个回答
嗨,你能在两台机器上分享lmutil lmstat的输出吗?谢谢,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Can you share the output of lmutil lmstat on both machines? Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
只有小组成员才能发言,加入小组>>
3119 浏览 7 评论
3408 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2875 浏览 9 评论
3967 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3058 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1326浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1168浏览 1评论
/9
GMT+8, 2025-12-3 06:51 , Processed in 0.641179 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3201
