电子发烧友论坛扫一扫,分享给好友
你好,
我刚收到41和42包,一直在看精彩的课。现在我想上传第4课的LED闪光灯,但我得到这个错误信息“端口获取失败”。我已经试过堵漏了。这无济于事。在驱动程序安装期间没有错误消息,设备管理器没有报告任何问题。Windows 7的HP。 要做什么? 以上来自于百度翻译 以下为原文 Hi, I've just received 41 and 42 kits and been watching the nice lessons. Now I wanted to upload the LED blinky from lesson 4 but I get this error message "Port Acquire failed". I've tried plugging out and in back again. This did not help. There were no error messages during driver install and there are no issues reported by the device manager. Windows 7 HP that is. What to do ? |
49个回答
也许这会有帮助
3.3编程CY8CKIT-0494XXX套件 CY8CKIT-0494XXX工具包是用包含Bootloader的固件预先编程的。因此,有两种对车载PSoC 4设备进行编程的方法: 1。使用USB串行设备作为UB-UART桥接器执行PSoC 4设备的UART引导加载程序。 2。使用CY8CITK-02MIXPROP3直接对目标设备进行编程调试。注意,只要套件上的PSoC 4设备包含引导加载程序,就可以使用任一种程序明方法。如果没有引导程序的项目被编程到PSoC 4上,那么只能使用第二种方法,直到PSoC 4设备用引导加载程序重新编程为止。换句话说,任何项目都可以使用MixPro3程序员进行编程,但只有一个可引导加载的项目可以使用第一种方法进行引导。 以上来自于百度翻译 以下为原文 Maybe this will help - 3.3 Programming the CY8CKIT-049-4xxx Kit The CY8CKIT-049-4xxx kits are pre-programmed with firmware containing a bootloader. Therefore, there are two methods of programming the onboard PSoC 4 device: 1. Perform UART bootload programming of the PSoC 4 device using the USB-Serial device as a USB-UART bridge. 2. Use a CY8CKIT-002MiniProg3 to program and debug the target device directly. Note that as long as the PSoC 4 device on the kit contains the bootloader, either method of program ming can be used. If a project without a bootloader is programmed onto the PSoC 4, then only the second method may be used until the PSoC 4 device is reprogrammed with a bootloader. In other words, any project can be programmed using the MiniProg3 programmer, but only a bootloadable project can be bootloaded using the first method. |
啊,在看录像之前应该已经看过PDF了。
所以,如果我忘记使用boatloadable -我需要JTAG适配器。 只有一个问题:验证不起作用是正确的吗? 06:51:34 PM -选择设备:USB串行口(COM21) 06:51:37 PM -编程开始 06:51:38 PM -编程成功完成 编程完成于1673MS。 06:51:46PM -验证开始 06:51:55 PM通信端口报告错误“无法从设备中读取数据的目标。 验证完成9606MS。 谢谢, 斯蒂芬 以上来自于百度翻译 以下为原文 Ah, should have read the pdf before watching the videos. So, if I ever forget to use a boatloadable - I need this jtag adapter. Just one question: Is it right that Verify does not work ? 06:51:34 PM - Selected device: USB Serial Port (COM21) 06:51:37 PM - Programming Started 06:51:38 PM - Programming Finished Successfully Programming completed in 1673ms. 06:51:46 PM - Verify Started 06:51:55 PM - Communication port reported error 'Unable to read data from the target device'. Verify completed in 9606ms. Thanks, Stephan |
我也面临着类似的情况。
我不能第一次使用Bootloader编程049(41xx)板。遵循所有的步骤,但我得到了一个错误 通信端口报告错误“无法从目标设备读取数据”。 编程完成564MS。 我犯了一些错误,我使用Windows XP COM端口数据速率115200,停止位1,奇偶校验无。我已经遵循了指南中给出的所有步骤,我更新了PSoC程序员和创作者,还有人能帮忙吗? 以上来自于百度翻译 以下为原文 I am facing a similar situation. I cannot program the 049 (41xx) board the first time using bootloader. Followed all the steps but i get an error Communication port reported error 'Unable to read data from the target device'. Programming completed in 5644ms. Am i making some mistake I am using windows xp com port data rate 115200, stop bit 1, parity none. I have followed all the steps given in the guide I have update psoc programmer and creator as well Can someone help? |
尝试使用PSoC程序员,并重新编程固件
在板中(释放引导装载程序)。 问候,Dana。 以上来自于百度翻译 以下为原文 Try using PSOC programmer, and reprogram the firmware in the board (which releoads the bootloader). Regards, Dana. |
我得到了10倍。
刚刚打开一个包,尝试了一个新的板,有同样的问题!!!! ???? 以上来自于百度翻译 以下为原文 i got 10x of those. just opened anoth package and tried with a fresh new board, having same issue !!! ??? |
文件案例和支持可以做远程桌面会话
与你。 在柏树创建一个技术案例 CyPress网站 “支持” “技术支持” “创造一个案例” 你必须先在赛普拉斯网站上注册。 问候,Dana。 以上来自于百度翻译 以下为原文 File a CASE and support can do a remote desktop session with you. To create a technical case at Cypress - www.cypress.com “Support” “Technical Support” “Create a Case” You have to be registered on Cypress web site first. Regards, Dana. |
董事会是列举好吗?
你是以下用户引导程序?注释工具包已加载 一个BL和项目运来的时候。 HTTP://www. CyPress?COM/?RID=92146 问候,Dana。 以上来自于百度翻译 以下为原文 The board is enumerating properly ? You are following the user guide to program ? Note kit is loaded with a BL and project when shipped. http://www.cypress.com/?rID=92146 Regards, Dana. |
不错过按钮步骤-
9。连接到PC。cy8ckit-049-4xxx原型板连接盒到港,因为它是插在降低sw1button。 你会注意到,LED开始快速闪烁;这表明PSoC 4在bootloader模式”,准备装latestfirmware。这必须在每次启动PSoC 4加载时完成。 10。选择工具& gt;Bootloader Hostto打开启动主机的工具。 问候,Dana。 以上来自于百度翻译 以下为原文 Not missing the push button step - 9. Connect the CY8CKIT-049-4xxx prototyping board tothe PC. When connecting the kit to the port, depress the SW1button as it is plugged in. You will notice that the LED begins to blink rapidly; this indicates that the PSoC 4 is in 'Bootloader Mode' and is ready to be loaded with the latestfirmware. This must be done each time you boot load the PSoC 4. 10.Select Tools > Bootloader Hostto open the Bootloader Host tool. Regards, Dana. |
对不起,这些CY8CKIT非常糟糕!
在2台电脑上试用过,但是: -设备不会自动识别。 在手动驱动驱动程序之后,该设备在“新娘控制器面板”工具中显示为COM6。 -但是我不能从“创造者”中编程它。 -程序员还告诉我没有端口可用,42xx线不可用。 现在,在一些安装和重新安装之后,当我把设备放到USB端口(现在在PC上)时,PC就挂断了。 第二台电脑崩溃了,所以需要一个系统修复。 第一台PC是Windows 7 64位,后面的电脑是Windows 7 32bit。 永远不要让它运行。真遗憾! 当做 托马斯 以上来自于百度翻译 以下为原文 Sorry but these CY8CKITs are very bad! Have tried it on 2 PCs but: - the Device will not recognised automatically - After manually intallation of the drivers, the device is showed up as COM6 in the "Bride-Controller-Panel" Tool - But I cant programm it from the "Creator" --> Port aquire failed - Also the Programmer tells me that no Port is available and the 42xx Line is not available - Now after some deinstalls and reinstalls, the PC hangs up when I put the device into the u*** port (now on both PC's). - the second PC is crashes so bad that a system repaire was needed. First PC ist Windows 7 64Bit, seconde PC is a Windows 7 32Bit. Never get it running. What a shame! regards Thomas |
当你得到一个“港口收购失败”的消息,你正在做的事情是错误的,这发生在你计划的先驱或kit-30或kit-50和一些失败。
我成功的程序(一)我的kit-049ers通过选择“工具”项下的“引导主机”。KIT-049作为一个COM端口显示,没有别的。 我的Windows配置和你相似,Vista、Win7、64和根本没有问题。 作为一个事实:柏把1500套在德国市场3天内,只有极少数的人有问题,让他们在一次。他们中的大多数人忘了按开关,插入工具插入USB 鲍勃 以上来自于百度翻译 以下为原文 When you get a "Port acquire fail" message you are doing something wrong, this happens when you program a Pioneer or a Kit-30 or Kit-50 and something fails. I successfully programed (any of ) my Kit-049ers by choosing under "Tools" the item "Bootloader Host". The Kit-049 shows as a COM port, nothing else. My windows configurations are similar to yours, a Vista and a Win7/64 and no issues at all. As a matter of fact: Cypress gave away 1500 Kits on a faire in Germany within 3 days and only a very few people have trouble to get them working at once. Most of them forgot to press the switch while inserting the kit into the USB Bob |
您好!
问题是该设备不受Windows(在两台PC上!)的影响。. 也许是因为我使用德语版的Windows? 在一台电脑上,我把一个工具包放进USB端口,什么也没发生。然后我把另一个工具包放入另一个USB端口,然后显示第一个工具包。第二个不是。对不起,USB枚举器一定有问题。有没有办法清除所有柏树车手,重新开始?如果我卸载软件,整个系统都塞满了柏树车手。 什么可能的情况下,Windows无法识别的USB设备呢? 最好的问候 托马斯 以上来自于百度翻译 以下为原文 Hi The problem is that the Device IS NOT recognised by Windows (on both PC's!). Maybe its because I use a german version of Windows? On one PC i put one kit into a u***-port and nothing happens. Then i put a second kit into another u***-port and then the FIRST kit will be shown. the second NOT. Sorry but something must be wrong with the USB Enumerator. Is there a Way to clean deinstall all Cypress drivers and start over? If I deinstall the Software the whole system ist full of Cypress drivers. And what could be the case, that Windows does not recognize the u***-device himself? best regards Thomas |
如前所述,考虑提交一个案例和做一个远程桌面
会话。 在另一个叉中,如果使用Windows 7下载Windows WDK,或者更早的DeVCON.EXE, 然后看看USB端口。稍微长一点,也许是你的芯片组驱动程序 你的电脑需要更新吗? 问候,Dana。 以上来自于百度翻译 以下为原文 As posted earlier consider filing a CASE and doing a remote desktop session. On another fork if using windows 7 download Windows WDK, or earlier devcon.exe, and take a look at USB ports with that. A bit of a longshot, maybe your chipset driver needs updating in your PC ? Regards, Dana. |
这与德语版的Windows无关,我也使用了一个(位于不来梅附近,你住在哪里?)
我只是把这个工具箱插进USB端口,而它还没有进入。我打开了安装窗口,一分钟后附上的图片就是结果。 鲍勃 UB1.JPG 21.8 K 以上来自于百度翻译 以下为原文 This has nothing to do with a German version of windows, I use one, too (being located near Bremen, where do you live?) I just plugged the Kit into an USB-port where it has not been in yet. I opened the installer window and after a minute the attached picture was the result. Bob
卸载USB设备:使用NRSOFT.NET的UBDEVIEW(免费来)。
鲍勃 以上来自于百度翻译 以下为原文 De-installing USB-devices: Use USBDeview from nirsoft.net (comes for free). Bob |
在结果选项卡、WorkSplorer资源管理器、Creator中,右击项目名称和副本
路径/地址。 获取资源管理器,粘贴地址,在最后删除项目文件。反过来 在目录中搜索*.HEX。 问候,Dana。 以上来自于百度翻译 以下为原文 In the results tab, Workspace Explorer, Creator, right click project name and copy the path/address. Win explorer, paste address, removing project file at very end. In turn do a search on that directory for *.hex. Regards, Dana. |
仍然阻止我的全部信息作为垃圾邮件,所以在碎片…
新的PSoC,但不是新的MCU。下载和运行CY8CK00442XXSUPUPUVRESSS.EXE 硬件驱动全部安装,但我得到端口AQUIR失败。 以上来自于百度翻译 以下为原文 Still blocks my full message as spam, so in pieces.... new to psoc but not new to MCUs. Downloaded and ran CY8CKIT04942xxSetup_revSS.exe The hardware drivers all install, but I get port aquire failed. |
谢谢你,鲍伯
USBDeview很乐于助人。 我已经拆除了所有柏树设备。 之后,我又插上了工具箱。但是,设备也没有被很好地识别。只有EN错误消息出现“没有找到在线驱动程序…”。所以我已经手动重新安装了所有的驱动程序。首先是“USB串行适配器”。同时,还安装了“USB总线枚举器”。然后手动“USB串行口”,并将其配置到COM2。 现在它起作用了! 但是抱歉,必须与USB设备的检测错误。我从未有过的问题在一些其他USB设备。看来,我的情况很少见,只有我有这个问题!? 我试图同时在第三电脑-是的-它也不会自动应用在所有三个!也许司机应该得到微软的认证; 再次感谢并致以最良好的问候 托马斯 以上来自于百度翻译 以下为原文 Thank you Bob USBDeview was helpfull. I have deinstalled all Cypress Devices. After it I pluged in the kit again. But again the device was NOT recogniced well. Just en error message appears "No drivers found online...". So I have installed all drivers again manually. First the "USB-Serial Adapter". With this, also the "USB Bus Enumerator " was installed. Then manually the "USB Serial Port" and configured it to COM2 again. Now it works! But sorry, something must be wrong with the USB device detection. I have never had problems before with some other USB-Devices. Seems that my conditions are very rarly and I am the only one with this problems!? I have tried it in the meantime on a third PC - and yes - it is also NOT automatically recogniced on all three PCs! Maybe the drivers should be certificated by Microsoft ;-) Thanks again and best regards Thomas |
作记号,
找不到文件的原因是没有必要的CyACD。 设置BooLoad组件、依赖项的属性,并且您需要一个.ELF和.HEX文件。转到Bootloader项目, 皮质M0ARMGCC调试和它们在那里。 10以上的COM端口没有问题。 鲍勃 以上来自于百度翻译 以下为原文 Mark, the reason that you cannot find the file is that there is no .cyacd you need. Set properties of the bootloadable component, dependencies and you see you need an .elf and a .hex file. Go to your bootloader project, Cortex M0ARMGCCDebug and there they are--- There are no issues with com-ports above 10 afaik Bob |
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7347 浏览 0 评论
2485 浏览 1 评论
2178 浏览 1 评论
4045 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2089 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7842浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6404浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
757浏览 2评论
729浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8255浏览 2评论
/9
GMT+8, 2025-12-13 12:27 , Processed in 1.947797 second(s), Total 108, Slave 91 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1645
