扫一扫,分享给好友
你好,
我刚收到41和42包,一直在看精彩的课。现在我想上传第4课的LED闪光灯,但我得到这个错误信息“端口获取失败”。我已经试过堵漏了。这无济于事。在驱动程序安装期间没有错误消息,设备管理器没有报告任何问题。Windows 7的HP。 要做什么? 以上来自于百度翻译 以下为原文 Hi, I've just received 41 and 42 kits and been watching the nice lessons. Now I wanted to upload the LED blinky from lesson 4 but I get this error message "Port Acquire failed". I've tried plugging out and in back again. This did not help. There were no error messages during driver install and there are no issues reported by the device manager. Windows 7 HP that is. What to do ? |
49个回答
PSoC Creatir将不会看到作为CY8CKIT-04942xx的可引导加载设备。这只能是引导程序宿主的程序。
CY8CKIT-042先锋套件有一个更复杂的芯片作为程序员。这不仅允许创建者“查看”该设备,它还允许调试设置断点、检查/设置变量和检查调用堆栈。 鲍勃 以上来自于百度翻译 以下为原文 PSoC Creatir will not see a bootloadable device as the CY8CKit-049-42xx. This can only be programmes with the BootLoader Host. The CY8CKit-042 Pioneer kit has got a more complex chip as programmer. This not only allows Creator to "See" that device, it additionally allows for debugging as setting breakpoints, inspecting/setting variables and checking the call-stack. Bob |
马克,欢迎来到PSOC的迷人世界!
玩你的先锋套件,使用调试器在创建者,当你喜欢,我建议你手上一个CY8CKIT-059 该套件的一部分是一个完整的PSoC程序员,你可以用来编程和调试你的4美元板。另外,PSOC5巫师是PSOC4S的大哥哥(更好的CPU,更快,更大的UDB)。 鲍勃 以上来自于百度翻译 以下为原文 Mark, welcome in the fascinating world of PSoCs! Play around with your pioneer kit, use the debugger in Creator and when you like that, I suggest you to get hands on a CY8CKIT-059 The snap-off part of that kit is a complete PSoC programmer which you can use to program and debug your 4$ boards. Additionally you get a PSoC5 witch is the big brother of the PSoC4s (Better CPU, faster, much more UDBs). Bob |
使用MIXPROP3编程,从工具箱手册
以上来自于百度翻译 以下为原文 Using Miniprog3 to program, from kit board manual - |
嗨,鲍伯,10美元,CY8CKIT-059是一个盗窃,我会马上订购一个。MILPROG 3是90美元,所以59套是一种更具成本效益的路线。
Alan Hawse视频“PSoC Creator 101:CY8CKIT-049原型工具包开始”显示CY8CKIT-49通过PSoC Creator编程,所以我会继续检查。如果我得到那份工作,我会把我发现的东西发出去。 谢谢大家,马克 以上来自于百度翻译 以下为原文 Hi Bob, At $10, the CY8CKIT-059 is a steal and I'll order one shortly. The miniprog 3 is $90, so the 59 kit is a more cost effective route. The Alan Hawse video "PSoC Creator 101: CY8CKIT-049 Prototyping Kit Getting Started" shows the CY8CKIT-49 being programmed via PSoC Creator, so I'll keep checking into that. If I ever get that working, I'll post what I find out. Thank you everyone, Mark |
嗨,各位,
另一个NeWB在这里,但是在其他论坛成员的帮助下(感谢Dana和鲍伯),我已经完成了这一峰,并且愉快地编写了我的4美元PSoC。你面临的最大问题是,大部分介绍材料都是面向先锋板的,而且与原型工具不同。但是塞浦路斯正在为我们组装材料,知道在哪里找到它是有帮助的。查看最近发布的视频:HTTP://www. CyPress?RID=107124和Cache=0和;源= CeRealStage页面,我的PSoC creator上的首页链接到一个特定于这个板的项目(可能是因为我从页面上下载了原型工具包)。 以下是我必须学会的事情: 忽略文件-gt;示例项目中发现的示例…现在。一旦你知道自己在做什么,它们就会有用。请理解,必须使用Bootloader宿主来生成可加载的项目。程序按钮对我们没有用。这是先驱(也可能是其他程序员的)。记住,当你把板插入USB端口时,请按住按钮!(有一个项目可以在Bootloader中获得上面的视频中的另一种方式)祝你好运,享受! 以上来自于百度翻译 以下为原文 Hi folks, Another newb here, but with some help from other forum members (many thanks to Dana and Bob) I've made it over the hump and am happily programming my $4 PSoC. The biggest problem you face is that most iof the introductory material is geared toward the Pioneer board and things are different with the prototyping kit. But Cypress is putting together material for us and it is helpful to know where to find it. Check out the videos posted recently: http://www.cypress.com/?rID=107124&cache=0&source=creatorStartPage And the front page on my PSoC creator has links to a couple projects specific to this board (probably because I downloaded it from the page for the prototyping kit.) Here are the things I had to learn to get going :
我现在检查了录像。049工具包使用Bootloader主机程序进行编程,主机程序可以从创建者的工具菜单中访问,但是没有(0)调试工具。
鲍勃 以上来自于百度翻译 以下为原文 I checked the video right now. The -049 kit is programmed using the BootLoader Host program which can be accessed from the tools-menu of Creator, but there are no (0) debugging facilities. Bob |
通过三次尝试,IAM通过Bootloader主机成功编程了8CKIT-0494XXXKIT,在此期间我犯了两个致命错误,一个是我不知道我需要改变我的COM端口的波特率从9600到115200(在Bootloader主机中波特率)D是相同的),另一个是我总是按下开关后的试剂盒已连接到USB端口,而这些错误导致不好的结果:“通信端口报告错误“无法从目标设备读数据。”
最后我改变波特率为115200,按下开关盒之前就已经连接到我的计算机的USB端口,thenloosen开关, 如果你看到蓝色LED闪烁,比以前更频繁,那么恭喜你可以计划或验证或擦除工具现在 更多信息:操作系统Windows 7 32bit,工具软件:cy8ckit04942xxsetup.exe 谢谢! 以上来自于百度翻译 以下为原文 through three days trying I am successfully programmed the CY8CKIT-049-4xxx Kit through Bootloader Host。During which i have made two fatal mistakes, one is at first i don't know that i need to change the Baud rate of the COM port of my compter from 9600 to 115200 (In Bootloader Host the Baud Rate should be the same ),the other is I always press the switch after the kit has been connected to the USB Port, while these two mistake cause the bad result that :“Communication port reported error 'Unable to read data from the target device'.” Finally i change the Baud rate to 115200 and Press down the switch on the kit before it has been connected to the USB Port of my computer, then loosen the switch, If you see the Blue Led blink more frequently than before ,then congratulations you can program or verify or erase the kit now For more information: operating system windows 7 32bit, Kit software :CY8CKIT04942xxSetup.exe Thanks! |
这就是我所想的。我不能使用主机DeLoDeAudiWistor程序员。我可以构建项目,编译它,或者生成应用程序,没有错误,但是永远找不到.CyACD文件或HEX文件。我肯定我错过了什么地方。我会一直插嘴的。 以上来自于百度翻译 以下为原文 That is what I thought. I'm not able to prog using host downloadewithr programmer. I can build the project, compile it, or generate application, without errors, but never can find the .cyacd file or hex file. I'm sure I missed something somewhere. I'll keep plugging at it. |
uwjfisgw 发表于 2019-1-15 17:47 对PSoC4编程同样的问题。论坛不接受我的短信,说它引发的垃圾邮件过滤器和报告,我封锁。 以上来自于百度翻译 以下为原文 Same problem with programming the PSOC4. Forum would not accept my message, said it triggered spam filter and to report that I'm blocked. |
就像这样……婴儿步骤……看来Creator不喜欢COM端口10及以上。修正了这个问题,但是我仍然找不到引导加载程序主机想要的文件,例如CyAcd(CopyUasascd,这就是我的记忆)。在构建一个项目后,我能找到的唯一的.HEX文件是“保护.HEX”,我不确定这是否是我想用PSoC Creator Bootloader主机使用的文件。即使在先锋42工具包工作之后,我仍然没有找到引导程序主机需要的文件。谁知道我错过了什么?我在整个文件系统中搜索CyAcd和HEX文件。
是的,我知道没有使用先锋49工具包的调试。我可以开发和调试使用先锋44工具包。 是的,我知道我必须按住49板上的按钮进入程序模式…快速闪光LED。 CY8CKIT-042先锋套件已经被CY8CKIT-044取代了吗? CY8CKIT-059套件的成本会下降吗?PSoC 5,更快,低功耗,实际上更符合我所需要的。 以上来自于百度翻译 以下为原文 Well it's like this...baby steps......It appears that Creator doesn't like com ports 10 and above. Fixed that problem, but I still cannot find a file that the bootLoader Host wants e.g. .cyacd (CoverYourAssCD that's how I remember it). The only .hex file that I can find after building a project is "protect.hex" and I'm not sure if that's what I'm suppose to use with the PSoC Creator bootLoader Host. Even after getting the Pioneer 42 kit working, I still haven't found the file that I need for the bootLoader Host. Anyone have any idea what I'm missing? I search my entire file system for the .cyacd and hex files. Yes, I know that there's no debugging using the Pioneer -49 Kit. I can develop and debug using the Pioneer 44 kit. Yes, I know that I must hold down the button on the -49 board to enter into the program mode...quick flaching LED. Has the CY8CKIT-042 Pioneer kit been superseded by kit CY8CKIT-044? Is the cost of the CY8CKIT-059 kit going to come down? The PSOC 5, faster, low power, is really more along the lines of what I need. |
只有小组成员才能发言,加入小组>>
717个成员聚集在这个小组
加入小组1908 浏览 1 评论
1659 浏览 1 评论
3415 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1578 浏览 6 评论
1386 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
197浏览 2评论
190浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
332浏览 2评论
357浏览 1评论
70浏览 1评论
GMT+8, 2024-5-3 19:56 , Processed in 0.661095 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
