或者我找不到它们。我正在使用创建者4.1,并安装了CY8CKIT-04942XX套件(KIT设计文件,文档,例子),因为我已经使用了一段时间的创建者,不需要它重新安装。我期待着在某处找到ScbBooLooul.CyWrk工作空间,但一直未能找到它可能在哪里。它不出现在起始页-GT工具包中,我希望它在PSoC 4 CY8CKIT-049原型工具包页上为KIT用户指南和视频提供。
在创建者的文件和代码示例对话框中有一个引导加载程序和可引导加载程序,但是在任何地方都找不到“可引导加载的闪烁LED”示例。我开始在我的工作场所的嵌入式系统,并希望使用基于PSoC 4的工具包作为一个负担得起的和更强大的替代ARDUNO,但这是一个主要的绊脚石,因为我设计我的讲座。此套件的文档和视频与创建者4.1不匹配,无法找到示例。 请帮助! 以上来自于百度翻译 以下为原文 ...or I can't find them anyway. I am using Creator 4.1 and installed the CY8CKIT-049-42xx Kit Only (Kit Design Files, Documentation, Examples) as I have been using Creator for awhile and did not need it re-installed. I was expecting to find the SCB_Bootloader.cywrk workspace somewhere but have not been able to find where it might be. It does not appear in the Start Page -> Kits where I would expect it per the kit user's guide and video on the PSoC 4 CY8CKIT-049 Prototyping Kits page. There is a Bootloader and Bootloadable in the File->Code Examples dialog in Creator but there is no "Bootloadable Blinking LED" example anywhere to be found. I am starting a class in Embedded Systems at my workplace and would like to use the PSoC 4 based kit as an affordable and much more powerful alternative to the Arduino but this is a major stumbling block as I design my lectures. The documentation and video for this kit do not match Creator 4.1 and the examples can't be found. Please help! |
2个回答
嗨,罗伯特,
如果您正在使用Win 7系统,您能在C:程序文件(x86) CyPress CY8CKIT-04942XX 1 固件SCBBooBooLoad中找到安装文件夹中的KIT-049代码示例吗? 如果没有,建议重新尝试安装KIT-049工具包。也许CE被删除或移动到任何其他地方。 谢谢, 赖安 以上来自于百度翻译 以下为原文 Hi Robert, If you are using Win 7 system, can you find the KIT-049 code example in installed folder at C:Program Files (x86)CypressCY8CKIT-049-42xx1.0FirmwareSCB_Bootloader ? If not, recommend to have a try to re-install KIT-049 Kit Only again. Maybe the CE was removed or moved to any other place. Thanks, Ryan |
pengzhongdianzi 发表于 2018-11-8 12:47 谢谢瑞安!我使用的是Windows 10。我重新安装了CY8CKIT-04942XX套件(KIT设计文件,文档,示例)文件,它神奇地工作了这次!不确定我以前做错了什么,但是“SCBBooBooLoul.CyWrk”链接出现在KITS & Gt;CY8CITK-04942XX中,就像创建者的起始页标签一样。我跑了! 以上来自于百度翻译 以下为原文 Thanks Ryan! I am using Windows 10. I did a reinstall of the CY8CKIT-049-42xx Kit Only (Kit Design Files, Documentation, Examples) file and it magically worked this time! Not sure what I was doing wrong before but the "SCB_Bootloader.cywrk" link appeared under the Kits->CY8CKIT-049-42XX in the Creator Start Page tab like it is supposed to. I am off and running! |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-1 22:02 , Processed in 0.750267 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1540
