CY8CKIT-04942XXKIT以前工作过。最近,它没有得到MyWi7PC的认可。附加的屏幕截图显示了插入板后发生的事情。我可以使用MIXPROP3编程板,但我想使用USB串行端口。请帮忙。
没有司机 27.6 K USB串行 25.4 K 没有端口 46.3 K 设备管理器 84.1 K 以上来自于百度翻译 以下为原文 The CY8CKIT-049-42xx kit was working before. Recently, it is not getting recognized by my Win7 PC. Attached screen shots show what is happening after the board is inserted. I can program the board using MiniProg3, but I want to use USB Serial port. Please help.
9个回答
欢迎来到论坛!
NoPort.PNG:CY8CKIT-04942XX从未设计用于调试,这以前从未工作过。 我建议您删除工具包并卸载设备管理器中的COM端口。 PC重启后插入你的-049,等待几次MiTube给它一个机会从互联网上更新。 在“工具”下选择“Bootloader主机”。现在应该列出你的工具包。 鲍勃 以上来自于百度翻译 以下为原文 Welcome in the forum! NoPort.PNG: The CY8CKIT-049-42xx was never designed for debugging, that has never worked before. I would suggest you to remove the Kit and de-install com ports in the device manager, After pc reboot plug in your -049ner and wait a few miutes to give it a chance to update from internet. Start Creator and under "Tools" select the "Bootloader Host". there should now your Kit's comport be listed. Bob |
如何卸载设备管理器中的COM端口?正如您在设备管理器PNG中看到的,没有列出的COM端口。甚至“显示隐藏设备”也不显示任何COM端口。我应该试试USBDeview吗?
以上来自于百度翻译 以下为原文 How do I uninstall Com Ports in Device Manager? As you see in Device Manager.PNG, there is no com port listed. Even 'Show hidden device' does not show any com port. Should I try USBDeview? |
删除虚拟串口设备。UBDEVIEW不是一个坏主意,而是关心你的鼠标;
鲍勃 以上来自于百度翻译 以下为原文 Remove your virtual serial port device. USBDeview is not a bad idea, but care for your mouse ;-) Bob |
卸载相关的驱动程序后,我重新启动我的PC。在插入了板之后,安装了两个驱动程序(见图像)。
但在Bootloader主机中没有COM端口(见图像)。 然后我尝试安装虚拟串口设备00,但是没有找到驱动程序。 所以,没有COM端口。 萨哈 以上来自于百度翻译 以下为原文 After uninstalling related drivers, I restarted my PC. After inserting the board, two driver is installed (see image). But no com port in Bootloader Host (see image). Then I tried to install Virtual Serial Port Device 00. But no driver found. So, no COM PORT. Saha |
我没有安装虚拟COM端口驱动程序!你使用的是什么操作系统?
鲍勃 以上来自于百度翻译 以下为原文 I did not install the virtual com port driver! What OS are you using? Bob |
Windows 7。几天过去了,它还在工作。这已经发生两天了。
萨哈 以上来自于百度翻译 以下为原文 Windows 7. Few days back also it was working. This has happened two days back. Saha |
我已经把我的电脑恢复到2天了,它也移除了PSoC创建者3.3的安装。但即便如此,它还是同一个问题——“虚拟串口设备00——没有找到驱动程序”。董事会或Windows 7有问题吗?
以上来自于百度翻译 以下为原文 I have restore my PC to 2 days back, which removes PSoC Creator 3.3 installation also. But even after that it is the same issue - " Virtual Serial Port Device 00 - no driver found". Is there problem with the board or windows 7? |
我有这个问题,我通过遵循这个PDF修复它。
CyPress USB串行驱动器安装指南1.PDF 1.1兆字节 以上来自于百度翻译 以下为原文 I had this problem and I fixed it by following this PDF. |
谢谢鲍勃。安装CyPress USB驱动程序后,解决了我的问题。再次感谢。 萨哈 以上来自于百度翻译 以下为原文 Thanks bobgoar. After installing Cypress USB Driver, my problem is solved. Thanks again. Saha |
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2105 浏览 1 评论
1851 浏览 1 评论
3669 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1786 浏览 6 评论
1536 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
568浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
423浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
437浏览 2评论
383浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
915浏览 2评论
GMT+8, 2024-12-23 10:35 , Processed in 1.178006 second(s), Total 65, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
