电子发烧友论坛|
以前,我们有matlab 2006a和ISE 8.2i,并且正在使用System Generator。
我们不得不重新安装Matlab 2006a以启用新的工具箱,但现在Simulink中没有System Generator。 我已使用下载站点上提供的WebPACK_82i_SFD.exe重新安装了ISE 8.2i。 但是,系统生成器仍然不可用。我需要做什么才能将系统生成器“重新安装”到Matlab中?谢谢!--- Mike VanHornmichael.vanhorn@wright.edu --- Mike VanHorn 以上来自于谷歌翻译 以下为原文 Previously, we had Matlab 2006a and ISE 8.2i, and were using the System Generator. We had to reinstall Matlab 2006a to enable a new toolbox, but now the System Generator is not available in Simulink. I have re-installed ISE 8.2i using the WebPACK_82i_SFD.exe available on the download site. However, the System Generator still isn't available. What do I need to do to "re-install" the System Generator into Matlab? Thanks! ---Mike VanHornmichael.vanhorn@wright.edu --- Mike VanHorn |
6个回答
您只需转到已安装ISE Design Suite的目录即可。
然后运行'sg_config.exe',在这种情况下你可以选择你的matlab。 例如,D: Xilinx 10.1 DSP_Tools common bin sg_config.exe 以上来自于谷歌翻译 以下为原文 You can just go to the directory where the ISE Design Suite have been installed. Then ran the 'sg_config.exe', in this case you can select your matlab. For example, D:Xilinx10.1DSP_Toolscommonbinsg_config.exe |
我在我的系统上找不到“sg_config.exe”文件。
奇怪的是,在C: Program Files Matlab 2006a toolbox目录中,有一个Xilinx目录,但Xilinx块集在Simulink LIbrary浏览器中不可用。 那么,也许我应该问的问题是如何重新安装Xilinx模块组? 谢谢!--- Mike VanHornmichael.vanhorn@wright.edu --- Mike VanHorn 以上来自于谷歌翻译 以下为原文 I can't find a "sg_config.exe" file anywhere on my system. What's weird is that in the C:Program FilesMatlab2006atoolbox directory, there is a Xilinx directory, but the Xilinx blockset isn't available in the Simulink LIbrary Browser. So, perhaps the question I should be asking is how to re-install the Xilinx blockset? Thanks! ---Mike VanHornmichael.vanhorn@wright.edu --- Mike VanHorn |
sg_config.exe随System Generator一起安装。
它在%XILINX_IDS_INSTALL_DIR% DSP_Tools nt common bin中 干杯,吉姆 以上来自于谷歌翻译 以下为原文 sg_config.exe is installed with System Generator. It's in %XILINX_IDS_INSTALL_DIR%DSP_Toolsntcommonbin Cheers, Jim |
抱歉,系统上没有任何sg_config.exe,也没有DSP_Tools目录。
你确定这应该适合8.2i吗? 我认为旧软件的功能有类似之处,但也许它位于不同的地方? --- 迈克范霍恩 michael.vanhorn@wright.edu --- Mike VanHorn 以上来自于谷歌翻译 以下为原文 Sorry, there isn't an sg_config.exe anywhere on the system, nor is there a DSP_Tools directory. Are you sure this is supposed to be right for 8.2i? I would imagine there is something similar in functionality for the older software, but perhaps it's in a different place? --- Mike VanHorn michael.vanhorn@wright.edu --- Mike VanHorn |
麦克风,
我不是SysGen专家,所以我不能在这里详细说明所有细节。 但是,我看了一下8.2i产品周期的SysGen的构建清单,它没有包含Jim引用的实用程序。 我将与我们内部的SysGen人员核实,看看他们是否有任何想法。 托尼 -------------------------------------------这个空间故意留空 以上来自于谷歌翻译 以下为原文 Mike, I'm not a SysGen expert, so I cannot speak to all of the details here. However, I took a look at the build manifest of SysGen for the 8.2i product cycle and it did not include the utility that Jim referenced. I will check with our internal SysGen folks and see if they have any ideas. -Tony ------------------------------------------- this space intentionally left blank |
我最终不得不联系Xilinx的技术支持,然后使我们的帐户能够完全重新下载SysGen 8.2软件包。
谢谢! --- Mike VanHorn 以上来自于谷歌翻译 以下为原文 I ended up having to contact Xilinx' tech support, and then enabled our account to be able to completely re-download the SysGen 8.2 package. Thanks! --- Mike VanHorn |
只有小组成员才能发言,加入小组>>
3141 浏览 7 评论
3435 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2897 浏览 9 评论
4097 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3081 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1358浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1196浏览 1评论
/9
GMT+8, 2025-12-11 04:45 , Processed in 0.958322 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
782
