电子发烧友论坛扫一扫,分享给好友
你好,
我正在尝试在我的Windows 7机器上安装Vivado 2014.4,但不断收到以下错误按摩: 安装文件时遇到以下致命错误:C: Xilinx Vivado 2014.4 data ip xilinx mig_7series_v2_3 data dlib 7series qdriiplus_sram par ise_flow_lsf.scr(访问被拒绝)单击“重试”以获取安装程序 重试此操作。 单击“取消”以取消此安装。 我以管理员身份登录。 谢谢, 奥拉 以上来自于谷歌翻译 以下为原文 Hello, I am trying to install the Vivado 2014.4 on my Windows 7 machine, but keep getting the following error massage: The following fatal error was encountered while installing files: C:XilinxVivado2014.4dataipxilinxmig_7series_v2_3datadlib7seriesqdriiplus_sramparise_flow_lsf.scr (Access is denied) Click Retry for the installer to retry this operation. Click Cancel to cancel this installation. I am logged in as an administrator. Thanks, Ola |
9个回答
嗨,
可以请分享安装日志文件。 也可以参考安装相关的查询 http://www.xilinx.com/support/answers/60122.html 谢谢, Shreyas -------------------------------------------------- --------------------------------------------尝试搜索你的答案 在发布新主题之前,在论坛或xilinx用户指南中发布问题。 请注意 - 如果提供的信息解决了您的问题,请将答案标记为“接受为解决方案”。给予您认为有帮助且回复导向的帖子给予荣誉(左侧提供的星标).---------- -------------------------------------------------- ---------------------------------- -------------------------------------------------- --------------------------------------------尝试搜索你的答案 在发布新帖子之前在论坛或xilinx用户指南中发出问题。请注意 - 如果提供的信息解决了您的问题,请将答案标记为“接受为解决方案”。给予您认为有用的帖子给予荣誉(右边提供的星号) 并回复.---------------------------------------------- ------------------------------------------------ 以上来自于谷歌翻译 以下为原文 Hi, Can you please share installation log files. also for installation related queries please refer http://www.xilinx.com/support/answers/60122.html thanks, Shreyas ---------------------------------------------------------------------------------------------- Try to search answer for your issue in forums or xilinx user guides before you post a new thread. Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query. Give Kudos (star provided in left) to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- ---------------------------------------------------------------------------------------------- Try to search answer for your issue in forums or xilinx user guides before you post a new thread. Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query. Give Kudos (star provided in right) to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
您好,请参阅http://www.knownfile.com/en-us/file/461163/solved-problem-with-ise_flow_lsf.scr-file-easy-steps-to-download-repair-fix-remove-clean-
uninstall-edit-ise_flow_lsf.scr-file解决与ise_flow_lsf.scr相关的问题 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello, Please refer http://www.knownfile.com/en-us/file/461163/solved-problem-with-ise_flow_lsf.scr-file-easy-steps-to-download-repair-fix-remove-clean-uninstall-edit-ise_flow_lsf.scr-file to resolve the issues related to ise_flow_lsf.scrRegards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨,请参考AR http://www.xilinx.com/support/answers/60118.html以解决2014.x安装问题。谢谢,Yash
以上来自于谷歌翻译 以下为原文 Hi, Please refer AR http://www.xilinx.com/support/answers/60118.html for trouble shooting 2014.x install issue. Thanks, Yash |
嗨Shreyas,
附加的日志文件。 谢谢, 奥拉 xinstall_1417607788929.log 107 KB 以上来自于谷歌翻译 以下为原文 Hi Shreyas, The log file attached. Thanks, Ola |
你好anandara@tcd.ie
从安装日志文件,它似乎是权限问题。 尝试在其他位置安装Vivado 2014.4而不是C: Xilinx。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello anandara@tcd.ie From the install log file, it seems like permissions issue. Try installing Vivado 2014.4 in other location rather than C:Xilinx. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
你好Vinay,
尝试但仍然失败。 确保权限设置为完全控制,同时安装sw但它没有帮助。 谢谢, 奥拉 以上来自于谷歌翻译 以下为原文 Hi Vinay, Tried but it still fails. Made sure that the persmision was set to full control, while installing the sw but it didn't help. Thnaks, Ola |
嗨,尝试安装没有docnav和驱动程序安装的webpack 1st。并检查你是否面临同样的问题。谢谢,yash
以上来自于谷歌翻译 以下为原文 hi, try to install webpack 1st without docnav and driver install. and check if u face the same issue. thanks, yash |
嗨Yash,
尝试过,但仍然出现同样的错误。 谢谢, 奥拉 以上来自于谷歌翻译 以下为原文 Hi Yash, Tried, but still the same error occured. Thanks, Ola |
你好,
你是如何安装这个工具的? 使用瘦安装程序下载和安装 要么 从完整的下载包安装? 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello, How are you installing the tool? Download and Installation using thin installer OR Installing from the complete download package? Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
只有小组成员才能发言,加入小组>>
3150 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2900 浏览 9 评论
4109 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1365浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1205浏览 1评论
/9
GMT+8, 2025-12-17 21:19 , Processed in 0.669460 second(s), Total 57, Slave 50 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1664
