我正在尝试在Windows 10中使用ISE 14.7。
ISE 14.7开始没问题,但是如果我点击New Project,它会崩溃。 我能够通过单击* .xise文件来运行它,但如果我关闭该项目并尝试打开另一个项目,我会收到此弹出错误: _pn.exe _pn.exe已停止工作 有点令人沮丧的是无法在ISE中打开和关闭项目。 在不同的帖子中有一个视频链接,但该视频已被删除。 以上来自于谷歌翻译 以下为原文 I’m trying to use ISE 14.7 in Windows 10. ISE 14.7 starts okay, but if I click on New Project, it crashes. I was able to get it to run by clicking on an *.xise file, but if I close that project and try to open another project, I get this popup error: _pn.exe _pn.exe has stopped working Kind of frustrating not being able to open and close projects in ISE. There's a link to a video in a different post, but that video has been removed. |
2个回答
@oldradarguy,
看看这个AR是否有助于您的情况:https://www.xilinx.com/support/answers/62380.html 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @oldradarguy, See if this AR helps in your case: https://www.xilinx.com/support/answers/62380.html Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).View solution in original post |
@oldradarguy,
看看这个AR是否有助于您的情况:https://www.xilinx.com/support/answers/62380.html 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @oldradarguy, See if this AR helps in your case: https://www.xilinx.com/support/answers/62380.html Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
只有小组成员才能发言,加入小组>>
2300 浏览 7 评论
2707 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2192 浏览 9 评论
3274 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2340 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
617浏览 1评论
1674浏览 1评论
173浏览 1评论
638浏览 0评论
1828浏览 0评论
GMT+8, 2024-9-14 10:57 , Processed in 1.082707 second(s), Total 51, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
