电子发烧友论坛|
早上好,
我想在我的项目中使用XC95144XL CPLD。 从那里我明白我需要使用ISE设计工具。 所以我试着安装它。事情是我的Windows帐户没有管理员权限。 要安装它,Windows 10会要求我提供管理员帐户和密码。 我做到了,安装工作得很好。 但是当我尝试启动项目导航器时,它不适用于我的帐户。 首先,我的帐户没有快捷方式,因此我将其从管理员帐户复制/粘贴到我的帐户。 然后,当我尝试运行它时,软件只是没有启动,在一小段时间内,窗口栏上出现了一个cmd图标,然后它消失了,没有其他任何事情发生。 但是,如果我尝试从我安装它的管理员帐户启动它,那就可以了。 问题是我无法使用我需要在个人帐户中使用的管理员帐户。 如何让项目导航器在我的帐户上运行? 以下是更详细的步骤: 1)从我的个人帐户启动ISE安装,该帐户没有管理员权限 2)windows 10“弹出”:您需要管理员权限才能安装它,并提供管理员用户名和密码。 我提供用户名和密码 3)安装工作正常 4)从C: Users admin AppData Roaming Microsoft Windows Start Menu Programs Xilinx ISE toC: Users personal AppData Roaming Microsoft Windows Start Menu Programs Xilinx ISE复制快捷方式 有权访问快捷方式 4)尝试从我的个人帐户启动ISE项目导航器=> ISE无法启动 5)退出我的帐户登录管理员帐户并尝试启动ISE项目导航器=>正常工作 我正在使用Windows 10 enterprise 2016 64位 我有8GB的内存 我试图使用版本14.7 for ISE Web包的Windows 10。 非常感谢 以上来自于谷歌翻译 以下为原文 Good morning, I want to use a XC95144XL CPLD in my project. From there I understand I need to use the ISE design tools. So I tried to install it.The thing is my windows account do not have admin rights. To install it windows 10 asks me to give an admin account and password. I did that and the installation worked well. But then when I try to launch the project navigator it does not work on my account. First I did not have the shortcut on my account so I copy/pasted it from the admin account to my account. Then when I try to run it the software just does not start, for a fraction of second there is a cmd icon appearing on the windows bar and then it disappear with nothing else happening. But if I try to launch it from the admin account that I installed it with, that works. The problem is I can't work from that admin account I need to work from my personal account. How can I make the project navigator working on my account? Here are the steps performed in more details: 1) launching ISE install from my personal account which does not have admin rights 2) windows 10 "pop up" : you need admin rights to install it give an admin username and password. I give the username and password 3) installation is working fine 4) copying the shortcut from C:UsersadminAppDataRoamingMicrosoftWindowsStart MenuProgramsXilinx ISE to C:UserspersonalAppDataRoamingMicrosoftWindowsStart MenuProgramsXilinx ISE to have access to the shortcut 4) trying to launch the ISE project navigator from my personal account => The ISE just does not start 5) log out of my account log in on the admin account and try to launch the ISE project navigator => Works fine I am working on windows 10 enterprise 2016 64 bits I have 8GB of memory I am trying to use the version 14.7 for windows 10 of the ISE web package. Many thanks |
3个回答
祝你好运
该部分在论坛周围有一些关于问题的注释 除此之外,Windows 10上不支持ISE, 所以你要么必须安装Vm,要么在那个Vm上运行Windows 7或Linux, 再次不支持, 或者你找到一台支持操作系统的机器。 以上来自于谷歌翻译 以下为原文 Good luck that part has a few notes around the forum about problems Adding to that , you have ISE is not supported on windows 10 for that part, so you either have to install a Vm , and run windows 7 or Linux on that Vm, which again is not supported, or you find a machine with a supported OS on. |
有两个ISE的14.7可用
ise for windows 10,它只有windows 10下载选项 这张纸条是 “此版本的ISE Design Suite仅支持Spartan®-6 FPGA” ISE 14.7(当时只有windows 7和linux下载选项) 这张纸条是 “ISE支持以下设备系列及其前几代产品:Spartan-6,Virtex-6和Coolrunner” 以上来自于谷歌翻译 以下为原文 There are two ISE's 14.7 available ise for windows 10, which only has the windows 10 download option the note is "This version of ISE Design Suite only supports Spartan®-6 FPGAs" ISE 14.7 ( which then only has windows 7 and linux download options ) the note is "ISE supports the following devices families and their previous generations: Spartan-6, Virtex-6, and Coolrunner" |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1198浏览 1评论
/9
GMT+8, 2025-12-14 07:51 , Processed in 0.740228 second(s), Total 49, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3078
