扫一扫,分享给好友
亲爱的大家,
我试图生成一个简单的模型(模拟运行良好),但我一直收到以下错误(见附图)。 有谁知道可能是什么原因? 它通常用于生成之前。 最好的祝福, 抢 以上来自于谷歌翻译 以下为原文 Dear all, I tried to generate a simple model (the simulation ran through fine), but I keep receiving the following error (see picture attached). Does anyone have an idea what can be the reason? It used generate normally before. Best regards, Rob |
6个回答
你好@acousic_vibration
看起来你没有Sysgen许可证。 在此处共享许可证文件和xinfo文件以进行确认 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @acousic_vibration Looks like you do not have Sysgen license. Share the license file and xinfo file here to confirm Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
尊敬的先生
在这里我附上thexinfo和许可证文件请解决这个问题 Xilinx.lic 2 KB 以上来自于谷歌翻译 以下为原文 Respected Sir Here i am attaching the xinfo and license file please solve this problem |
嗨@ umamahesh271,
附加此位置中的xinfo.txt:C: Users MAHESH 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @umamahesh271, Attach the xinfo.txt present in this location: C:UsersMAHESH Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
尊敬的先生
在这里,我附上了Xinfo.txt 感谢您 xinfo.txt 71 KB 以上来自于谷歌翻译 以下为原文 Respected Sir Here i am attaching the Xinfo.txt Thanking you |
嗨@ umamahesh271,
您没有许可证中的Sysgen功能。 因此你无法使用它。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @umamahesh271, You do not have Sysgen feature in the license. Hence you are unable to use it. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
尊敬的先生
我怎样才能避免这个问题。 此许可证文件仅从xilinx网站下载。 请解决这个问题。 感谢您 umamahesh 以上来自于谷歌翻译 以下为原文 Respected Sir How can i avoid this problem. this licence file was downloaded from xilinx website only. please solve this problem. Thanking you umamahesh |
只有小组成员才能发言,加入小组>>
3119 浏览 7 评论
3408 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2875 浏览 9 评论
3967 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3058 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1332浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1171浏览 1评论
/9
GMT+8, 2025-12-3 17:12 , Processed in 1.389475 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3260
