电子发烧友论坛扫一扫,分享给好友
嗨,我有错误:模拟引擎无法启动:找不到有效的许可证进行模拟
我正在使用Vivado 2015.2 Webpack。 我一直在阅读类似的案例,但我仍然不知道有没有办法解决这个问题。 当我运行commandxlicclientmgr -v时,我得到: 查看应用程序可信存储 如果不信任你。 D如果禁用。 。 fulfillmentType。 。 。 到期计数Fulfillmentid ProductId 你 6永久0 211571623 209855574U。 6永久0 211820930 209856468 已浏览2条履行记录中的2条。 我还读到了关于不受信任的状态,我真的不知道是什么原因引起的,可能是系统中的最新格式或由于时区变化而导致时钟变化,我真的很感谢你的帮助。 以上来自于谷歌翻译 以下为原文 Hi, I am having the error: Simulation engine failed to start: A valid license was not found for simulation I am using Vivado 2015.2 Webpack. I have been reading similar cases but still I dont know if there is any way to solve this. When I run the command xlicclientmgr -v I obtain: Viewing application trusted storage. U if untrusted . D if disabled . . fulfillmentType . . . Expiry Count FulfillmentId ProductId U . 6 permanent 0 211571623 209855574 U . 6 permanent 0 211820930 209856468 Viewed 2 of 2 fulfillment records. I have also read about untrusted status and I really dont know what could cause it, perhaps a recent format in the system or a clock change because of a time zone change, I would really appreciate your help. |
6个回答
您好,下面的帖子可以提供帮助http://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-License-Manager-will-not-allow-me-to-return-license/m-p/531573#M8739
问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello, Below thread can be helpful http://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-License-Manager-will-not-allow-me-to-return-license/m-p/531573#M8739Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨,Ashish,
我实际上有一个类似的问题,但使用ISE 14.7 webpack版本。 安装完毕后 然后我尝试获得许可证,但唯一可用的许可证仅适用于Vivado相关产品。 由于我以前安装过Vivado Webpack,我确实拥有Vivado Webpack的许可证, 但是当我尝试将Vivado Webpack许可证加载到ISE14.7中时,我得到类似的“可信”错误。 那么我可以将Vivado Webpack用于ISE Webpack吗? (我确实尝试过,但得到了“未经编辑的”错误)。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi Ashish, I actually has a somewhat similar issue but with ISE 14.7 webpack version. After installation, I then tried to obtain a license but the only license available was only for Vivado related products. Since I also had Vivado Webpack installed previously, I do have the license for the Vivado Webpack, but I get similar "Trusted" error when I tried to load the Vivado Webpack license into my ISE14.7. So can I use the Vivado Webpack for the ISE Webpack? (I did try that but got the "unstruted" error). Thanks. |
嗨,Ashish,
我试过按照上面提供的链接中的说明进行操作 但它没有帮助我。 我想我需要一些来生成 ISE 14.7版本的Webpack许可证。 你是否认为这是因为我之前安装了Vivado Webpack 它以某种方式干扰了目前的14.7? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi Ashish, I've tried followed the instructions in the link provided above but it didn't help me. I guess I need someway to generate a Webpack license for the ISE 14.7 version. Do you think that because I previously installed the Vivado Webpack that somehow it interfere with the current 14.7? Thanks. |
你好@ andy92806
您不能将ISE 14.7与Vivado webpack许可证一起使用。 在您的帐户中,您应该在基于证书的许可证部分下看到ISE webpack许可证。 如果你没有看到它,你可能已经alreday下载了它。如果你已经下载它,它将在你的帐户的管理许可标签下,你可以从那里再次下载它。 下载ISE webpack许可证后,使用Vivado许可证管理器中的加载许可证选项将其安装在您的计算机上,如下所示。 以上来自于谷歌翻译 以下为原文 Hi @andy92806 You can't use ISE 14.7 with Vivado webpack license. In your account you should see ISE webpack license under certificate based licenses section. If you are not seeing it you might have alreday downloaded it.If you already downloaded it it will be under manage license tab in your account and you can downlaod it again from there. Once you download the ISE webpack license, install it on your machine using load license option in Vivado license manager as shown below. |
我附加了Xilinx网站的“管理许可”选项卡的屏幕截图。 你可以看一下,因为我没有看到任何ISE许可证。 如果你没有看到它,你可能已经alreday下载了它。如果你已经下载它,它将在你的帐户的管理许可标签下,你可以从那里再次下载它。 我有Vivado Webpack许可证,但我认为我从未下载任何Webpack许可证 ISE版本。 以上来自于谷歌翻译 以下为原文 In your account you should see ISE webpack license under certificate based licenses section. I attached the screen capture of the "Manage License" tab from Xilinx website. Could you take a look since I do not see any ISE license there. If you are not seeing it you might have alreday downloaded it.If you already downloaded it it will be under manage license tab in your account and you can downlaod it again from there. I had the Vivado Webpack license but I don't think I ever download any Webpack license for the ISE version. |
按照线程中的步骤执行后,我可以下载在VLM中激活的新许可证文件。
现在,当我尝试模拟时,我仍然获得相同的消息: 错误:[Simtcl 6-50]模拟引擎无法启动:未找到有效的许可证进行模拟。 请运行Vivado License Manager以获取有关确定哪些功能和设备已获得系统许可的帮助。 但是,存在差异。 我运行commandxlicclientmgr -v I。 我得到: 如果不信任你。 D如果禁用。 。 fulfillmentType。 。 。 到期计数FulfillmentId ProductId 可信存储中没有履行记录。 你知道原因是什么吗? 谢谢你的支持 以上来自于谷歌翻译 以下为原文 After following the steps found in the thread I was able to download a new licence file which is activated in the VLM. Now when I try to simulate I still obtain the same message: ERROR: [Simtcl 6-50] Simulation engine failed to start: A valid license was not found for simulation. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system. But, there is a difference. Whe I run the command xlicclientmgr -v I . I am obtaining: U if untrusted . D if disabled . . fulfillmentType . . . Expiry Count FulfillmentId ProductId No fulfillment records in trusted storage. Do you know what could be the cause? Thanks for your hep |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 19:23 , Processed in 0.699566 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2906
