嗨论坛,
我们正在运行Xilinix设计套件13.1并在许可证服务器中安装了网络许可证。 但是,每当我们启动该工具时,它都会说未找到许可证并要求获得许可证。 但我们可以从经理窗口获取许可证。 我附上了图片。 谢谢 J.P raj 以上来自于谷歌翻译 以下为原文 Hi forum, we are running Xilinix design suite 13.1 and have network license installed in the license server. But each time when we start the tool it says license not found and asks for license. But we are able to get the license from manager window. I have attached the images. Thanks J.P raj |
10个回答
嗨,
检查此AR:http://www.xilinx.com/support/answers/33115.htm 谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, Check this AR: http://www.xilinx.com/support/answers/33115.htm Thanks -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
嗨,
这里我附上了xinfo.txt文件。 谢谢 J.P Raj xinfo.txt 51 KB 以上来自于谷歌翻译 以下为原文 Hi, Here with i attach the xinfo.txt file. thanks J.P Raj |
嗨,
来自Xinfo,您没有软件许可证。 如果您有许可证,请将其附在此处。 如果从服务器获取许可证,请发布以下命令的输出(在ISE命令提示符中): lmutil lmstat -c port @ server 谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, From the Xinfo, you do not have a license for software. If you have a license, attach it here. If you are getting the license from server, post the output of the below command (in ISE Command Prompt): lmutil lmstat -c port@server Thanks -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
你好J.P raj,
看起来(从您的新佛)您的浮动许可证未正确设置且无法找到。您看,使用浮动许可证,您需要在生成的计算机上启动许可证服务器,然后指向 您希望使用许可证的计算机上的许可证服务器。 要启动浮动许可证服务器,您需要遵循许可常见问题解答(http://www.xilinx.com/tools/faq.htm)的“使用浮动许可证”部分中的说明。 你有没有遵循这些指示? 问候, Anatoli Curran, Xilinx技术支持 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello J.P raj, It looks like (from your Xinfo) that your floating license wasn’t set up correctly and can't be found.You see, with a floating license you need to start the license server on the computers it was generated for and then point to that license server on the computers where you wish to use the license. To launch the floating license server you need to follow the directions laid out in the "Using a Floating License" section of the licensing FAQ (http://www.xilinx.com/tools/faq.htm). Have you followed these directions? Regards, Anatoli Curran, Xilinx Technical Support Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
嗨阿纳托利,谢谢你的回复。
但是我们的许可证服务器在大多数机器上运行良好。 只有一些新部署的计算机(VDI桌面)正面临这个问题,而且只有在我关闭并重新打开其请求许可证时才能使用许可证管理器窗口(附加图像)提取许可证。 以上来自于谷歌翻译 以下为原文 Hi Anatoli, Thanks for your reply. But our license server is working fine with most of the machines. only some newly deployed machines (VDI desktops) are facing this issue and more over I am able to pull license using license manager window (attached image) only when I close and reopen again its asking for license. |
嗨,
下图清楚地表明问题出在服务器端: 正如我之前所要求的,在工作客户端计算机和非工作客户端计算机上运行命令:lmutil lmstat -c 2100@10.2.3.1并共享输出。 谢谢 谢谢。 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, The below image clearly states that the issue is at server end: As I requested earlier, run the command: lmutil lmstat -c 2100@10.2.3.1 on the working client machine and non-working client machine and share the output. Thanks Thanks. -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
HI,
客户端和许可证服务器之间的端口需求是什么。 目前tcp端口2100已打开。 以上来自于谷歌翻译 以下为原文 HI, what is the port requierment between client and license server . currently tcp port 2100 is open. |
嗨,
检查此AR:http://www.xilinx.com/support/answers/33115.htm 谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Check this AR: http://www.xilinx.com/support/answers/33115.htm Thanks -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
是的防火墙端口问题。
非常感谢.. 以上来自于谷歌翻译 以下为原文 Yes its problem with firewall port . thank you so much.. |
只有小组成员才能发言,加入小组>>
2222 浏览 7 评论
2645 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2127 浏览 9 评论
3197 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2254 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
497浏览 1评论
1580浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2221浏览 0评论
547浏览 0评论
1716浏览 0评论
GMT+8, 2024-7-5 18:26 , Processed in 1.510414 second(s), Total 96, Slave 80 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
