电子发烧友论坛|
当我尝试使用2024.3进行小型模拟时,我在TCL窗口中收到以下消息:
... 信息:[USF-XSim-98] ***使用args运行xsim“TESTBENCH_FOR_top_behav -key {Behavioral:sim_2:Functional:TESTBENCH_FOR_top} -tclbatch {TESTBENCH_FOR_top.tcl} -log {simulate.log}”INFO:[USF-XSim -8]加载模拟器功能Vivado Simulator 2014.3ERROR:[Simtcl 6-50]模拟引擎无法启动:未找到模拟的有效许可证。 请运行Vivado许可证管理器以获取有关确定系统许可的功能和设备的帮助。有关详细信息,请参阅Tcl控制台或消息。 我尝试了重新安装和许可证,相同的结果....这是在webpack中禁用???? 约翰 以上来自于谷歌翻译 以下为原文 When I attempt a small simulation using 2024.3 I get the following message in the TCL window: ... INFO: [USF-XSim-98] *** Running xsim with args "TESTBENCH_FOR_top_behav -key {Behavioral:sim_2:Functional:TESTBENCH_FOR_top} -tclbatch {TESTBENCH_FOR_top.tcl} -log {simulate.log}" INFO: [USF-XSim-8] Loading simulator feature Vivado Simulator 2014.3 ERROR: [Simtcl 6-50] Simulation engine failed to start: A valid license was not found for simulation. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system. Please see the Tcl Console or the Messages for details. I tried a re-install and licenses, same results.... Has this been disabled in webpack???? John |
11个回答
嗨,你能检查一下webpack的版本限制是否满足2014.3?你可以在tcl控制台中运行report_environment命令并在这里附上日志吗?谢谢,Deepika。
谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, Can you check if the version limit of webpack satisifes 2014.3? Can you run report_environment command in tcl console and attach the log here? Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)View solution in original post |
谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Can you check if the version limit of webpack satisifes 2014.3? Can you run report_environment command in tcl console and attach the log here? Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
嗨,请查看版本限制详情@ http://www.xilinx.com/support/answers/33770.htm
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Please check the version limit details @ http://www.xilinx.com/support/answers/33770.htmThanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我附上了日志。
似乎不知何故获得了Vivado Webpack许可证,我设法获得了ISE许可证??? 不确定是怎么回事或如何纠正它。 你可否确认? 约翰 vivado_license_dump.txt 9 KB 以上来自于谷歌翻译 以下为原文 I have attached the log. It appears that somehow instead of getting a Vivado Webpack License, I managed to get an ISE license??? Not sure how that happened or how to correct it. Can you confirm? John |
嗨,
Vivado webpack的版本限制为2014.07,您无法使用Vivado 2014.3。 您生成的最新许可证是ISE webpack。 我们已经开始为Vivado提供基于激活的webpack许可证。 要生成许可证,请按照以下步骤操作。 1.转到开始 - > Xilnx设计工具 - > Vivado 2014.3 - >管理Xilinx许可证。 这将打开VLM。 2.在“获取许可证”选项卡中,选择“获取免费许可证”,然后单击“立即连接”。 3.这会将您引导至Xilinx许可站点,您可以在“基于激活的许可证”部分中找到Vivado webpack许可证。 生成此许可证。 4.转到VLM中的“加载许可证”选项卡,然后使用“激活许可证”选项加载接收的许可证.xml文件。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, The version limit of Vivado webpack is 2014.07 with which you cannot use Vivado 2014.3. The latest license which you generated is ISE webpack. We have started providing activation based webpack licenses for Vivado. To generate the license follow the steps below. 1. Go to Start--> Xilnx Design tools --> Vivado 2014.3 --> Manage Xilinx licenses. This opens VLM. 2. In the "obtain license" tab, select "get free licenses" and click on "connect now". 3. This directs you to Xilinx licensing site where you can find the Vivado webpack license in "Activation based licenses" section. Generate this license. 4. Go to "Load license" tab in VLM and load the recieved license .xml file using "Activate license" option. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
您好John,从附带的文本文件中,我看到许可证版本限制为2014.07,与Vivado 2014.3一起使用,您需要最低版本限制为2014.10.Thanks,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello John, From the text file attached, I see the license version limit is 2014.07 where as to work with Vivado 2014.3, you need a minimum version limit as 2014.10. Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨约翰,请查看我之前的消息(http://www.xilinx.com/support/answers/33770.htm)。
此AR可帮助您了解版本限制详细信息。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi John, Please check my previous message (http://www.xilinx.com/support/answers/33770.htm). This AR helps you in understanding the version limit details.Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
你有非常明确的指示,但激活许可证块在我的屏幕上显示为灰色...当我使用VLM时,它只是坐着并循环,(防火墙?? _)我点击取消然后收到一封带有ISE webpack许可证的电子邮件
.. 以上来自于谷歌翻译 以下为原文 You have very clear instructions however the activation licenses block is greyed out on my screen... When I use the VLM, it just sits and cycles, (firewall??_) I hit cancel and then get an email with the ISE webpack license.. |
嗨,
要使激活许可证部分可见,您需要通过VLM进行连接。 如果VLM需要时间加载,请尝试下载 1. Source Vivado环境:打开命令提示符并迁移到 Xilinx Vivado 2014.3。 运行settings64.bat或settings64.sh。 2.运行以下命令,生成一个html文件。 xlicclientmgr -cr create_request.xml3。 打开创建的html文件并使用您的详细信息登录,看看您是否能够生成许可证。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, For the activation licenses section to be visible you need to connect via VLM. If VLM is taking time to load, try below 1. Source Vivado environment: Open command prompt and migrate to 2. Run the below command this generates a html file. xlicclientmgr -cr create_request.xml 3. Open the html file created and login with your details, see if you are able to generate the license. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
Vermulad,
我开始从我的许可页面中删除一些旧许可证,最后找到了一个我可以“修改”的vivado webpack工具。 它向我发送了一个新的xilinx.lic文件,我可以加载它。 谢谢,约翰 以上来自于谷歌翻译 以下为原文 Vermulad, I started deleting some of the old licenses from my licence page and finally found one for the vivado webpack tools which I could "modify". It sent a new xilinx.lic file to me which I was able to load. Thanks, John |
嗨,
哦好的。 但请确保您在许可证文件中具有2014.10或更高版本的限制,然后仅适用于vivado 2014.3。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Oh, ok. But ensure that you have a version limit of 2014.10 or above in the license file then only it works with vivado 2014.3. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 18:56 , Processed in 0.779498 second(s), Total 92, Slave 75 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2906
