大家好!
我遇到了Vivado 2014.2 Webpack版本的问题,当我试图模拟示例设计时(然后它发生了这个问题在每个设计中都很常见......)。 [Simtcl 6-50]模拟引擎无法启动:未找到有效的许可证进行模拟。 请运行Vivado许可证管理器以获取有关确定系统许可的功能和设备的帮助。有关详细信息,请参阅Tcl控制台或消息。 我不知道它发生的原因。 之前我已经成功安装了免费的Webpack License(由VLM加载.xml文件),并在VLM中显示。 我在论坛中尝试了很多解决方案: - 我重新安装了Vivado三次, - 我用禁用防病毒软件(Avast)运行模拟,我检查了它的“病毒库”,但根本没有* .dll文件 - 我尝试在32位模式下运行Vivado,结果是一样的 我考虑创建另一个Xlilinx帐户,但这也可能是不必要的,因为VLM每次重新安装后都会找到旧许可证 - 创建另一个许可证没有意义吗? 你能告诉我其他任何可能吗? 我希望我的情况有解决方案。 :) 当然,我会尽力回答你的每一个问题。 最好的祝福 垫 以上来自于谷歌翻译 以下为原文 Hello everyone! I met a problem with Vivado 2014.2 Webpack version, when I tried to simulate example design (and then it occured that problem is common for every design...). [Simtcl 6-50] Simulation engine failed to start: A valid license was not found for simulation. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system. Please see the Tcl Console or the Messages for details. I don't know the reason why it happens. Earlier I had installed succesfully free Webpack License (loaded .xml file by VLM) and it is shown in VLM. I tried many solutions mentioned here in forums: - I reinstalled Vivado three times, - I ran simulation with disabled antivirus (Avast), I checked its "virus chest", but there is no *.dll files at all - I tried running Vivado in 32bit mode and the result is the same I consider creating another Xlilinx account, however this also may be unnecessary, because VLM found old license every time after reinstallation - there is no point in creating another license? Could you suggest me any other possibilities? I hope there is solution for my situation. :) Of course I'll try to answer every of your questions. Best regards mat |
19个回答
你有没有在你的系统上获得30天的评估许可证?
如果过期的eval许可证仍在许可证路径中并且在webpack许可证之前找到,则会发生此类许可错误。 您应该可以从Xilinx许可证管理器中进行检查。 - Gabor 以上来自于谷歌翻译 以下为原文 Have you ever had a 30-day evaluation license on your system? This sort of licensing error can happen if your expired eval license is still in the license path and is found before the webpack license. You should be able to check this from the Xilinx License Manager. -- Gabor |
你能发布显示许可功能的VLM截图吗?
看到你的许可证文件也很好。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Can you post the screenshot of VLM which shows the licensing features? It's also good to see your license file. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
您好,感谢您的快速回复。
@gszakacs 不,我从未在此主机上获得任何评估许可。 下面是VLM的截图,现在只有一个许可证(之前还有来自Vivado Webpack的“认证”窗口中的ISE包),其“搜索顺序”值为1。 @graces 以下是VLM的截图和我的许可文件作为附件。 Xilinx_License.xml 3 KB 以上来自于谷歌翻译 以下为原文 Hello, thank you for your quick reply. @gszakacs No, i have never had any evaluation license on this host. Below there is a screenshot from VLM, now there is only one license (earlier there was also ISE pack, in "certified" window) from Vivado Webpack with "search order" value 1. @graces Here is screenshot from VLM and my license file as attachment. Xilinx_License.xml 3 KB |
嗨,你能在webpack设备上运行模拟吗?
您可以通过在任何示例设计上运行模拟来确认,如下所示:谢谢,Vinay -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Are you able to run simulation on webpack devices. You can confirm by running simulation on any example design as shown below: Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
你好Vinay,
我无法运行模拟既不是示例设计也不是我的,结果总是错误[Simtcl 6-50]。 垫 以上来自于谷歌翻译 以下为原文 Hello Vinay, I'm not able to run simulation of neither example design nor mine, result is always error [Simtcl 6-50]. mat |
嗨Mat,你能在Tcl控制台中运行这个命令并分享结果:xlicclientmgr -vThanks,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Mat, Can you run this command in Tcl console and share the outcome: xlicclientmgr -v Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨Mat,由于xlicclientmgr -v的输出表明在机器上处理的许可证文件是不可信的,我怀疑是否是许可证生成过程。
是否为此机器生成许可证? 谢谢,维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Mat, Since the output of xlicclientmgr -v indicates that the license file processed on the machine is untrusted, I doubt whether the license generation process. Is license generated for this machine? Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
转到许可委员会
问候,Debraj ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Moving to Licensing BoardRegards, Debraj ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗯,这是我唯一使用Xilinx软件的主机。
我在许可证创建过程中使用它,所以一切都应该没问题? 在Xilinx网页的“产品许可”选项卡中,“管理许可证”中有此许可证,主机名是正确的(“Mateusz-PC”,如上面VLM的屏幕截图所示)。 你有什么建议吗? 也许我可以以某种方式重新创建许可证? 垫 以上来自于谷歌翻译 以下为原文 Well, this is the only host, where I used Xilinx software. I used it in license creation process so everything should be ok? On Xilinx webpage, in Product Licensing tab, "Manage Licenses" there is this license, hostname is correct ("Mateusz-PC", as in the screenshot from VLM above). Have you got any suggestions? Maybe can I recreate license somehow? mat |
嗨Mat,请按照以下答案记录中提到的步骤进行操作:http://www.xilinx.com/support/answers/60525.html返回许可证。
返回许可证后,再次生成许可证并对其进行处理并共享VLM快照。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Mat, Follow the steps mentioned in the following answer record: http://www.xilinx.com/support/answers/60525.html to return the license. Once the license is returned, generate it again and process it and share the VLM snapshot. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
我试图按照建议的答案记录中提到的步骤,但发生错误(第一步),我无法返回许可证。
你有进一步的建议吗? 垫 以上来自于谷歌翻译 以下为原文 I tried to follow steps mentioned in suggested answer record, but an error occured (at first step) and I'm unable to return the license. Have you got any further suggestions? mat |
嗨,
请在DOS提示符下而不是在Vivado Tcl shell中运行这些命令行,看看是否仍然出现此错误。 问候, 肖恩 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi, Please run these command line in DOS prompt rather than in Vivado Tcl shell and see if you still get this error. Regards, Sean ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
有人能帮助我吗?
如何“修复”(如上所示)我的许可证? 我明白了,我可以用xlicclientmgr创建修复请求,但下一步是什么? 垫 以上来自于谷歌翻译 以下为原文 Can somebody help me? How can I "repair" (as seen above) my license? I see, I can create repair request with xlicclientmgr, but what next? mat |
@seanz
我做了,你的建议,但结果相同。 垫 以上来自于谷歌翻译 以下为原文 @seanz I did, what you suggested, but there is the same result. mat |
嗨Mat,
我不知道为什么许可证实现不受信任。 您是否更改了机器硬件配置? 或者您是否从备份还原系统和许可证? 请尝试使用以下命令来修复履行 xlicclientmgr -cr -e 211463675 问候, 肖恩 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi Mat, I have no idea why the license fulfillment is untrusted. Have you changed your machine hardware configuration? Or have you restore your system as well as license from a backup? Please try with following command to repair the fulfillment xlicclientmgr -cr -e 211463675 Regards, Sean ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
你好肖恩,
在第一次安装Vivado之后,我能够运行模拟示例设计。 然后我创建了自己的简单项目,但是在模拟时发生异常,当我重新启动模拟整个Vivado崩溃时。 当我再次启动Vivado时,由于[Simtcl 6-50]许可证错误,没有模拟成功... 我没有对我的计算机进行过任何改动,也没有从备份中恢复系统。 有没有办法恢复许可证? 我试图通过VLM再次激活它,但它说它已经被处理过了。 我使用了建议的命令,由于xlicclientmgr -listRequests命令,我可以看到我的请求状态为“待定”。 我的申请何时处理? 问候, 垫 以上来自于谷歌翻译 以下为原文 Hello Sean, after first Vivado installation I was able to run simulation of example design. Then I created own simple project, but an exception occured while simulation and when I restarted simulation whole Vivado crashed. When I started Vivado again no simulation was succesful because of [Simtcl 6-50] license error... I haven't made any hadware changes of my computer as well as I haven't restored system from backup. Is there any way to restore license? I tried to activate it again through VLM, but it says that it has been already processed. I used suggested command and I can see my request status as "Pending" thanks to xlicclientmgr -listRequests command. When will my request be processed? Regards, mat |
你好,
有人可以帮助我并回答我的问题吗? 问候, 垫 以上来自于谷歌翻译 以下为原文 Hello, could somebody help me and answer my questions? Regards, mat |
嗨Matey22,
我有一个类似的问题,我的许可证需要修复。 你有没有找到解决办法? 谢谢 以上来自于谷歌翻译 以下为原文 Hi Matey22, I am having a similar issue where my license needs repair. Did you ever find a fix? Thanks |
只有小组成员才能发言,加入小组>>
2337 浏览 7 评论
2756 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2229 浏览 9 评论
3306 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2381 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
690浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
488浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
268浏览 1评论
697浏览 0评论
1892浏览 0评论
GMT+8, 2024-10-17 16:18 , Processed in 2.090181 second(s), Total 114, Slave 98 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
