扫一扫,分享给好友
大家好,
在将vivado 2016.1安装到d: xilinx时,发生以下错误: 提取存档D时遇到错误: Xilinx_Vivado_SDK_2016.1_0409_1 payload rdi_0076_2016.1_0409_1.xz可能的原因可能是:磁盘已满,您已超出磁盘配额,或目标目录太长。 我很确定d:/上有足够的空间,为什么目录太长了? 最好的祝福 向超 以上来自于谷歌翻译 以下为原文 hi all, While installing vivado 2016.1 to d:xilinx,the following error occured: Error was encountered while extracting archive D:Xilinx_Vivado_SDK_2016.1_0409_1payloadrdi_0076_2016.1_0409_1.xz The possible reasons can be: the disk is full, you've exceeded disk quota, or the destination directory is too long. I am pretty sure there is enough space on d:/, and why the directory is too long? best regards Xiang Chao |
2个回答
嗨@南瓜,
请访问http://www.xilinx.com/support/answers/64982.html 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @pumpkin, Please go through http://www.xilinx.com/support/answers/64982.html Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨@南瓜,
你禁用了防病毒软件吗? 您也可以通过以下链接尝试Web安装程序:http://www.xilinx.com/support/download.html 还要检查您是否对要安装的文件夹具有正确的读写权限。 您可以尝试使用管理员权限。 此外,请确保下载文件的MD5总和与您从中下载的xilinx站点上提供的文件相匹配。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @pumpkin, Have you disabled antivirus? You can also try the web installer at this link: http://www.xilinx.com/support/download.html Also check if you have proper read-write permission on the folder where you are trying to install. You can try with Admin privileges. Also, make sure that the MD5 Sum of downloaded file matches the one provided on xilinx site where you downloaded it from. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
只有小组成员才能发言,加入小组>>
2178 浏览 7 评论
2616 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2090 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2211 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
448浏览 1评论
1540浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2184浏览 0评论
515浏览 0评论
1658浏览 0评论
GMT+8, 2024-5-13 03:55 , Processed in 0.998459 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
