亲爱的社区,
我已经在不同的主机系统,操作系统和浏览器上下载了Xilinx_ISE_DS_Lin_14.7_1015_1.tar。 计算出的md5sum总是如此 55a93d5e4c83e2b0e33ab61c00e25bef 代替 e8065b2ffb411bb74ae32efa475f9817 如下载网站上所述。 文件大小为6.538.618.880字节。 你知道吗,出了什么问题? 亲切的问候, 勒内 以上来自于谷歌翻译 以下为原文 Dear community, I've downloaded the Xilinx_ISE_DS_Lin_14.7_1015_1.tar on different host systems, operating systems and browsers. The calculated md5sum is always 55a93d5e4c83e2b0e33ab61c00e25bef instead of e8065b2ffb411bb74ae32efa475f9817 as noted on the download website. The size of the file is 6.538.618.880 bytes. Do you have an idea, what's going wrong? Kind regards, René |
3个回答
嗨,
尝试从以下链接下载http://www.xilinx.com/support/answers/57840.html 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, Try to download from the below link http://www.xilinx.com/support/answers/57840.html Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)View solution in original post |
嗨,
尝试从以下链接下载http://www.xilinx.com/support/answers/57840.html 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Try to download from the below link http://www.xilinx.com/support/answers/57840.html Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
从链接下载工作 - 现在。
在我尝试之前。非常感谢,René 以上来自于谷歌翻译 以下为原文 Downloading from the link works - now. Before I tried it too. Many thanks, René |
只有小组成员才能发言,加入小组>>
2178 浏览 7 评论
2616 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2084 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2210 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
446浏览 1评论
1539浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2184浏览 0评论
515浏览 0评论
1658浏览 0评论
GMT+8, 2024-5-11 12:54 , Processed in 1.182547 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
