安装在我的桌面上创建了两个快捷方式:Xilinx PlanAhead 14.7和ISE Design Suite 14.7。
PlanAhead快捷方式可以正确加载和运行PlanAhead应用程序。 ISE Design Suite快捷方式可打开“剪辑主机”窗口。 我已经多次在我的Windows 7,64位笔记本电脑上安装并重新安装了Webpack ISE 14.7。 我已经下载并重新安装了ISE的拆分版本和完整版本,但结果相同。 我总是在下载文件后验证MD5总和,以确保它们在此过程中没有损坏。 我试过运行32位和64位版本都没有成功。 在安装过程中,会弹出一个错误对话框,抱怨“提取存档时遇到错误”。 它建议检查以确保我对文件夹(我这样做)有写入权限并询问是否有足够的内存空间(我有足够的空间)。 如果我选择重试,则错误消失,安装继续。 如果我从头开始重新安装,那么这些错误对于相同的档案重复很多。 但正如我之前所说,MD5值正确匹配,我已尝试拆分文件安装和单个映像安装。 以上来自于谷歌翻译 以下为原文 The install creates two shortcuts on my desktop: Xilinx PlanAhead 14.7 and ISE Design Suite 14.7. The PlanAhead shortcut does load and run the PlanAhead application correctly. It is the ISE Design Suite shortcut that opens the Clip Host window. I've installed and reinstalled the Webpack ISE 14.7 on my Windows 7, 64 bit laptop several times. I have downloaded and reinstalled both the split version of ISE and the full version with the same result. I always verify the MD5 sums after downloading files to insure they are not corrupted in the process. I've tried running both 32 bit and 64 bit versions with no success. During installation, an error dialog box pops up several times complaining that "An error was encountered while extracting archive". It suggests checking to make sure I have write permission for the folder (I do) and questions whether there is enough memory space (I have way more than enough space). If I select retry then the error goes away and the installation continues. If I restart installation from scratch then these errors repeat pretty much for the same archives. But as I said previously the MD5 values match correctly and I have tried both the split file install and single image install. |
2个回答
嗨@mikpzk
我认为问题是由于您计算机上的防病毒软件造成的。 您可以禁用防病毒软件,安装该工具并尝试运行它吗? 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @mikpzkI think the issue is due to anti-virus software on your machine.Can you disable your anti-virus software, install the tool and try running it?Thanks,Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
我尝试从我的PC上卸载完整的ISE Design Suite,禁用McAfee Anti-Virus软件,然后重新安装所有内容。
不幸的是,我得到了相同的结果。 PlanAhead应用程序(以及套件中的所有其他应用程序)似乎正常工作,但任何运行Project Navigator的尝试都以Clip Host窗口结束。 以上来自于谷歌翻译 以下为原文 I've tried uninstalling the complete ISE Design Suite from my PC, disabling the McAfee Anti-Virus software and then re-installing everything. Unfortunately, I get the same result. The PlanAhead application (and all other applications in the Suite) appear to work properly but any attempt to run the Project Navigator ends with the Clip Host window. |
只有小组成员才能发言,加入小组>>
2249 浏览 7 评论
2658 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2149 浏览 9 评论
3217 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2282 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
526浏览 1评论
1603浏览 1评论
98浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2250浏览 0评论
567浏览 0评论
GMT+8, 2024-7-30 06:28 , Processed in 1.091879 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
