电子发烧友论坛|
你好,
我们已经购买了CysB3KIT(FX3)开发套件,我们计划用于视频流应用程序。我的开发环境是EZ USB套件和英特尔NUC Windows 7 64位。开发工具包没有在设备管理器和控制中心中枚举。按照套件指南中提到的跳线配置,PG 35,我们使所有连接仍然没有变化。PMODE设置为SW25.1和SW25.2断开,SW25.3和SW25.4断开,J96、J97连接在2-3和J98之间,用于USB枚举。 截至目前,我已经尝试了以下几点 改进的跳线设置为每个工具包用户GuiDeVoToT水平被确认,VIO1到VIO5给3.3V通过外部5V DC jack供电时,我短路J40,J47和J53连接断开。即使改变了与评估工具箱一起提供的电缆,也没有变化,当尝试通过外部Jlink Pro连接时,没有区别,目标被检测到,并且通过GDB服务器测量3.1V,但是按照KIT用户指南中给出的指令,连接失败,甚至。尝试从Eclipse中运行GDB调试配置,用于ARM9、大Endiad、JTAG配置。它停止了在FD0上检测到的异常情况,在STDIN上检测到错误,退出(当程序恢复时预期信号SIGIT) 如果你能帮我们登上董事会,那就太好了。 以上来自于百度翻译 以下为原文 Hi, We have purchased a CYUSB3KIT (FX3) development kit which we are planning to use for a video streaming application. My development environment is EZ USB suite and Intel NUC windows 7 64 bit. The development kit is not getting enumerated in device manager as well as in control centre. As per the jumper configurations mentioned in kit guide, pg 35 we made all connections still there is no change. The PMODE settings are SW25.1 and SW25.2 are off and SW25.3 and SW25.4 are off and J96,J97 are connected between 2-3 and J98 is left open for USB enumeration. As of now, I have tried the following
It would be great if you can help us in getting the board up and running. |
1个回答
嗨,Annamol,
从描述中我了解到您使用的是CYSUB3KIT-1001(EZ-USB®FX3μm开发套件(CysB3KIT-1001)赛普拉斯半导体) 你使用的工具包的版本是什么?这是仅供J77或J96以下。 您的设置SW 25、J96、J97和J98设置看起来很好。 在SW9中(BuSE电源和外部5V DC)使用的设置是什么? 我不确定你是否必须缩短J40和J47。 而不是外部电源时,您的总线电源设备任何LED的发光板上,如(D14,D15,D16,D17和D18) 谢谢和问候, 苏德希尔 以上来自于百度翻译 以下为原文 Hi Annamol, From the description my understanding is you are using CYUSB3KIT-001 (EZ-USB® FX3™ Development Kit (CYUSB3KIT-001) | Cypress Semiconductor ) What is the version of the KIT that you are using. This is available just next to J77 or below J96. Your settings SW 25, J96, J97 and J98 settings looks fine. What is the setting that have you used for SW9 (In buse power and external 5V DC) I am not sure if you have to short J40 & J47. Instead of external power when you bus power the device any of the LED's glow on the board such as (D14, D15, D16, D17 & D18) Thank You & Regards, Sudheer |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 00:22 , Processed in 0.471873 second(s), Total 41, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
497
