电子发烧友论坛|
嗨,
我正在研究在未来的项目中使用LSM6DSL(以取代我们对LSM6DS3的使用),我一直在测试STEVAL-MKI178V1评估部分。 在加速度计的Z轴上似乎有一些奇怪的信号(旧的LSM6DS3上没有),? 我已经将来自6个轴(gyro_x,gyro_y,gyro_z,accel_x,accel_y,accel_z)的30s测量数据的图片与3个不同方向的传感器相连。流氓信号的强度似乎总是恒定的(大约100 LSB,或者我们的规模为6 mg)。 传感器配置为高性能模式,104 Hz输出数据速率,+ -2g满量程。 谢谢, 缺口 #lsm6dsl #accelerometer 以上来自于谷歌翻译 以下为原文 Hi, I'm investigating the use of the LSM6DSL in a future project (to replace our use of the LSM6DS3) and I have been testing the STEVAL-MKI178V1 evaluation part. There appears to be some strange signal on the Z axis of the accelerometer (that was not present on the older LSM6DS3), ? I've attached pictures of 30s of measurement data from the 6 axes (gyro_x, gyro_y, gyro_z, accel_x, accel_y, accel_z) with the sensor in 3 different orientations. The strength of the rogue signal always seems to be constant (around 100 LSB, or 6 mg at our scale). The sensor is configured to be in high performance mode, 104 Hz output data rate, +-2g full scale. Thanks, Nick #lsm6dsl #accelerometer |
5个回答
这是出乎意料的行为。你在使用FIFO吗?
你有另一件要试试吗? 以上来自于谷歌翻译 以下为原文 It is unexpected behavior. Are you using FIFO? Do you have another piece to try? |
你好Miroslav,
是的我正在使用FIFO,我每1秒清空一次,这对应于信号的衰减。我只购买了一个部件用于评估目的,所以我没有任何替代硬件可供尝试。 以上来自于谷歌翻译 以下为原文 Hi Miroslav, Yes I am using the FIFO, and I am emptying it every 1 second which corresponds to the decay of the signal. I only purchased a single part for evaluation purposes so I do not have any alternative hardware to try. |
我认为传感器配置会出现问题。在我看来,时间戳数据被添加到Z轴数据,因此它创建了锯形信号。你能分享你的传感器配置吗?我可以尝试复制这个问题。
以上来自于谷歌翻译 以下为原文 I think there will be something wrong in the sensor configuration. It seems to me that timestamp data are added to the Z axis data, so it creates the saw shape signal. Can you please share your sensor configuration? I can try to replicate the issue. |
你好尼克,
你解决了问题了吗?我问,因为我有类似的问题。 Br Piotr 以上来自于谷歌翻译 以下为原文 Hello Nick, Did you solved your issue? I'm asking because i have similar problem. Br Piotr |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 00:29 , Processed in 0.852326 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2786
