电子发烧友论坛|
我们正在考虑在新设计中使用LSM6DS3,但我注意到LSM6DSL使用了一半的功率。这两个部分看起来是引脚兼容的,可能与软件兼容(至少对于大多数功能而言)。那是对的吗?
更具体地说:使用AN4650应用笔记与LSM6DSL一起使用是否有效(至少在该部分有类似的应用笔记可用之前)?如果部件与LSM6DSL交换,是否可能为LSM6DS3编写的代码有效? 有关LSM6DSL的使用申请说明的任何ETA? #lsm6ds3#lsm6dsl 以上来自于谷歌翻译 以下为原文 We were looking at using the LSM6DS3 in a new design, but I noticed the LSM6DSL uses half the power. The two parts look to be pin compatible and probably software compatible (at least for most features). Is that correct? More specifically: is it valid to use the AN4650 Application note to work with the LSM6DSL (at least until there is a similar application note for that part available)? Is it likely that code written for LSM6DS3 would work if the part were swapped with the LSM6DSL? Any ETA on a usage application note for the LSM6DSL? #lsm6ds3 #lsm6dsl |
1个回答
你好贾森,
我绝对可以推荐你使用 。 即使LSM6DS3与LSM6DSL非常相似,我建议你参考应用笔记( http://www.st.com/content/st_com/en/products/mems-and-sensors/inemo-inertial-modules/lsm6dsm.html )因为它几乎相同,。您还可以比较(http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion中的LSM6DS3-LSM6DSL编码差异。 -software / x立方体-mems1.html )或(http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-software/x-cube-mems-xt1 html的 )SW软件包,您可以从ST网站免费下载。这些封装支持几个Nucleo板和MEMS Shield板(IKS01A1和IKS01A2)。 感谢你并致以真诚的问候, 切赫 以上来自于谷歌翻译 以下为原文 Hello Jason, I can definitely recommend you to use . Even if LSM6DS3 is very similar to LSM6DSL, I suggest you to refer to application note ( http://www.st.com/content/st_com/en/products/mems-and-sensors/inemo-inertial-modules/lsm6dsm.html ) since it is almost the same, . Also you can compare the LSM6DS3-LSM6DSL coding differences in the (http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-software/x-cube-mems1.html ) or (http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-software/x-cube-mems-xt1.html ) SW packages which you can download from ST web for free. These packages support a few Nucleo boards and MEMS Shield boards (IKS01A1 and IKS01A2). Thank you and best regards, Petr |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1472 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1526 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3674 浏览 1 评论
3864 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2483 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
753浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
685浏览 5评论
730浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
977浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
781浏览 5评论
/9
GMT+8, 2025-12-15 11:19 , Processed in 0.544848 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
572
