电子发烧友论坛|
Freshliy已安装v 12.1。
我在WinXP SP3上。 在启动时,我收到许可证警告,选择获取WebPack许可证,然后经理将我带到reg。 网站。 通知似乎都很好: “感谢您注册ISE Design Suite产品。已安装相应的FLEXnet许可证密钥,现在可以使用该软件了。” 抱歉,该工具找不到该密钥。 如果不在c:Xilinx目录中,它可能在哪里? 请帮助 ! 以上来自于谷歌翻译 以下为原文 Freshliy installed v 12.1. Am on WinXP SP3. On startup, I get a license warning, select the fetch WebPack license, and the manager takes me to the reg. website. All seems well with the notification: "Thank you for registering your ISE Design Suite product. The appropriate FLEXnet license key has been installed and the software is now ready for use."Sorry, but the key is NOT found by the tool. Where might it be if not in the c: Xilinx directory?H e l p, p l e a s e ! |
4个回答
hackerooooo
几个.lic文件。 看起来ISE很满意这个: C:赛灵思 12.1 ISE_DS ISE coregen core_licenses 我错过了一些文件吗? 以上来自于谷歌翻译 以下为原文 hackerooooo several .lic files. Looks like ISE is happy with the one in: C:Xilinx12.1ISE_DSISEcoregencore_licenses Did I miss some documentation? |
那么,您只是将Xilinx指向该文件夹中的许可文件,现在一切都很好吗?
Wierd ......我遇到了同样的问题。 我很高兴看到你弄清楚了。 谢谢! 凯尔 以上来自于谷歌翻译 以下为原文 So, you just pointed Xilinx to one the license file located in that folder and everything is good now? Wierd... I was having the same issue. I am glad to see you figured it out. Thanks! Kyle |
嗨,
这些许可证文件适用于coregen IP。 ISE许可证应位于C:。Xilinx文件夹中。 我在上周运行非网络安装时遇到了问题,此处已解决。 布鲁斯 以上来自于谷歌翻译 以下为原文 Hi W, Those license files are for coregen IP. The ISE license should be in the C:.Xilinx folder. I had an issue getting a non-networked installation running last week and it was resolved here. Bruce |
目前WebSite中存在一个错误,应该在接下来的几天内修复。
从XLCM转到获取WebPack许可证目前会将您带到错误的页面。 您应该通过下载.xilinx.com - > 12.1 - > Enablement(右下角)手动生成WebPack许可证。 登录并生成WebPack许可证。 执行此操作后,将许可证存储在Linux上的$ HOME / .Xilinx的%HOMEDRIVE%/。Xilinx上。 以上来自于谷歌翻译 以下为原文 There is currently a bug in the WebSite that should be fixed within the next couple of days. Going from XLCM to get a WebPack license currently takes you to the wrong page. You should manually generate a WebPack license by going to download.xilinx.com -> 12.1 -> Enablement (bottom right hand side). Log in and generate a WebPack license. After doing so, store the license to your %HOMEDRIVE%/.Xilinx of $HOME/.Xilinx on Linux. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 22:18 , Processed in 0.911477 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2913
