电子发烧友论坛|
我安装了Xilinx 12.1 webpack版本并通过产品许可网站下载了许可证文件。
我安装在离线机器上,所以我在一台计算机上下载了许可证并将其转移到离线机器上。 我在离线计算机上安装了webpack版本,并使用Xilinx许可证配置管理器将许可证文件复制到.Xilinx文件夹。 当我运行ISE 12.1时,我没有遇到任何问题。 但是当我打开EDK时,我收到一条错误弹出窗口,上面写着“找不到XPS功能的许可证。此错误的典型原因是找不到许可证文件或找到的许可证文件不包含 具有所需功能的未到期许可证。......“ 我点击了,然后继续创建一个新项目。 在第一对屏幕之后,当我选择单个PowerPC时,我收到错误消息“无法找到Core ppc440_virtex5。请退出应用程序,因为任何进一步的操作未定义”。 有什么想法吗? 谢谢, 以上来自于谷歌翻译 以下为原文 I installed the Xilinx 12.1 webpack edition and downloaded a license file through the product licensing website. I installed on an offline machine, so i downloaded the license on one computer and tranferred it to the offline machine. I installed the webpack edition on the offline machine and copied the license file to the .Xilinx folder with the Xilinx License Config Manager. When i run ISE 12.1, i get no problem. But when i open EDK, I get an error popup that says " A license was not found for the XPS feature. Typical causes for this error are either that there is no license file found or that license files, which were found, do not contain an unexpired license with the required feature. ..." I click okay and proceed to make a new project. After the first couple screens, when I choose single PowerPC, I get an error that says "Core ppc440_virtex5 cannot be found. Please quit the application as any further operation is undefined". Any thoughts? Thanks, |
1个回答
你好
我认为Webpack仅适用于ISE, 不是EDK, 我认为EDK在你必须注册之前有一个月的时间来“评估它”,这可能会让你摆脱麻烦。 以上来自于谷歌翻译 以下为原文 Hi I hthink Webpack is for ISE only, not the EDK, I think EDK has up to a month to 'evaluate it' before you must register, which might get you out of imediate trouble. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 19:28 , Processed in 0.848142 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1339
