电子发烧友论坛|
我从Xilinx网站下载并安装了ISE Webpack for Linux。
它安装没有问题,我能够使用它的一些功能。 但是,每次启动该程序时,它都会告诉我没有许可证,并告诉我当我单击“确定”时许可管理器将启动。 但是当我点击OK时,没有任何反应。 我还尝试通过执行以下操作启动许可证管理器:帮助 - >获取许可证密钥和帮助 - >管理许可证,但在这两种情况下,一切都没有发生。 当我使用该程序时,我能够进行综合并执行模拟,但是当它尝试实现我的设计(地点和路线等,......)时,会出现一条错误消息,告诉我没有找到许可证文件。 我还能做些什么来让许可证管理器出现/获得Webpack版本的许可证? 以上来自于谷歌翻译 以下为原文 I downloaded and installed ISE Webpack for Linux from Xilinx website. It installed without problems, and I am able to use some of its functionalities. However, every time I launch the program, it tells me there is no license and tells me that the license manager is going to start when I click "OK". But when I click OK, nothing happens. I also tried launching the license manager by doing: Help -> Obtain a license Key and Help -> Manage License, but in both cases, nothing at all happens. When I use the program, I am able to do synthesis and perform simulations, but when it tries implementing my design (place&route, etc, ...) an error message appears telling me no license file was found. What else can I do to get the license manager to appear/ get a license for the Webpack edition ? |
3个回答
嗨,
将环境变量XILINXD_LICENSE_FILE设置为许可证文件的位置。 例如: setenv XILINXD_LICENSE_FILE /opt/Xilinx/Xilinx.lic 谢谢。 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, set the environmental variable XILINXD_LICENSE_FILE to the location of license file. for example: setenv XILINXD_LICENSE_FILE /opt/Xilinx/Xilinx.lic Thanks. -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
要获得许可证,许可证管理器(XLCM)将带您到www.xilinx.com getlicense。
向注册的任何人(注册帐户免费)授予webPACK权利。 生成许可证后,请按照上一篇文章中的说明进行操作。 以上来自于谷歌翻译 以下为原文 To get a license, the license manager (XLCM) will take you to www.xilinx.comgetlicense. A webPACK entitlement is granted to anyone who is registered (registering an account is free). Once you generate the License, follow the instructions from the previous post. |
但我不使用许可证文件。
我从我的学校使用web指针许可证,例如: abcde@someAddress.dot.com 我在哪里输入? 我遇到了同样的问题:最新的Xilinx ISE 14.7几乎成功安装在最新的Ubuntu 14.04上(除了USB驱动程序无法安装),但是当我尝试获得许可证或打开许可证管理器时,没有任何反应。 与先前用户描述的症状相同。 如何输入Web地址指针作为许可证? 以上来自于谷歌翻译 以下为原文 But I do not use license file. I use web pointer to licence, from my school, for example: abcde@someAddress.dot.com Where do I input that? I have the same problem: latest Xilinx ISE 14.7 almost succesfuly installs on latest Ubuntu 14.04 (with exception of USB drivers failing to install), but when I try to get license or open license manager, nothing happens. Same symptoms as described by previous user. How do I input web address pointer as a license? |
只有小组成员才能发言,加入小组>>
3115 浏览 7 评论
3405 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2870 浏览 9 评论
3961 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3055 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1324浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1166浏览 1评论
/9
GMT+8, 2025-12-1 10:52 , Processed in 0.692053 second(s), Total 72, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1176
