嗨,
如果pblock_a中有一些BRAM,但是没有使用它们,那么其他模块可以使用这些BRAM吗? 谢谢, 以上来自于谷歌翻译 以下为原文 Hi, If there are some BRAMs in pblock_a, but they are not used, so other modules can use these BRAMs? Thanks, |
2个回答
@ araongao2015
是的,除非您的pblock设置了EXCLUDE_PLACEMENT属性。 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug912-vivado-properties.pdf#page=200 pblock默认禁用此属性。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @araongao2015 Yes, unless your pblock has EXCLUDE_PLACEMENT property set on it. https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug912-vivado-properties.pdf#page=200 This property is disabled by default for pblock. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------View solution in original post |
@ araongao2015
是的,除非您的pblock设置了EXCLUDE_PLACEMENT属性。 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug912-vivado-properties.pdf#page=200 pblock默认禁用此属性。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @araongao2015 Yes, unless your pblock has EXCLUDE_PLACEMENT property set on it. https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug912-vivado-properties.pdf#page=200 This property is disabled by default for pblock. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2215 浏览 7 评论
2640 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2119 浏览 9 评论
3188 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2243 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
491浏览 1评论
1570浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2217浏览 0评论
543浏览 0评论
1704浏览 0评论
GMT+8, 2024-6-26 17:13 , Processed in 1.406879 second(s), Total 51, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
