电子发烧友论坛|
我刚刚在我的电脑上运行了SPINFamily eval软件,可以用它来控制我的电机。但是,我刚进入寄存器映射将步进模式从1/128更改为完整步骤。事实证明,无论我写什么价值,当我读回它时,它仍然设置为1/128。我已经更改了寄存器映射中的其他值,例如OCD和失速阈值,并且可以毫无问题地设置这些值。有没有人见过这个?
我在一两个星期前下载了这个软件,但是无法让IBUUI工作(它只是一直崩溃)。但是这个更新程序应该与评估软件如何设置注册有关,对吧? #l6470 #eval #step-mode 以上来自于谷歌翻译 以下为原文 I just got the SPINFamily eval software running on my PC, and can control my motor with it. However, I just went into the Register Map to change the step mode from 1/128 to full step. It turns out that no matter what value I write, when I read it back it is still set to 1/128. I have changed other values in the Register Map, such as the OCD and stall thresholds, and those values can be set without problems. Has anyone else seen this? I downloaded the software just a week or two ago, but haven't been able to get the IBUUI to work (it just crashes all of the time). But this updater should have anything to do with how the evaluation software sets registers, right? #l6470 #eval #step-mode |
1个回答
这是我的IBUUI更新程序所做的...
(无法弄清楚如何使用Image Uploader上传图像,所以......) DFUSeConsole.exe - 应用程序错误 应用程序无法正确启动(0xc0150002)。单击“确定”关闭应用程序。 这种情况发生在弹出窗口“更新固件......不要重新插入或重置电路板!!!”之后。 当我关闭消息时,它会说''更新无法完成。您当前的固件版本不支持DFU。请通过JTAG程序员更新您的电路板。'' 以上来自于谷歌翻译 以下为原文 Here is what my IBUUI updater does... (couldn't figure out how to upload an image with the Image Uploader, so...) DFUSeConsole.exe - Application Error The application was unable to start correctly (0xc0150002). Click OK to close the application. This happens right after the popup that says ''Updating firmware... DO NOT UNPLUG OR RESET THE BOARD!!!''. When I close the message, it then says ''The update cannot be completed. Your current firmware version do not support DFU. Please, update your board through a JTAG programmer.'' |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1447 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1494 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3641 浏览 1 评论
3834 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2454 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
658浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
744浏览 5评论
/9
GMT+8, 2025-12-1 19:19 , Processed in 1.090761 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3786
