嗨,
我正在尝试使用STEVAL-PCC009V2& EVAL6470H板使用SPIN 家庭评估工具(3.2版) 但是当我尝试连接到主板时,我收到以下错误: 我已设法在以下位置找到以下hex文件: C: Program Files(x86) STMicroelectronics SPINFamily评估工具3.2 Firmware 我尝试使用Keil uVision将下面的hex文件下载到主板上,但是我在Build Output中收到以下错误。 应该注意的是,我能够使用旧版本的SPINFamily评估工具。 如果有人对此问题有任何解决方案或者有评估工具第3版的链接,我将不胜感激。 亲切的问候, 欧内斯特库克 #dspin#pcc009v2-eval6470h-spinfamily #dspin-gui#powerstep01#keil-uvision 以上来自于谷歌翻译 以下为原文 Hi, I am trying to use the STEVAL-PCC009V2 & EVAL6470H boards using the SPIN Family Evaluation Tool (Version 3.2) However when I try to connect to the board I get the following error: I have managed to locate the below hex file at the following location: C:Program Files (x86)STMicroelectronicsSPINFamily Evaluation Tool 3.2Firmware I have tried to download the hex file below onto the board using Keil uVision but I am getting the following error in the Build Output. It should be noted that I was able get older versions of the SPINFamily Evaluation Tool to work. If anyone has any solutions to this problem or has a link to Version 3 of the Evaluation Tool I would greatly appreciate it. Kind Regards, Ernest Cooke #dspin #pcc009v2-eval6470h-spinfamily #dspin-gui #powerstep01 #keil-uvision |
4个回答
欧内斯特你好,
我没有uVision的专业知识,但你可以尝试使用你可以在SPINFamily文件夹中找到的'IBUUI Updater'工具更新PCC009V2板。 如果此程序不可用(它是基于固件的,我不知道您是否尝试通过uVision更新固件会损坏闪存)并且您有一个ST-LINK,您可以使用STM32 ST-LINK Utility来编写.hex文件进入MCU。 以上来自于谷歌翻译 以下为原文 Hello Ernest, I have no expertise in uVision, but you can try update the PCC009V2 board using the 'IBUUI Updater' tool you can fin in the SPINFamily folder. If this procedure is not available (it is firmware based, I don't know if your attempt to update the firmware through uVision corrupted the flash) and you have a ST-LINK, you can use the STM32 ST-LINK Utility to write the .hex file into the MCU. |
嗨恩里科,
非常感谢您的回复! 我尝试使用?IBUUI更新程序更新主板?工具,我完成了前面三个步骤,如下所示。但是,程序在进入下一阶段时会崩溃(切换到DFU模式),并且在更新电路板时不会再进一步。 IBUUI Board Updater - 坚持'切换到DFU模式' 然后我尝试通过ST-LINK Utility更新代码。但是我无法连接到电路板。我收到了下面显示的错误。 STM32 ST-LINK?连接到目标 STM32 ST-LINK?设置 通过KeilμVision更新固件并没有损坏STEVAL板上的闪存,因为我仍然可以下载旧版本的hex文件并使用旧版本的SPINFamily评估工具。 以上来自于谷歌翻译 以下为原文 Hi Enrico, Thank you very much for your response! I tried to update the board using the ?IBUUI Updater? tool and I got through the first three steps as shown below. However, the program crashes when it gets to the next stage (Switch to DFU mode) and it doesn?t go any further in updating the board. IBUUI Board Updater - Stuck at 'Switch to DFU mode' I then tried to update the code through the ST-LINK Utility. However I was unable to connect to the board. I got the errors shown below. STM32 ST-LINK ? Connect to the target STM32 ST-LINK ? Settings Updating the firmware through Keil µVision has not corrupted the flash on the STEVAL board because I can still download the older version of the hex file and use the older version of the SPINFamily Evaluation Tool. |
嗨欧内斯特,
PCC009V2本身不是STLINK!您应该将STLINK编程器连接到电路板的20极连接器。您也可以使用Nucleo板作为编程器,但在这种情况下,您必须自己连接SWD线。 也许这是你尝试过的方法,但我在Keil网站上发现了这个: http://www.keil.com/support/man/docs/uv4/uv4_fl_hexdownload.htm 以上来自于谷歌翻译 以下为原文 Hi Ernest, The PCC009V2 is not a STLINK itself! You should connect a STLINK programmer to the 20 poles connector of the board. You can also use a Nucleo board as programmer, but in this case you have to wire the SWD lines by yourself. Maybe it is the same method you already tried, but I found this on Keil website: http://www.keil.com/support/man/docs/uv4/uv4_fl_hexdownload.htm |
很高兴知道您已准备好使用SPINFamily工具。
问候 恩里科 以上来自于谷歌翻译 以下为原文 Glad to know you are ready to work with the SPINFamily tool. Regards Enrico |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2632 浏览 1 评论
3208 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1783 浏览 1 评论
3607 浏览 6 评论
5987 浏览 21 评论
939浏览 4评论
1315浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
582浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1302浏览 3评论
1357浏览 3评论
GMT+8, 2024-11-22 03:07 , Processed in 2.281161 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
