电子发烧友论坛|
你好,
我正在使用STM32F051C,FOC 4.3,无传感器,1分流器来启动电机。在斜坡阶段,电机可以旋转,但听到连续的噪音。大约20-30秒后,电机停止运转,噪音继续。 有关此问题的任何建议吗? 谢谢。 #sensorless #bldc 以上来自于谷歌翻译 以下为原文 Hi There, I'm bringing up motor using STM32F051C, FOC 4.3, sensorless, 1 shunt. In ramp stage, the motor can spin, but hear continuous noise. After about 20-30 sec, the motor stopped and noise continues. Any suggestions for this issue? Thanks. #sensorless #bldc |
2个回答
我们假设一些事情:
坡道中的总和持续时间超过30秒 您继续听到的噪音来自电机,而不是任何其他电路 您的电机未装载。 如果您在开始时没有经历过良好的电机对准,则磁场的推进可能与磁性元件不能很好地协调。在较低的速度下,协调可能足够接近,但随着斜坡变化,差异变大。 或者,与电机可用的电流量相比,斜坡的斜率太陡。您可以减小斜坡斜率,也可以添加更多电流。 祝你的设计好运 以上来自于谷歌翻译 以下为原文 Let's assume a couple things: The summed duration in your ramp is longer than 30 seconds The noise you continue to hear comes from the motor and not from any of the other circuitry Your motor is not loaded. If you have not experienced a good alignment of the motor at the beginning, it is possible that the advancement of the field is not well coordinated with the magnetics. The coordination may be close enough at the lower speeds, but as you ramp the difference gets larger. Alternately, the slope of your ramp is too steep compared with the amount of current available to the motor. You can either reduce the ramp slope or you can add more current. Best of luck with your deisgn |
嗨Blauser,谢谢你的回复。
我试图增加电流并减小斜坡斜率,但没有帮助。 启用开环后,电机可以平稳旋转。下一步的任何建议或文件? 我很确定硬件没有问题,有人让它运行过。 以上来自于谷歌翻译 以下为原文 Hi Blauser, thanks for kindly reply. I tried to increase the current and decreased the ramp slope, but no help. After enabled open loop, motor can spin smoothly. Any suggestions or documents for next step? I'm pretty sure hardware don't have issue, someone made it run before. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1465 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1518 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3664 浏览 1 评论
3856 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2475 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
745浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
678浏览 5评论
723浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
962浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
763浏览 5评论
/9
GMT+8, 2025-12-9 07:59 , Processed in 0.582289 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
720
