电子发烧友论坛|
大家好,
我是Tom,我是ST社区的网! 我有X-Nucleo IHM07M1和Nucleo F302R8开发板试图运行STM FOC SDK 4.3库。我有配备了套件的Bull Run电机,我设法安装并且运行良好,我还有另一个爱好大小的电机,所有设置和运行我想要的。 然而,我也有一个较小的2极(R = 14欧姆,L = 4.6 mH),我想通过无传感器FOC运行。但是,一旦我输入新参数,它就会按照启动顺序进行调整,但不会切换到FOC控件。给出速度反馈错误。我已经尝试了常见问题解答中提到的所有内容来解决此问题(第16页),但它仍然无法正常运行。 正如第16页所建议的那样,我减少了G2参数,但是一旦超过某个点(大约800),它就会加速到完全加速并产生启动错误。 同样如第16页所示,我的启动验证速度约为40%到90%的应用程序速度,但仍无法正常启动。 我尽可能多地尝试过,但我仍然不知道如何让它发挥作用。 提前致谢, 汤姆 #foc 以上来自于谷歌翻译 以下为原文 Hi All, Im Tom, Im net to the ST Community! I have the X-Nucleo IHM07M1 and the Nucleo F302R8 dev boards trying to run the STM FOC SDK 4.3 library. I have the Bull Running motor which came with the kit which I have managed to set-up and is running well, I also have another hobby sized motor all set up and running as I would like. However I also have a smaller 2 pole, (R = 14 Ohm, L = 4.6 mH) which I would like to run also through the sensorless FOC. However, once I put in the new parameters it spools up, as per the startup sequence, but does not swap over to the FOC control. Giving Speed Feedback errors. I have tried everything as mentioned in the FAQ to remedy this (page 16) yet it still doesnt run properly. As suggested on page 16 I reduce the G2 parameter, but once it gets beyond a certain point (about 800) it then speeds up to the full ramp up speed and gives a Start up error. Also as suggested on page 16, I have the startup verification speed at about 40% to 90% application speed and it still unable to start up properly. I have tried as much as possible and still I have no idea how to make it work. Thanks in advance, Tom #foc |
1个回答
你好汤姆,
速度反馈错误意味着系统过早地从开环切换到闭环,或者由于某些原因,一旦进入闭环模式,它就会失去控制。 如果您还没有这样做,请尝试尽可能减慢加速阶段并启用“Rev-up to FOC切换”。 以上来自于谷歌翻译 以下为原文 Hi Tom, The Speed Feedback error implies the system switched from open to closed loop too early or, for some reasons, it loses the control as soon as it enters the closed loop mode. If you have not already done so, try slowing down the ramp-up phase as much as possible and enables the 'Rev-up to FOC switch-over'. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1464 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1517 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3662 浏览 1 评论
3855 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2474 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
742浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
674浏览 5评论
722浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
961浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
761浏览 5评论
/9
GMT+8, 2025-12-8 16:17 , Processed in 0.528384 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4183
