电子发烧友论坛|
有时使用 DMA 激活某些外设会以导致外设无法工作的方式生成代码。
当 MX_DMA_Init 放置在所需的外设 MX 启动之后时,问题就出现了。解决方案是强制 MX_DMA_Init 在 MX GPIO 启动后立即保留。 每次从 MX 生成代码来处理这个简单的操作后,这都会对我造成影响。这可能会导致新用户浪费大量时间来调试他们感染了这个问题的代码。现在我在使用 SAI2 和 DMA 时遇到了这个问题。我也遇到过 I2C 的这个问题。 实际问题(此代码阻止 SAI2 工作): 虽然重现这个错误可能很难,因为它并不总是发生。也许您必须在没有 DMA 生成代码的情况下初始化 periph,然后再次激活它的 DMA。或者一些不寻常的东西会产生这个错误。 |
3个回答
When DMA is used, the MX_DMA_Init shall always be called before any other HAL_***_Init (where *** is any peripheral with a HW dependency on DMA init code). A regression was detected in the previous STM32CubeMX version 6.3.0 (STM32CubeIDE Version: 1.7.0 ) generating a wrong order of initialization functions. This issue was fixed in the latest STM32CubeMX version 6.4.0. Thus, newly created project with this version will generate the correct initialization functions order. Because the calling order is saved into the ioc file, the misplacement call to MX_DMA_Init() remains the same when trying to migrate automatically an old project from a buggy old version to the fixed version. The order stays the same and the generated code will be unfunctional. For any old ioc file created by any STM32CubeMX version up to 6.3.0 included, hereafter some steps to overcome this misbehavior:
Many thanks for posting this. It saved my sanity after a couple of frustrating days trying to get DMA working for the LPUART and the ADCs.
There are many posts on stackoverflow etc. saying that the DMA must be initialised before the thing that uses it, e.g. ADCs. I had moved the DMA initialisation to position 3 in the start up order (after GPIO and SystemClock_Config) but DMA didn't work. When I moved it to position 2 as shown above, DMA worked. So there must be some interaction between the DMA and the SystemClock_Config initialisation that is preventing the DMA from running correctly. tldr: Make sure the order is:
I have just generated code with this IDE
STM32CubeIDE Version: 1.8.0 Build: 11526_20211125_0815 (UTC) OS: Linux, v.5.13.0-28-generic, x86_64 / gtk 3.24.20, WebKit 2.34.4 Java version: 11.0.11 CubeMX Version: 6.4.0-RC4 Build: 20211122-2105 (UTC) Still: Wrong code. WTF ST?
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1447 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1494 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3641 浏览 1 评论
3834 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2454 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
658浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
744浏览 5评论
/9
GMT+8, 2025-12-1 18:38 , Processed in 0.442959 second(s), Total 46, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
529
