我有一个intel miniPC NUC7i3DNHE,我想通过edp接口连接LG平板显示器(LP156WF6-SPA1,这是在官方推荐列表中,http://compatibleproducts.intel.com/ProductDetails?EPMID = 122498)。
问题1:我使用以下行顺序连接它们: NUC eDP线订购LG LP156WF6-SPA1订购 connectjion行顺序 但是按照这个顺序,当我打开NUC电源时,平板显示器没有响应。 然后我发现eDP_pin32(BL_ENABLE)和eDP_pin33(BL_PWM_DIM)处于低电平(0V),因此我将LCD_pin22 / 23连接到eDP_pin25 / 26(高电平3.3V),然后再次打开NUC电源。 此时,平板显示器的背光正常工作,但显示器仍无信号。 所以我希望有人告诉我问题出在哪里? 问题2:为什么我的NUC bios项目少于NUC TPS? 因为我不能让平板显示器正常工作,我认为bios设置可能有问题。 但是只有2项关于平板显示器的内容 - >设备 - >视频。(右图) 在TPS,第24/25页,有5个项目。 我猜也许bios会自动隐藏相关设置,因为NUC无法识别显示。 但是我怎么能让NUC认出LP156WF6-SPA1? LP156WF6-SPA1在官方推荐列表中,为什么bios无法识别它? 以上来自于谷歌翻译 以下为原文 I have a intel miniPC NUC7i3DNHE, and I want to connect a LG Flat panel display through edp interface(LP156WF6-SPA1,which Is in the official recommendation list, http://compatibleproducts.intel.com/ProductDetails?EPMID=122498 ) . Question 1: I connect them with the following line order: NUC eDP line order LG LP156WF6-SPA1 line order connectjion line order but with this order, the flat panel display is no response when i power on the NUC. Then I find the eDP_pin32(BL_ENABLE) and eDP_pin33(BL_PWM_DIM) are in the low level(0V), so I connect LCD_pin22/23 with eDP_pin25/26(high level 3.3V), and power on the NUC again. At this time, backlight of the flat panel display is work, but the display is still no signal. so I hope someone tells me where the problem is? Question 2: why my NUC bios items are less than the NUC TPS? Because I cann't let the flat panel display work properly, I think maybe something wrong with the bios setting. But only 2 items about flat panel display in the bios-->Devices-->Video.(right part of the pic) in the TPS, page 24/25, there are 5 items. I guess Maybe the bios hides the relevant settings automatically, becaues NUC failed to recognize display. But how can i let the NUC recognize LP156WF6-SPA1? LP156WF6-SPA1 Is in the official recommendation list, why bios cann't recognize it? |
4个回答
Hellonemoxf,
感谢您的发表。 您是否了解此英特尔®NUC的规格变更? 见下文: 第iii页:https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC7i3DN_TechProdSpec.pdf 您能否帮我们确认一些有关您系统的信息? 这有助于我们回答您的所有问题: 通过私人消息提供您的英特尔®NUC的SAnumber。 我很快就会给你发一条消息。 提供您的下载英特尔®系统支持实用程序Windows *报告。 要附加文件,“附加”选项将显示在响应框的右下角。 艾米C. 英特尔客户支持技术人员 根据与英特尔公司的合同 以上来自于谷歌翻译 以下为原文 Hello nemoxf, Thank you for posting. Are you aware of the specification change for this Intel® NUC? See below: Page iii: https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC7i3DN_TechProdSpec.pdf Can you please help us to confirm some information regarding your system? This will help us to answer all your questions:
To attach a file, the "attach" option will appear in the bottom right corner of the response box. Amy C Intel Customer Support Technician Under Contract to Intel Corporation |
嗨,艾米C.
谢谢你的提醒。 我也注意到澄清1,我实际用AVO仪表测量了这些引脚,发现实线顺序(绿色)正好相反 以上来自于谷歌翻译 以下为原文 Hi Amy C Thanks for your reminder. I also noticed the clarification 1, and i Actually measured these pins by an AVO meter,and found that the real line order (green) is just the opposite |
拜托,让我仔细检查一下。 艾米C. 英特尔客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Please, let me double check this. Amy C Intel Customer Support Technician Under Contract to Intel Corporation |
只有小组成员才能发言,加入小组>>
382浏览 0评论
GMT+8, 2024-9-30 11:29 , Processed in 0.729333 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
