电子发烧友论坛|
嗨,
我试图让lsm303c在INT_XL引脚上输出“低电平有效”中断。 这是我的初始代码: void LSM303C_AccInit(void) { uint8_t result = 0; ACCELERO_IO_Write(LSM303C_CTRL_REG1_A,0b00100101); //禁用y轴以避免mg ACCELERO_IO_Write(LSM303C_CTRL_REG2_A,0b00000000); ACCELERO_IO_Write(LSM303C_CTRL_REG3_A,0b00001000); ACCELERO_IO_Write(LSM303C_CTRL_REG4_A,0b00000000); ACCELERO_IO_Write(LSM303C_CTRL_REG5_A,0b00000011); //中断低电平有效,开漏 ACCELERO_IO_Write(LSM303C_FIFO_CTRL,0b01000000); //流模式 ACCELERO_IO_Write(LSM303C_IG_CFG1_A,0b11100010); // y中断禁用 ACCELERO_IO_Write(LSM303C_IG_THS_X1_A,5); ACCELERO_IO_Write(LSM303C_IG_THS_Y1_A,5); ACCELERO_IO_Write(LSM303C_IG_THS_Z1_A,5); ACCELERO_IO_Write(LSM303C_IG_DUR1_A,0b10000001); //中断延迟 } 嵌入式控制器的引脚配置为弱上拉输入。 示波器显示出对加速的良好中断反应,但不是我配置的:没有中断时INT_XL为低电平,但一旦检测到加速度,信号就会变为高电平约40ms然后再次回到低电平状态。 我究竟做错了什么? 谢谢, 吉尔 以上来自于谷歌翻译 以下为原文 Hi, I am trying to get lsm303c output an "active low" interrupt on pin INT_XL. here is my init code: void LSM303C_AccInit(void) { uint8_t result = 0; ACCELERO_IO_Write(LSM303C_CTRL_REG1_A, 0b00100101); // disable y axis to avoid mg ACCELERO_IO_Write(LSM303C_CTRL_REG2_A, 0b00000000); ACCELERO_IO_Write(LSM303C_CTRL_REG3_A, 0b00001000); ACCELERO_IO_Write(LSM303C_CTRL_REG4_A, 0b00000000); ACCELERO_IO_Write(LSM303C_CTRL_REG5_A, 0b00000011); //interrupt active low, open-drain ACCELERO_IO_Write(LSM303C_FIFO_CTRL, 0b01000000); //stream mode, ACCELERO_IO_Write(LSM303C_IG_CFG1_A, 0b11100010); //y interrupt disabled ACCELERO_IO_Write(LSM303C_IG_THS_X1_A, 5); ACCELERO_IO_Write(LSM303C_IG_THS_Y1_A, 5); ACCELERO_IO_Write(LSM303C_IG_THS_Z1_A, 5); ACCELERO_IO_Write(LSM303C_IG_DUR1_A, 0b10000001); //interrupt delay } The embedded controller's pin is configured as input with weak pull up. The oscilloscope shows a good interrupt reaction to acceleration, but not as i configured it: the INT_XL is low when no interrupt, but as soon as there is acceleration detected, the signal goes high for about 40ms and then goes back to low again forever. What am i doing wrong? Thanks, Gil |
1个回答
以下配置不正确:
ACCELERO_IO_Write(LSM303C_IG_CFG1_A,0b11100010); // y中断禁用 如果需要AND组合,请将AOI位设置为1;如果需要OR,请将其设置为0并设置 6D位为0。 以上来自于谷歌翻译 以下为原文 Following configuration is not correct: ACCELERO_IO_Write(LSM303C_IG_CFG1_A, 0b11100010); //y interrupt disabled Please set the AOI bit to 1 if you want AND combination or to 0 if you want OR and set the 6D bit to 0. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 09:19 , Processed in 1.198978 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2460
