我需要帮助来配置中断,特别是6d方向中断。
我根据需要在任何轴上工作轻触中断,但我有时也需要配置为仅在从z-positive锥体转换到该锥体的过渡中断。 我在LSM6DS0数据表中找不到任何解释,也没有任何应用说明。我在这里看到LSM6DS3的应用笔记: http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00157511.pdf 但这对LSM6DS0没有帮助 还要注意,我在LSM303D部件上都有这两个中断。 对于LSM6DS0上的两个中断,我配置为10-Hz和2-g。 对于任何轴上的轻触,我设置: INT_GEN_CFG_XL = 0x2A INT_GEN_THS_xyz_XL = 8 INT_GEN_DUR_XL = 0x81 以上工作可以在任何轴上产生轻触。 对于z轴上的方向中断,我尝试了许多不同的THS和DUR值,许多不同的排列,INT_GEN_CFG_XL为0xD0,0xE0,依此类推。 任何提示将不胜感激。 #lsm6ds0-6d运动中断 以上来自于谷歌翻译 以下为原文 I need help to configure the interrupt, specifically for a 6d orientation interrupt. I have working as needed a light touch interrupt on any axis, but I also need sometimes to configure to interrupt only on a transition from out of the cone of z-positive then into that cone. I cannot find any explanation in the LSM6DS0 data sheet, nor any application note. I do see app note for LSM6DS3 here: http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00157511.pdf But that does not help for this LSM6DS0 Also to note that I have both of these interrupts working on a LSM303D part. For both interrupts on LSM6DS0, I configure for 10-Hz and 2-g. For light touch on any axis, I set this: INT_GEN_CFG_XL = 0x2A INT_GEN_THS_xyz_XL = 8 INT_GEN_DUR_XL = 0x81 The above works to generate light touch on any axis. For orientation interrupt on z-axis, I've tried many different THS and DUR values, many different permutations with INT_GEN_CFG_XL as 0xD0, 0xE0, and so on. Any hints would be greatly appreciated. #lsm6ds0-6d-movement-interrupt |
1个回答
好吧,LSM6DS0 6d工作就像我需要让它工作(就像我在LSM303D上工作一样) - 我发现我自己的错误(错误地,总是用轻触配置覆盖6d中断配置)下面。
以上来自于谷歌翻译 以下为原文 Ok, the LSM6DS0 6d is working like I needed to get it working (and like I had it working on the LSM303D) - I found my own bug (erroneously, always overwriting the 6d interrupt configuration with the light touch configuration) just after I posted the below. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2732 浏览 1 评论
3241 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1810 浏览 1 评论
3650 浏览 6 评论
6038 浏览 21 评论
1339浏览 4评论
201浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
350浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
443浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
274浏览 2评论
GMT+8, 2024-12-23 18:32 , Processed in 1.072467 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
