你好,
我想在我的产品中使用CY8C4A25。 经销商说,它还没有生产,建议我使用CY8C4145LQI-PS433,这是库存(据推测,仍然检查交货时间)。 我想使用PSoC创建者和CY8CKIT-048 CE211301PiRyMyTySoG感测例子,CY8C4145LQI-PS433,但是当我打开项目,并尝试改变设备(Project & Gt;Device Selector)时,这个设备没有列出。我已经尝试了PSoC 4.2和3.3版本。 如何做到这一点?哪个PSoC创建者要使用? 基于CY8C4145LQI-PS433,设计了基于CE211301PiRyMyTyg传感实例的设计,并将其迁移到CY8C4A25/CY8C4A45。 -谢谢,汤姆 以上来自于百度翻译 以下为原文 Hi, I want to use CY8C4A25 in my product. Distributor say it is not in production yet, suggest I use CY8C4145LQI-PS433, which is in stock (supposedly, still checking the lead time). I want to use PSoC creator and CY8CKIT-048 CE211301_PIR_Motion_Sensing example with CY8C4145LQI-PS433, but when I open the project, and try to change the device (Project > Device Selector), this device is not listed. I've tried both PSoC 4.2 and 3.3 version. How to do this?Which PSoC creator to use? I want to make my design based on CE211301_PIR_Motion_Sensing example, with CY8C4145LQI-PS433, and later migrate to CY8C4A25 / CY8C4A45 . -- Thanks, Tom |
3个回答
请从这个链接安装原型工具包完整安装:
HTTP://www. CyPress .COM/DICONTION/Debug -KITSBBOARDS/CY8CKIT-147PSOC-4100PSS原型套件 然后检查PSoC创建程序4.2。 以上来自于百度翻译 以下为原文 Please install Prototyping kit complete setup from this link: http://www.cypress.com/documentation/development-kit***oards/cy8ckit-147-psoc-4100ps-prototyping-kit Then check the PSoC Creator4.2. |
转到“工具& GT;发现新设备”选项卡在PSoC创建者4.2,并安装设备包,如所附屏幕截图中提到的。
现在创建一个新的项目,当你做“& LT设备选择器& GT”时,你应该看到如下所示的设备: 点击OK,然后您可以像往常一样继续您的项目。 如果这个答案是有用的,请告诉我。 当做, 德黑拉杰 以上来自于百度翻译 以下为原文 Go over to "Tools > Find New Devices" tab in PSoC Creator 4.2 and install the device pack as mentioned in the screenshot attached. Now create a New Project and when you do the " Click on OK and then you can continue with your project as usual. If this answer was helpful, do let me know. Regards, Dheeraj |
谢谢你们两个!
我不确定是哪一个建议在我试过这两个方法的时候,仍然没有得到设备,然后重新安装了工具包,重新启动了PSoC creator,然后是VoILA,部分就在那里。 谢谢! —— 汤姆 以上来自于百度翻译 以下为原文 Thank you both! I'm not sure which suggestion did the trick as I tried both, still didn't get the device, then re-installed the kit and restarted the PSoC creator, then voila, the part is there . Thanks! -- Tom |
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7386 浏览 0 评论
2490 浏览 1 评论
2183 浏览 1 评论
4046 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2093 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7874浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6436浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
760浏览 2评论
735浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8292浏览 2评论
/9
GMT+8, 2025-12-14 20:39 , Processed in 0.776584 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3206
