扫一扫,分享给好友
基于Spartan6LX16ftg256,我在XPS平台的以太网设计项目中添加Axi 10/100 Ethernet Lite(或XPS 10/100 Ethernet Lite)和RMII2Mii IP核,生成Netlist步骤成功,但Generate BitStream失败,有一些东西
在13.2 13.4和14.3 XPS平台中出错。我在13.2,13.4和14.3中尝试了,都失败了,我该如何解决? 错误:NgdBuild:770 - 网络'Ethernet_10_100_PHY_rx_clk'上的IBUF'PHY_tx_clk_IBUF'和IBUF'PHY_rx_clk_IBUF'串联排列。 相同方向的缓冲器不能串联.ERROR:NgdBuild:462 - 输入焊盘网'Ethernet_10_100_PHY_rx_clk'驱动多个缓冲器:错误:NgdBuild:924 - 输入焊盘网'Ethernet_10_100_PHY_rx_clk'驱动非缓冲原语:错误:Xflow - 程序ngdbuild返回错误代码2.中止流程执行... 以上来自于谷歌翻译 以下为原文 base on Spartan6LX16ftg256 ,I add Axi 10/100 Ethernet Lite (or XPS 10/100 Ethernet Lite) and RMII2Mii IP core in my Ethernet Design Project in XPS Platform,Generate Netlist step is success,but Generate BitStream is fail,there is something of error in the 13.2 13.4 and 14.3 XPS platform.I try it in 13.2,13.4 and 14.3,all is failed,How can I solve it? ERROR:NgdBuild:770 - IBUF 'PHY_tx_clk_IBUF' and IBUF 'PHY_rx_clk_IBUF' on net 'Ethernet_10_100_PHY_rx_clk' are lined up in series. Buffers of the same direction cannot be placed in series. ERROR:NgdBuild:462 - input pad net 'Ethernet_10_100_PHY_rx_clk' drives multiple buffers: ERROR:NgdBuild:924 - input pad net 'Ethernet_10_100_PHY_rx_clk' is driving non-buffer primitives: ERROR:Xflow - Program ngdbuild returned error code 2. Aborting flow execution... |
2个回答
嗨,
这些错误看起来很有名,并且通常由于许多原因而出现,其中一些在Xilinx AR和相关论坛帖子中有详细说明。 请交叉检查是否也适用于您的设计。 http://forums.xilinx.com/t5/Archived-ISE-issues/Error-message-Buffers-of-the-same-direction-cannot-be-placed-in/td-p/9731 http://www.xilinx.com/support/answers/34771.html http://www.xilinx.com/support/answers/6034.htm http://www.xilinx.com/support/answers/32428.htm http://www.edaboard.com/thread260179.html http://dbaspot.com/arch/253728-ngdbuild-error-multiple-drivers-driving-non-buffer-primitives.html 希望这可以帮助 问候, Vanitha。 -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, The errors look famous and generally arise due to many reasons, some of them are specified in below Xilinx ARs and related forum posts. Please cross check if they apply for your design too. http://forums.xilinx.com/t5/Archived-ISE-issues/Error-message-Buffers-of-the-same-direction-cannot-be-placed-in/td-p/9731 http://www.xilinx.com/support/answers/34771.html http://www.xilinx.com/support/answers/6034.htm http://www.xilinx.com/support/answers/32428.htm http://www.edaboard.com/thread260179.html http://dbaspot.com/arch/253728-ngdbuild-error-multiple-drivers-driving-non-buffer-primitives.html Hope this helps Regards, Vanitha. --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented View solution in original post |
嗨,
这些错误看起来很有名,并且通常由于许多原因而出现,其中一些在Xilinx AR和相关论坛帖子中有详细说明。 请交叉检查是否也适用于您的设计。 http://forums.xilinx.com/t5/Archived-ISE-issues/Error-message-Buffers-of-the-same-direction-cannot-be-placed-in/td-p/9731 http://www.xilinx.com/support/answers/34771.html http://www.xilinx.com/support/answers/6034.htm http://www.xilinx.com/support/answers/32428.htm http://www.edaboard.com/thread260179.html http://dbaspot.com/arch/253728-ngdbuild-error-multiple-drivers-driving-non-buffer-primitives.html 希望这可以帮助 问候, Vanitha。 -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 Hi, The errors look famous and generally arise due to many reasons, some of them are specified in below Xilinx ARs and related forum posts. Please cross check if they apply for your design too. http://forums.xilinx.com/t5/Archived-ISE-issues/Error-message-Buffers-of-the-same-direction-cannot-be-placed-in/td-p/9731 http://www.xilinx.com/support/answers/34771.html http://www.xilinx.com/support/answers/6034.htm http://www.xilinx.com/support/answers/32428.htm http://www.edaboard.com/thread260179.html http://dbaspot.com/arch/253728-ngdbuild-error-multiple-drivers-driving-non-buffer-primitives.html Hope this helps Regards, Vanitha. --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
只有小组成员才能发言,加入小组>>
2174 浏览 7 评论
2612 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2082 浏览 9 评论
3153 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2199 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
435浏览 1评论
1532浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2181浏览 0评论
512浏览 0评论
1652浏览 0评论
GMT+8, 2024-5-4 12:27 , Processed in 1.016030 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
