我想用我的atlys spartan-6 xc6slx45做一个hello world程序。我打开了EDK我使用BSB创建了一个新的Projet然后我用PLB互连创建了一个新的microlaze。之后我生成Bitstream,之后我导出设计(SDK
当SDK的窗口打开时,我使用C代码创建一个新的hello world项目。然后我点击了程序FPGA,但是我收到了这个错误: 程序FPGA失败。 与电路板的连接失败。 无法打开Jtag电缆。 电缆目标未连接到主机。 电路板已通电,我只使用一根USB电缆,从我的电脑连接到程序端口。我该怎么办? 以上来自于谷歌翻译 以下为原文 I want to do a hello world program with my atlys spartan-6 xc6slx45.I opened EDK I create a new Projet using BSB then I create a new microblaze using PLB interconnect.After that I generate the Bitstream,after that I export design (SDK).When the window of the SDK opened I crate a new hello world project using C code.then I clicked program FPGA but I got this error : Program FPGA failed.Connection to board failed.Failed to open Jtag cable.Cable target is not connected to the host.The board was powered on and I use only one u*** cable which is connected from my PC to the program port.What can I do ? |
1个回答
你好,1。
你真的有正确的电缆驱动器吗?2。 你有权力应用于目标板吗?3。 Nexys板的用户手册对编程有何看法?4。 据我所知(通过简要搜索Nexys板),有多个USB端口。 您确认已连接到正确的编程端口吗? 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, 1. Do you actually have the correct cable drivers? 2. Do you have power applied to the target board? 3. What does the user manual for the Nexys board say about programming? 4. From what I could tell (by briefly searching for the Nexys board), there are multiple USB ports. Have you confirmed you are connected to the correct port for programming?Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 00:48 , Processed in 0.455196 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3231
