@ottmann
这已在Vivado实施用户指南(UG904)的“常见设计错误”主题下记录:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug904-vivado-implementation.pdf#page=51
正如@ shameeraYou正确建议的那样,您可以打开精心设计或合成设计并检查LUT单元的连接。
打开合成设计后使用以下TCL命令:
show_objects -name test [get_cellsLD180_130918_i / axi_apb_bridge_0 / U0 / AXILITE_SLAVE_IF_MODULE / FSM_sequential_axi_wr_rd_cs [1] _i_2]
如果您有一个有效的连接并且该工具正在修剪它,您也可以应用DONT_TOUCH属性。
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug912-vivado-properties.pdf#page=191
FYI:HTTPS://www.xilinx.com/support/answers/70111.html
--Syed
-------------------------------------------请注意 - 请标记答案
如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------
以上来自于谷歌翻译
以下为原文
@ottmann
This has been documented in Vivado implementation user guide (UG904) under "common design error" topic:
As correctly suggested by @shameera You can open elaborated or synthesized design and check the connection of the LUT cell.
Use the following TCL command after opening synthesized design:
show_objects -name test [get_cells LD180_130918_i/axi_apb_bridge_0/U0/AXILITE_SLAVE_IF_MODULE/FSM_sequential_axi_wr_rd_cs[1]_i_2]
You can also apply DONT_TOUCH attribute if you have a valid connection and the tool is trimming it.
FYI: https://www.xilinx.com/support/answers/70111.html
--Syed
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
@ottmann
打开合成设计后使用以下TCL命令:
--Syed
以上来自于谷歌翻译
以下为原文
@ottmann
--Syed
举报
