RT-Thread Env Tool (ConEmu) Version 1.5.2
\ | / - RT - Thread Operating System / | \ 2006 - 2024 Copyright by RT-Thread team Activate Python VENV in C:\Users\Jack\Downloads\private\env-windows-v2.0.0\env-windows\tools\bin\..\..\.venv Clink v1.6.16 is available. - To apply the update, run 'clink update'. - To stop checking for updates, run 'clink set clink.autoupdate off'. - To view the release notes, visit the Releases page: https://github.com/chrisant996/clink/releases (.venv) Jack@DESKTOP-aaaaaaaa C:\Users\Jack\Downloads\private\rt-thread-master\bsp\STM32\stm32l475-atk-pandora $ scons --dist scons: Reading SConscript files ... Newlib version: 4.1.0 make distribution.... => stm32l475-atk-pandora => start dist handle => copy stm32 bsp library TypeError: join() argument must be str, bytes, or os.PathLike object, not 'NoneType': File "C:\Users\Jack\Downloads\private\rt-thread-master\bsp\stm32\stm32l475-atk-pandora\SConstruct", line 56: DoBuilding(TARGET, objs) File "C:\Users\Jack\Downloads\private\rt-thread-master\tools\building.py", line 863: EndBuilding(target, program) File "C:\Users\Jack\Downloads\private\rt-thread-master\tools\building.py", line 976: MkDist(program, BSP_ROOT, Rtt_Root, Env, project_name, project_path) File "C:\Users\Jack\Downloads\private\rt-thread-master\tools\mkdist.py", line 192: dist_handle(BSP_ROOT, dist_dir) File "C:\Users\Jack\Downloads\private\rt-thread-master\bsp\stm32\stm32l475-atk-pandora\rtconfig.py", line 218: dist_do_building(BSP_ROOT, dist_dir) File "C:\Users\Jack\Downloads\private\rt-thread-master\bsp\stm32\tools\sdk_dist.py", line 17: bsp_copy_files(os.path.join(library_path, rtconfig.BSP_LIBRARY_TYPE), File "", line 147: File "", line 152: |
1个回答
根据您提供的信息,您正在使用 RT-Thread Env Tool (ConEmu) 1.5.2 版本,并尝试使用 menuconfig 功能。遇到报错问题,我们可以按照以下步骤进行排查和解决:
1. 确保环境变量配置正确:首先检查您的环境变量是否已经正确配置。在 Windows 系统中,您需要将 Python 的安装路径添加到 PATH 环境变量中。例如,如果您的 Python 安装在 "C:Python39",则需要将 "C:Python39" 和 "C:Python39Scripts" 添加到 PATH。 2. 检查 Python 版本:RT-Thread 需要 Python 3.5 以上版本。您可以在命令行中输入 `python --version` 来检查当前的 Python 版本。如果版本不符合要求,请升级 Python。 3. 确保 RT-Thread 环境变量配置正确:在命令行中输入 `env --version`,检查 RT-Thread Env Tool 的版本。如果版本不符合要求,请下载并安装合适的版本。 4. 检查 menuconfig 脚本:在 RT-Thread 的项目目录中,找到名为 "menuconfig.py" 的 Python 脚本。确保该脚本存在且具有执行权限。 5. 运行 menuconfig:在 RT-Thread 项目目录的命令行中,输入 `python menuconfig.py` 来运行 menuconfig。如果仍然遇到报错,请查看报错信息,以便进一步排查问题。 6. 查看报错信息:根据报错信息,可能是 Python 库缺失或其他问题。根据报错信息,您可以在互联网上搜索解决方案或在 RT-Thread 社区寻求帮助。 7. 更新 RT-Thread:如果问题仍然无法解决,您可以尝试更新 RT-Thread 到最新版本,看看是否解决了问题。 通过以上步骤,您应该能够找到并解决使用 menuconfig 时遇到的问题。如果问题仍然存在,请提供更详细的报错信息,以便我们为您提供更具体的帮助。 |
只有小组成员才能发言,加入小组>>
148个成员聚集在这个小组
加入小组【Vision Board创客营连载体验】基于RA8D1-Vision Board的自动路径规划小车
831 浏览 0 评论
【Vision Board创客营连载体验】基于Vision Board的垃圾分类
893 浏览 0 评论
【Vision Board创客营连载体验】使用 Vision Board 做一个 UVC Camera
779 浏览 0 评论
【Vision Board创客营连载体验】TinyMaix进行手写数字识别
1100 浏览 0 评论
【Vision Board创客营连载体验】RA8D1-Vision Board使用7寸屏设置为RGB666大端模式模式成功显示摄像头图案
1062 浏览 0 评论
STM32F407ZGT6 spi flash片选引脚无法被拉低的原因?怎么解决?
1122浏览 2评论
移植RT-THREAD在stm32开发板上,使用rt_kprintf不能正常打印的原因是什么?怎么解决?
458浏览 2评论
stm32f103zet用rtthread studio生成带finsh的项目程序,串口输入help没有反应是为什么?
460浏览 2评论
rtthread studio已经成功编写了外部flash下载算法,程序也能下载进去但是不能进行调试怎么办?
397浏览 2评论
rt-thread 4.1.1的pin的实际引脚编号和内核引脚编号的对应关系在哪个文件里面能找到?
405浏览 2评论
GMT+8, 2024-10-21 00:16 , Processed in 0.718791 second(s), Total 84, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
