开发板:正点原子达芬奇Pro开发板FPGA Artix-7 XC7A100T
调试器:Sipeed USB-JTAG/TTL RISC-V调试器 OpenOCD报错如下: Open On-Chip Debugger 0.11.0+dev-01897-gc8fc2a168 (2022-04-01-04:46)Licensed under GNU GPL v2For bug reports, read use 'adapter speed' not 'adapter_khz'DEPRECATED! use 'adapter driver' not 'interface'Info : Using libusb driverInfo : clock speed 1000 kHzInfo : JTAG tap: riscv.cpu tap/device found: 0x1e200a6d (mfg: 0x536 (Nuclei System Technology Co Ltd), part: 0xe200, ver: 0x1)Info : TAP auto0.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto1.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto2.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto3.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto4.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto5.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto6.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto7.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto8.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto9.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto10.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto11.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto12.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto13.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto14.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto15.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto16.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto17.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto18.tap does not have valid IDCODE (idcode=0x0)Info : TAP auto19.tap does not have valid IDCODE (idcode=0x0)Warn : Unexpected idcode after end of chain: 52 0x00000000Warn : Unexpected idcode after end of chain: 84 0xfe000000Error: double-check your JTAG setup (interface, speed, ...)Error: Trying to use configured scan chain anyway...Warn : AUTO auto0.tap - use "jtag newtap auto0 tap -irlen 2 -expected-id 0x00000000"Error: auto0.tap: IR capture error; saw 0x0000 not 0x0001Warn : Bypassing JTAG setup events due to errorsError: Unsupported DTM version 14. (dtmcontrol=0xffe)Warn : target riscv.cpu examination failedInfo : starting gdb server for riscv.cpu on 3333Info : Listening on port 3333 for gdb connectionsError: Target not examined yet |
只有小组成员才能发言,加入小组>>
在软件SDK中选择不同的下载模式时,是哪个部件更改了QSPI0中寄存器的值?
703 浏览 2 评论
cmt_instret_ena的使能为什么要排除branch等指令造成流水线冲刷的情况?
848 浏览 1 评论
e203 rom启动仅仅是引导到itcm执行指令吗?flash启动就是加载指令到itcm中吗?
978 浏览 1 评论
/9
GMT+8, 2025-12-11 23:44 , Processed in 0.624128 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3824
