电子发烧友论坛|
STM32F1系列芯片的5个串口初始化方法(有的芯片引脚少,只有3个串口)
串口是我们常用的一个数据传输接口,STM32F103系列单片机共有5个串口
注意事项下面是5个串口的配置函数和收发数据函数代码: 串口1 void USART1_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE ); RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE ); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //USART1 TX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); //端口A; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //USART1 RX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入; GPIO_Init(GPIOA, &GPIO_InitStructure); //端口A; USART_InitStructure.USART_BaudRate = 9600; //波特率; USART_InitStructure.USART_WordLength = USART_WordLength_8b; //数据位8位; USART_InitStructure.USART_StopBits = USART_StopBits_1; //停止位1位; USART_InitStructure.USART_Parity = USART_Parity_No ; //无校验位; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //无硬件流控; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式; USART_Init(USART1, &USART_InitStructure);//配置串口参数; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置中断组,4位抢占优先级,4位响应优先级; NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //中断号; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //抢占优先级; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //响应优先级; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); USART_Cmd(USART1, ENABLE); //使能串口; } void USART1_Send_Byte(u8 Data) //发送一个字节; { USART_SendData(USART1,Data); while( USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET ); } void USART1_Send_String(u8 *Data) //发送字符串; { while(*Data) USART1_Send_Byte(*Data++); } void USART1_IRQHandler(void) //中断处理函数; { u8 res; if(USART_GetITStatus(USART1, USART_IT_RXNE) == SET) //判断是否发生中断; { USART_ClearFlag(USART1, USART_IT_RXNE); //清除标志位; res=USART_ReceiveData(USART1); //接收数据; USART1_Send_Byte(res); //用户自定义; } } 串口2 void USART2_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE ); RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE ); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //USART2 TX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); //端口A; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; //USART2 RX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入; GPIO_Init(GPIOA, &GPIO_InitStructure); //端口A; USART_InitStructure.USART_BaudRate = 9600; //波特率; USART_InitStructure.USART_WordLength = USART_WordLength_8b; //数据位8位; USART_InitStructure.USART_StopBits = USART_StopBits_1; //停止位1位; USART_InitStructure.USART_Parity = USART_Parity_No ; //无校验位; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件流控; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式; USART_Init(USART2, &USART_InitStructure);//配置串口参数; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置中断组,4位抢占优先级,4位响应优先级; NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn; //中断号; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //抢占优先级; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //响应优先级; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); USART_ITConfig(USART2, USART_IT_RXNE, ENABLE); USART_Cmd(USART2, ENABLE); //使能串口; } void USART2_Send_Byte(u8 Data) //发送一个字节; { USART_SendData(USART2,Data); while( USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET ); } void USART2_Send_String(u8 *Data) //发送字符串; { while(*Data) USART2_Send_Byte(*Data++); } void USART2_IRQHandler(void) //中断处理函数; { u8 res; if(USART_GetITStatus(USART2, USART_IT_RXNE) == SET) //判断是否发生中断; { USART_ClearFlag(USART2, USART_IT_RXNE); //清除标志位; res=USART_ReceiveData(USART2); //接收数据; USART2_Send_Byte(res); //用户自定义; } } 串口3 void USART3_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE ); RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE ); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //USART3 TX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); //端口B; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //USART3 RX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入; GPIO_Init(GPIOB, &GPIO_InitStructure); //端口B; USART_InitStructure.USART_BaudRate = 9600; //波特率; USART_InitStructure.USART_WordLength = USART_WordLength_8b; //数据位8位; USART_InitStructure.USART_StopBits = USART_StopBits_1; //停止位1位; USART_InitStructure.USART_Parity = USART_Parity_No ; //无校验位; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件流控; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//收发模式; USART_Init(USART3, &USART_InitStructure);//配置串口参数; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置中断组,4位抢占优先级,4位响应优先级; NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn; //中断号; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //抢占优先级; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //响应优先级; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); USART_ITConfig(USART3, USART_IT_RXNE, ENABLE); USART_Cmd(USART3, ENABLE); //使能串口; } void USART3_Send_Byte(u8 Data) //发送一个字节; { USART_SendData(USART3,Data); while( USART_GetFlagStatus(USART3, USART_FLAG_TC) == RESET ); } void USART3_Send_String(u8 *Data) //发送字符串; { while(*Data) USART3_Send_Byte(*Data++); } void USART3_IRQHandler(void) //中断处理函数; { u8 res; if(USART_GetITStatus(USART3, USART_IT_RXNE) == SET) //判断是否发生中断; { USART_ClearFlag(USART3, USART_IT_RXNE); //清除标志位; res=USART_ReceiveData(USART3); //接收数据; USART3_Send_Byte(res); //用户自定义; } } |
64脚以上的芯片才有 void UART4_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE ); RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE ); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //UART4 TX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); //端口C; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //UART4 RX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入; GPIO_Init(GPIOC, &GPIO_InitStructure); //端口C; USART_InitStructure.USART_BaudRate = 9600; //波特率; USART_InitStructure.USART_WordLength = USART_WordLength_8b; //数据位8位; USART_InitStructure.USART_StopBits = USART_StopBits_1; //停止位1位; USART_InitStructure.USART_Parity = USART_Parity_No ; //无校验位; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //无硬件流控; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式; USART_Init(UART4, &USART_InitStructure);//配置串口参数; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置中断组,4位抢占优先级,4位响应优先级; NVIC_InitStructure.NVIC_IRQChannel = UART4_IRQn; //中断号; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //抢占优先级; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //响应优先级; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); USART_ITConfig(UART4, USART_IT_RXNE, ENABLE); USART_Cmd(UART4, ENABLE); //使能串口; } void UART4_Send_Byte(u8 Data) //发送一个字节; { USART_SendData(UART4,Data); while( USART_GetFlagStatus(UART4, USART_FLAG_TC) == RESET ); } void UART4_Send_String(u8 *Data) //发送字符串; { while(*Data) UART4_Send_Byte(*Data++); } void UART4_IRQHandler(void) //中断处理函数; { u8 res; if(USART_GetITStatus(UART4, USART_IT_RXNE) == SET) //判断是否发生中断; { USART_ClearFlag(UART4, USART_IT_RXNE); //清除标志位; res=USART_ReceiveData(UART4); //接收数据; UART4_Send_Byte(res); //用户自定义; } } 64脚以上的芯片才有 void UART5_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD, ENABLE ); RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART5, ENABLE ); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; //UART5 TX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); //端口C; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //UART5 RX; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入; GPIO_Init(GPIOD, &GPIO_InitStructure); //端口D; USART_InitStructure.USART_BaudRate = 9600; //波特率; USART_InitStructure.USART_WordLength = USART_WordLength_8b; //数据位8位; USART_InitStructure.USART_StopBits = USART_StopBits_1; //停止位1位; USART_InitStructure.USART_Parity = USART_Parity_No ; //无校验位; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //无硬件流控; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式; USART_Init(UART5, &USART_InitStructure); //配置串口参数; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置中断组,4位抢占优先级,4位响应优先级; NVIC_InitStructure.NVIC_IRQChannel = UART5_IRQn; //中断号; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //抢占优先级; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //响应优先级; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); USART_ITConfig(UART5, USART_IT_RXNE, ENABLE); USART_Cmd(UART5, ENABLE); //使能串口; } void UART5_Send_Byte(u8 Data) //发送一个字节; { USART_SendData(UART5,Data); while( USART_GetFlagStatus(UART5, USART_FLAG_TC) == RESET ); } void UART5_Send_String(u8 *Data) //发送字符串; { while(*Data) UART5_Send_Byte(*Data++); } void UART5_IRQHandler(void) //中断处理函数; { u8 res; if(USART_GetITStatus(UART5, USART_IT_RXNE) == SET) //判断是否发生中断; { USART_ClearFlag(UART5, USART_IT_RXNE); //清除标志位; res=USART_ReceiveData(UART5); //接收数据; UART5_Send_Byte(res); //用户自定义; } } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4178 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3251 浏览 1 评论
2781 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2210 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
15077 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3136浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1926浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2094浏览 3评论
2004浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2201浏览 3评论
/9
GMT+8, 2025-12-8 16:17 , Processed in 0.733122 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2513
