STM32 & ARM汇编启动程序
1、STM32启动汇编文件 下面是startup_stm32f10x_hd.s汇编文件代码: Stack_Size EQU 0x00000400 ;先定义Stack_Size大小为0x00000400 AREA STACK, NOINIT, READWRITE, ALIGN=3 ;定义栈,未初始化,可读可写,堆数据段8字节边界对齐 Stack_Mem SPACE Stack_Size ;分配空间大小为Stack_Size (0x00000400) __initial_sp ; ; ; Heap_Size EQU 0x00000200 ;定义堆,未初始化,可读可写,。。 AREA HEAP, NOINIT, READWRITE, ALIGN=3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit PRESERVE8 ;命令指定当前文件保持栈的八字节对齐 THUMB ; THUMB指令集必须位于使用新语法的任何Thumb代码之前 ;向量表映射地址 AREA RESET, DATA, READONLY EXPORT __Vectors EXPORT __Vectors_End EXPORT __Vectors_Size __Vectors DCD __initial_sp ; Top of Stack DCD Reset_Handler ; Reset Handler DCD NMI_Handler ; NMI Handler DCD HardFault_Handler ; Hard Fault Handler DCD MemManage_Handler ; MPU Fault Handler DCD BusFault_Handler ; Bus Fault Handler DCD UsageFault_Handler ; Usage Fault Handler DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD SVC_Handler ; SVCall Handler DCD DebugMon_Handler ; Debug Monitor Handler DCD 0 ; Reserved DCD PendSV_Handler ; PendSV Handler DCD SysTick_Handler ; SysTick Handler ; 外部中断 DCD WWDG_IRQHandler ; Window Watchdog DCD PVD_IRQHandler ; PVD through EXTI Line detect DCD TAMPER_IRQHandler ; Tamper DCD RTC_IRQHandler ; RTC DCD FLASH_IRQHandler ; Flash DCD RCC_IRQHandler ; RCC DCD EXTI0_IRQHandler ; EXTI Line 0 DCD EXTI1_IRQHandler ; EXTI Line 1 DCD EXTI2_IRQHandler ; EXTI Line 2 DCD EXTI3_IRQHandler ; EXTI Line 3 DCD EXTI4_IRQHandler ; EXTI Line 4 DCD DMA1_Channel1_IRQHandler ; DMA1 Channel 1 DCD DMA1_Channel2_IRQHandler ; DMA1 Channel 2 DCD DMA1_Channel3_IRQHandler ; DMA1 Channel 3 DCD DMA1_Channel4_IRQHandler ; DMA1 Channel 4 DCD DMA1_Channel5_IRQHandler ; DMA1 Channel 5 DCD DMA1_Channel6_IRQHandler ; DMA1 Channel 6 DCD DMA1_Channel7_IRQHandler ; DMA1 Channel 7 DCD ADC1_2_IRQHandler ; ADC1 & ADC2 DCD USB_HP_CAN1_TX_IRQHandler ; USB High Priority or CAN1 TX DCD USB_LP_CAN1_RX0_IRQHandler ; USB Low Priority or CAN1 RX0 DCD CAN1_RX1_IRQHandler ; CAN1 RX1 DCD CAN1_SCE_IRQHandler ; CAN1 SCE DCD EXTI9_5_IRQHandler ; EXTI Line 9..5 DCD TIM1_BRK_IRQHandler ; TIM1 Break DCD TIM1_UP_IRQHandler ; TIM1 Update DCD TIM1_TRG_COM_IRQHandler ; TIM1 Trigger and Commutation DCD TIM1_CC_IRQHandler ; TIM1 Capture Compare DCD TIM2_IRQHandler ; TIM2 DCD TIM3_IRQHandler ; TIM3 DCD TIM4_IRQHandler ; TIM4 DCD I2C1_EV_IRQHandler ; I2C1 Event DCD I2C1_ER_IRQHandler ; I2C1 Error DCD I2C2_EV_IRQHandler ; I2C2 Event DCD I2C2_ER_IRQHandler ; I2C2 Error DCD SPI1_IRQHandler ; SPI1 DCD SPI2_IRQHandler ; SPI2 DCD USART1_IRQHandler ; USART1 DCD USART2_IRQHandler ; USART2 DCD USART3_IRQHandler ; USART3 DCD EXTI15_10_IRQHandler ; EXTI Line 15..10 DCD RTCAlarm_IRQHandler ; RTC Alarm through EXTI Line DCD USBWakeUp_IRQHandler ; USB Wakeup from suspend DCD TIM8_BRK_IRQHandler ; TIM8 Break DCD TIM8_UP_IRQHandler ; TIM8 Update DCD TIM8_TRG_COM_IRQHandler ; TIM8 Trigger and Commutation DCD TIM8_CC_IRQHandler ; TIM8 Capture Compare DCD ADC3_IRQHandler ; ADC3 DCD FSMC_IRQHandler ; FSMC DCD SDIO_IRQHandler ; SDIO DCD TIM5_IRQHandler ; TIM5 DCD SPI3_IRQHandler ; SPI3 DCD UART4_IRQHandler ; UART4 DCD UART5_IRQHandler ; UART5 DCD TIM6_IRQHandler ; TIM6 DCD TIM7_IRQHandler ; TIM7 DCD DMA2_Channel1_IRQHandler ; DMA2 Channel1 DCD DMA2_Channel2_IRQHandler ; DMA2 Channel2 DCD DMA2_Channel3_IRQHandler ; DMA2 Channel3 DCD DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 & Channel5 __Vectors_End __Vectors_Size EQU __Vectors_End - __Vectors ;计算向量表地址空间大小 ;定义区域代码名|.text|,代码段,只读 AREA |.text|, CODE, READONLY ; Reset handler Reset_Handler PROC EXPORT Reset_Handler [WEAK] ;此处[WEAK]表示弱定义,优先执行其他文件的定义 IMPORT __main IMPORT SystemInit LDR R0, =SystemInit BLX R0 LDR R0, =__main BX R0 ENDP ; Dummy Exception Handlers (infinite loops which can be modified) NMI_Handler PROC EXPORT NMI_Handler [WEAK] B . ENDP HardFault_Handler PROC EXPORT HardFault_Handler [WEAK] B . ENDP MemManage_Handler PROC EXPORT MemManage_Handler [WEAK] B . ENDP BusFault_Handler PROC EXPORT BusFault_Handler [WEAK] B . ENDP UsageFault_Handler PROC EXPORT UsageFault_Handler [WEAK] B . ENDP SVC_Handler PROC EXPORT SVC_Handler [WEAK] B . ENDP DebugMon_Handler PROC EXPORT DebugMon_Handler [WEAK] B . ENDP PendSV_Handler PROC EXPORT PendSV_Handler [WEAK] B . ENDP SysTick_Handler PROC EXPORT SysTick_Handler [WEAK] B . ENDP Default_Handler PROC ; 输出异常向量表标号,方便外部实现异常的具体功能,[WEAK]是弱定义的意思,如果外部定义了,优先执行外部定义,否则下面的函数定义 EXPORT WWDG_IRQHandler [WEAK] EXPORT PVD_IRQHandler [WEAK] EXPORT TAMPER_IRQHandler [WEAK] EXPORT RTC_IRQHandler [WEAK] EXPORT FLASH_IRQHandler [WEAK] EXPORT RCC_IRQHandler [WEAK] EXPORT EXTI0_IRQHandler [WEAK] EXPORT EXTI1_IRQHandler [WEAK] EXPORT EXTI2_IRQHandler [WEAK] EXPORT EXTI3_IRQHandler [WEAK] EXPORT EXTI4_IRQHandler [WEAK] EXPORT DMA1_Channel1_IRQHandler [WEAK] EXPORT DMA1_Channel2_IRQHandler [WEAK] EXPORT DMA1_Channel3_IRQHandler [WEAK] EXPORT DMA1_Channel4_IRQHandler [WEAK] EXPORT DMA1_Channel5_IRQHandler [WEAK] EXPORT DMA1_Channel6_IRQHandler [WEAK] EXPORT DMA1_Channel7_IRQHandler [WEAK] EXPORT ADC1_2_IRQHandler [WEAK] EXPORT USB_HP_CAN1_TX_IRQHandler [WEAK] EXPORT USB_LP_CAN1_RX0_IRQHandler [WEAK] EXPORT CAN1_RX1_IRQHandler [WEAK] EXPORT CAN1_SCE_IRQHandler [WEAK] EXPORT EXTI9_5_IRQHandler [WEAK] EXPORT TIM1_BRK_IRQHandler [WEAK] EXPORT TIM1_UP_IRQHandler [WEAK] EXPORT TIM1_TRG_COM_IRQHandler [WEAK] EXPORT TIM1_CC_IRQHandler [WEAK] EXPORT TIM2_IRQHandler [WEAK] EXPORT TIM3_IRQHandler [WEAK] EXPORT TIM4_IRQHandler [WEAK] EXPORT I2C1_EV_IRQHandler [WEAK] EXPORT I2C1_ER_IRQHandler [WEAK] EXPORT I2C2_EV_IRQHandler [WEAK] EXPORT I2C2_ER_IRQHandler [WEAK] EXPORT SPI1_IRQHandler [WEAK] EXPORT SPI2_IRQHandler [WEAK] EXPORT USART1_IRQHandler [WEAK] EXPORT USART2_IRQHandler [WEAK] EXPORT USART3_IRQHandler [WEAK] EXPORT EXTI15_10_IRQHandler [WEAK] EXPORT RTCAlarm_IRQHandler [WEAK] EXPORT USBWakeUp_IRQHandler [WEAK] EXPORT TIM8_BRK_IRQHandler [WEAK] EXPORT TIM8_UP_IRQHandler [WEAK] EXPORT TIM8_TRG_COM_IRQHandler [WEAK] EXPORT TIM8_CC_IRQHandler [WEAK] EXPORT ADC3_IRQHandler [WEAK] EXPORT FSMC_IRQHandler [WEAK] EXPORT SDIO_IRQHandler [WEAK] EXPORT TIM5_IRQHandler [WEAK] EXPORT SPI3_IRQHandler [WEAK] EXPORT UART4_IRQHandler [WEAK] EXPORT UART5_IRQHandler [WEAK] EXPORT TIM6_IRQHandler [WEAK] EXPORT TIM7_IRQHandler [WEAK] EXPORT DMA2_Channel1_IRQHandler [WEAK] EXPORT DMA2_Channel2_IRQHandler [WEAK] EXPORT DMA2_Channel3_IRQHandler [WEAK] EXPORT DMA2_Channel4_5_IRQHandler [WEAK] ; 如下只是定义一个空函数 WWDG_IRQHandler PVD_IRQHandler TAMPER_IRQHandler RTC_IRQHandler FLASH_IRQHandler RCC_IRQHandler EXTI0_IRQHandler EXTI1_IRQHandler EXTI2_IRQHandler EXTI3_IRQHandler EXTI4_IRQHandler DMA1_Channel1_IRQHandler DMA1_Channel2_IRQHandler DMA1_Channel3_IRQHandler DMA1_Channel4_IRQHandler DMA1_Channel5_IRQHandler DMA1_Channel6_IRQHandler DMA1_Channel7_IRQHandler ADC1_2_IRQHandler USB_HP_CAN1_TX_IRQHandler USB_LP_CAN1_RX0_IRQHandler CAN1_RX1_IRQHandler CAN1_SCE_IRQHandler EXTI9_5_IRQHandler TIM1_BRK_IRQHandler TIM1_UP_IRQHandler TIM1_TRG_COM_IRQHandler TIM1_CC_IRQHandler TIM2_IRQHandler TIM3_IRQHandler TIM4_IRQHandler I2C1_EV_IRQHandler I2C1_ER_IRQHandler I2C2_EV_IRQHandler I2C2_ER_IRQHandler SPI1_IRQHandler SPI2_IRQHandler USART1_IRQHandler USART2_IRQHandler USART3_IRQHandler EXTI15_10_IRQHandler RTCAlarm_IRQHandler USBWakeUp_IRQHandler TIM8_BRK_IRQHandler TIM8_UP_IRQHandler TIM8_TRG_COM_IRQHandler TIM8_CC_IRQHandler ADC3_IRQHandler FSMC_IRQHandler SDIO_IRQHandler TIM5_IRQHandler SPI3_IRQHandler UART4_IRQHandler UART5_IRQHandler TIM6_IRQHandler TIM7_IRQHandler DMA2_Channel1_IRQHandler DMA2_Channel2_IRQHandler DMA2_Channel3_IRQHandler DMA2_Channel4_5_IRQHandler B . ENDP ALIGN ; 默认是字对齐方式,也说明了代码是4字节对齐的 ;****************************************************************************** ; User Stack and Heap initialization ;****************************************************************************** IF :DEF:__MICROLIB ;如果勾选了MicroLib就执行下面 EXPORT __initial_sp EXPORT __heap_base EXPORT __heap_limit ELSE ;没勾选就使用下面 IMPORT __use_two_region_memory EXPORT __user_initial_stackheap __user_initial_stackheap ;此处是初始化两区的堆栈空间,堆是从由低到高的增长,栈是由高向低生长的,两个是互相独立的数据段,并不能交叉使用。 LDR R0, = Heap_Mem LDR R1, =(Stack_Mem + Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR ALIGN ENDIF END ;文件末尾处 以上代码注释仅供参考 [tr]符号寄存器名称[/tr]
根据软件仿真的汇编指令与C语言配合,应该可以提升代码执行效率,但是带来的后果是不利于观察他们的逻辑,所以不建议全部都用汇编。一部分代码使用汇编就好。
void add(){ int i, int j int res; return res; } //主函数里面,就不放死循环了 int main(){ //内嵌汇编,使用BL命令然后,填写标签(C语言叫函数名称),多指令写法如下 __ASM{ BL add } //另一种写法 __asm("BL add");//跳转到add函数 } 【2】内联汇编不能对物理寄存器直接操作。。。我试过多次还是不行,会被编译器优化处理成 NOP指令(这个指令什么也不做)。。。也就是说什么也不干。 然后尝试了一下,下面这种方法,据说也能写汇编 #pragma asm //汇编指令写在这里 #pragma endasm 但这种方法只适合用于51单片机的汇编,不适用于ARM。如果在ARM KEIL开发环境会报错说 “ pragma不认识 ”。 【3】另一种汇编,可以在函数里面直接写汇编代码 __asm void add(void){ //此处编写汇编指令 } 3、子程序执行 下面是通过KEIL5软件仿真得到的结果。 ①执行代码 IMPORT SystemInit ;在开头时候已经声明SystemInit,不然编译器懵逼往不知道哪里找这个地址。 LDR R0 , =SystemInit ;加载SystemInit地址到R0寄存器 BLX R0 ;跳转到R0地址 运行上面几行代码会跳转到SystemInit( )函数并且执行,此时寄存器数值如下: [tr]LRPC[/tr]
②进入子程序SystemInit()后,首先执行代码如下 PUSH { R4 , LR } ;R4和LR寄存器压入栈 寄存器数值如下: [tr]LRPC[/tr]
运行子程序SystemInit退出前,会先出行出栈执行指令跳回原来汇编文件,就是下面指令 POP { R4 , PC } ;R4和LR寄存器出栈,执行完之后就会跳到0x08005844地址继续执行 当进入子程序之后,第一条指令是LR寄存器数值先入栈,运行完子程序退出时候这个数值会出栈交给PC寄存器,从而实现退出子程序。 栈特点是先进后出,而且根据程序入栈与出栈是平衡的,当汇编语言进入C语言函数后: 先执行PUSH { R4 , LR } , 再次新的子程序后将寄存器数据压入栈中PUSH { R4 , LR }, 再次有新的子程序进入后,寄存器将数据压入堆栈中PUSH { R2-R3 , LR } 返回原来程序前出栈先POP { R2 - R3 , PC }, 跳出当前子程序后再次出栈POP { R4 , PC }, 再次出栈指令POP { R4 , PC } 总结:
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1192 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1208 浏览 1 评论
613 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
461 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1127 浏览 2 评论
1669浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
332浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
328浏览 3评论
322浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
297浏览 3评论
GMT+8, 2024-8-30 23:27 , Processed in 0.827189 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
