1个回答
#include “adc.h”
#include “common.h” #include “usart.h” #include “L298N.h” #include “senser.h” #include “NVIC.h” #include “ir1838.h” #include “DMA.h” #define kP 11 #define kdI 200 //nI除数 kI=1/kdI #define kD 120 #define kdPID 28//PID除数 #define D_INTERVAL 1200 #define I_INTERVAL 15 #define ONLINE_MINVAL 25 #define POSVAL_MAX SENSER_MAXVAL*2//位置量值域(-POSVAL_MAX,POSVAL_MAX) #define SPEED_MIN 1700 #define SPEED_NORMAL 1950 #define SPEED_MAX 2000 #define CHECK_WAIT_TIMEOUT 100000 extern u16 ADC_DataBuffer[ADC_DMA_BUFFER_LENGTH]; extern u32 senVals[3]; u16 mod=0; int main() { s32 PID; s32 nP=0; s32 nI=0; s32 nD=0; s32 nLastP=0; u32 nDC=D_INTERVAL; u32 nIC=I_INTERVAL; s32 carSpeed=SPEED_NORMAL; u32 checkWait=0; u8 adjustMod=100; common_init(); ADC_init(); #ifdef USART_ON usart_init(); #endif L298N_init(); #ifdef IR_CTRL_ IR1838_init(); #else //mod=1; #endif DMA_init(); NVIC_init(); delayms(120);//等待DMA将 adc_buffer 填满,避免senser校准值出错(如果有0会导致minvs不正确) while (1) { #ifdef IR_CTRL_ Ircordpro(); #endif switch (mod) { case 0: //等待车被放上跑道 senVals[0]=ADC_DMA_getVal(0); senVals[1]=ADC_DMA_getVal(1); senVals[2]=ADC_DMA_getVal(2); #ifdef USART_ON #define LSHIFTBIT 9 #define SENVALGATE 9 //printDebug(“senVals[0]=”,senVals[0]); //printDebug(“senVals[1]=”,senVals[1]); //printDebug(“senVals[2]=”,senVals[2]); //printDebug(“-------------n”,0); if(senVals[2]》SENVALGATE) { senVals[2]-=SENVALGATE; } else { senVals[2]=0; } senVals[2]《《=LSHIFTBIT; L298N_setLS(senVals[2]); L298N_setRS(senVals[2]); //delayms(3000); continue; #endif if (senVals[0]》SENSER_ORIGIN_MIN&&senVals[0]》SENSER_ORIGIN_MIN&&senVals[0]》SENSER_ORIGIN_MIN)//车被提起 { checkWait=CHECK_WAIT_TIMEOUT; adjustMod=100; L298N_setLS(0); L298N_setRS(0); } else { if(adjustMod==100) { adjustMod=0; Senser_reset(); } } switch (adjustMod) { case 0: if (checkWait) { checkWait--; } else { adjustMod=1; beep(900,300); } break; case 1: //将左传感器移动到线上 L298N_setLS(1400); L298N_setRS(0); if(senVals[0]》SENSER_ORIGIN_MIN) { adjustMod=2; } break; case 2: //将左传感器移动到线右边 if(senVals[0] { L298N_setLS(0); L298N_setRS(0); adjustMod=3; beep(900,300); } break; case 3: //左转开始扫描,直到右传感在线上 L298N_setLS(0); L298N_setRS(1400); if(senVals[2]》SENSER_ORIGIN_MIN) { adjustMod=4; } break; case 4: //直到右传感器移动到线左边 if(senVals[2] { adjustMod=5; beep(900,300); } break; case 5: //右转直到中间传感器在线上 L298N_setLS(1400); L298N_setLS(0); if(senVals[1]》SENSER_ORIGIN_MIN) { beep(800,300); delayms(10); beep(600,300); delayms(10); beep(600,300); delayms(10); beep(600,300); mod=1; } } if(adjustMod==3||adjustMod==4) { //校正 Senser_getsv(0); Senser_getsv(1); Senser_getsv(2); } case 1: Senser_getsv(0); Senser_getsv(1); Senser_getsv(2); /* ------------P------------ */ /* 计算位置 */ if (senVals[1]》ONLINE_MINVAL) { //线在中间传感器下 if (carSpeed { //加速 carSpeed++; } if (senVals[0]》ONLINE_MINVAL) { //中间偏左 nP=POSVAL_MAX/2-senVals[1]; } else { //中间偏右 nP=senVals[1]-POSVAL_MAX/2; } } else if (senVals[0]》ONLINE_MINVAL) { //线在左边传感器偏左 nP=POSVAL_MAX-senVals[0]; } else if (senVals[2]》ONLINE_MINVAL) { //线在右边传感器偏右 nP=senVals[2]-POSVAL_MAX; } else { //线离开传感器检测范围 if (carSpeed》SPEED_MIN) { //减速 carSpeed--; } if (nP《0) { nP=-POSVAL_MAX; } else { nP=POSVAL_MAX; } } //nP/=4; /* ------------I------------ */ if(nIC) { nIC--; } else { nIC=I_INTERVAL; if(nP》ONLINE_MINVAL||nP { nI+=nP/20;//nI=9*nI/10; } else { nI=0; } } /* ------------D------------ */ if(nDC) { nDC--; } else { nDC=D_INTERVAL; nD=nP-nLastP; nLastP=nP; } /* PID */ PID=nP*kP + nI/kdI + nD*kD; PID/=kdPID; L298N_setSpeed(carSpeed,PID); /* printDebug(“nP=”,nP*kP); printDebug(“nI=”,nI/kdI); printDebug(“nD=”,nD*kD); printDebug(“PID=”,PID); printChar(‘n’,USART2); printDebug(“LS=”,TIM4-》CCR3); printDebug(“RS=”,TIM4-》CCR4); |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1617 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1543 浏览 1 评论
977 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
683 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1595 浏览 2 评论
1863浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
644浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
515浏览 3评论
531浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
504浏览 3评论
GMT+8, 2024-11-22 08:24 , Processed in 0.777320 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
