电子发烧友论坛|
int main(void) { uint8_t a=0;//LED高低电压控制 /* System Clocks Configuration */ RCC_Configuration(); //系统时钟设置 /*嵌套向量中断控制器 说明了USART1抢占优先级级别0(最多1位) ,和子优先级级别0(最多7位) */ NVIC_Configuration(); //中断源配置 /*对控制LED指示灯的IO口进行了初始化,将端口配置为推挽上拉输出,口线速度为50Mhz。PA9,PA10端口复用为串口1的TX,RX。 在配置某个口线时,首先应对它所在的端口的时钟进行使能。否则无法配置成功,由于用到了端口B, 因此要对这个端口的时钟 进行使能,同时由于用到复用IO口功能用于配置串口。因此还要使能AFIO(复用功能IO)时钟。*/ GPIO_Configuration(); //端口初始化 USART_Config(USART1); //串口1初始化 while (1) { if(rec_f == 1) { //判断是否收到一帧有效数据 rec_f = 0; for(i=0; i 相关变量 uint8_t TxBuffer1[] = "USART Interrupt Example: This is USART1 DEMO";uint8_t RxBuffer1[], rec_f, tx_flag, i;__IO uint8_t TxCounter1 = 0x00;__IO uint8_t RxCounter1 = 0x00;uint32_t Rec_Len;串口中断函数配置如下所示: USART_SendChar(USART_TypeDef*(USART_GetFlagStatus(USARTx,USART_FLAG_TC)== USART_Config(USART_TypeDef*= ; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; &USART_InitStructure); USART_ITConfig(USARTx, USART_IT_TXE, ENABLE); (; nCount!=; nCount-- RCC_Configuration(| RCC_APB2Periph_GPIOD | GPIO_Configuration(= GPIO_Pin_2; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed =&= GPIO_Pin_9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); NVIC_Configuration( = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = ; NVIC_InitStructure.NVIC_IRQChannelSubPriority = ; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&在中断服务函数中编写usart函数。 //串口1 中断服务程序void USART1_IRQHandler(void) { unsigned int i; //判断读寄存器是否非空 if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) { //将读寄存器的数据缓存到接收缓冲区里 RxBuffer1[RxCounter1++] = USART_ReceiveData(USART1); //判断结束标志是否是0x0d 0x0a if(RxBuffer1[RxCounter1-2] == 0x0d && RxBuffer1[RxCounter1-1] == 0x0a) { for(i=0; i< RxCounter1; i++) TxBuffer1 = RxBuffer1; //将接收缓冲器的数据转到发送缓冲区,准备转发 //接收成功标志 rec_f = 1; //发送缓冲区结束符 TxBuffer1[RxCounter1] = 0; TxCounter1 = RxCounter1; RxCounter1 = 0; } } //这段是为了避免STM32 USART 第一个字节发不出去的BUG if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET) { //禁止发缓冲器空中断, USART_ITConfig(USART1, USART_IT_TXE, DISABLE); }} 运行结果如下,在发送去不填写任何字符,直接发送,显示RT Interrupt Example: This is USART1 DEMO,说明前三个字符已经被占用替换了。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4168 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3246 浏览 1 评论
2776 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2206 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
15067 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3135浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1923浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2093浏览 3评论
2003浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2200浏览 3评论
/9
GMT+8, 2025-12-8 11:28 , Processed in 0.591175 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1607
