电子发烧友论坛|
STM32的SPI1、SPI2、SPI3初始化及RF1101的应用(标准库与HAL库)
——基于STM32F103RCT6 ---- 标准库: 说明:相关文件共有两个:bsp_spi_cc1101.h;bsp_spi_cc1101.c;以SPI2为例。 1、“bsp_spi_cc1101.h”中的参数定义: #ifndef _BSP_SPI_1101_H_ #define _BSP_SPI_1101_H_ #include 《stdio.h》 #include “stm32f10x.h” #include “misc.h” #include “os_cfg_app.h” #include “os.h” #include “core_cm3.h” #include “bsp.h” #include “stm32f10x_spi.h” #define CSN_CC1101_GPIO GPIOB #define CSN_CC1101_GPIO_PIN GPIO_Pin_12 #define SPI_CC1101_GPIO GPIOB #define SCK_CC1101_GPIO_PIN GPIO_Pin_13 #define MISO_CC1101_GPIO_PIN GPIO_Pin_14 #define MOSI_CC1101_GPIO_PIN GPIO_Pin_15 #define GDO0_CC1101_GPIO GPIOA #define GDO0_CC1101_GPIO_PIN GPIO_Pin_11 #define SPI_GPIO_RCC_1 RCC_APB2Periph_GPIOB #define SPI_GPIO_RCC_2 RCC_APB2Periph_GPIOA #define CC1101_SPI SPI2 #define CSN_SET GPIO_SetBits(GPIOB,GPIO_Pin_12) #define CSN_RESET GPIO_ResetBits(GPIOB,GPIO_Pin_12) void SPI_CC1101_Init(void); u8 SPI2_ReadWriteByte(u8 TxData); #endif 2、“bsp_spi_cc1101.c”中的引脚及SPI功能初始化: #include “bsp_spi_cc1101.h” void SPI_CC1101_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; SPI_InitTypeDef SPI_InitStructure; RCC_APB2PeriphClockCmd(SPI_GPIO_RCC_1 | SPI_GPIO_RCC_2,ENABLE); //初始化GPIO时钟 /*********SPI1初始化内容**** RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,ENABLE); //初始化SPI1时钟 ******SPI1初始化内容******/ /*********SPI2初始化内容************/ RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE); //初始化SPI2时钟 /********SPI3需要初始化的内容******** RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE); //初始化SPI3时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); //初始化复用IO时钟,重定向IO口 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE); //由于SPI3占用JTAG口,所以需要关闭JTAG ******SPI3需要初始化的内容*******/ //片选设定成通用IO模式 GPIO_InitStructure.GPIO_Pin=CSN_CC1101_GPIO_PIN; GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP; GPIO_Init(CSN_CC1101_GPIO,&GPIO_InitStructure); //SCK时钟IO初始化 GPIO_InitStructure.GPIO_Pin=SCK_CC1101_GPIO_PIN; GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP; GPIO_Init(SPI_CC1101_GPIO,&GPIO_InitStructure); //MISO的IO初始化 GPIO_InitStructure.GPIO_Pin=MISO_CC1101_GPIO_PIN; GPIO_Init(SPI_CC1101_GPIO,&GPIO_InitStructure); //MOSI的IO初始化 GPIO_InitStructure.GPIO_Pin=MOSI_CC1101_GPIO_PIN; GPIO_Init(SPI_CC1101_GPIO,&GPIO_InitStructure); //RF1101中用到的GDO0的IO初始化 GPIO_InitStructure.GPIO_Pin=GDO0_CC1101_GPIO_PIN; GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU; GPIO_Init(GDO0_CC1101_GPIO,&GPIO_InitStructure); //SPI模式设置 SPI_InitStructure.SPI_Direction=SPI_Direction_2Lines_FullDuplex; //全双工模式 SPI_InitStructure.SPI_Mode=SPI_Mode_Master; //主设备模式 SPI_InitStructure.SPI_DataSize=SPI_DataSize_8b; //8字节数据通信 SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; //时钟空闲时为低电平 SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; //时钟奇数边沿采样 SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //软件控制NSS(CSN)位 SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; //通信速率设定,波特率预分频值 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //数据传输从MSB开始 SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC计算多项式 SPI_Init(CC1101_SPI, &SPI2_InitStructure); //初始化 SPI_Cmd(CC1101_SPI, ENABLE); //使能 SPI2_ReadWriteByte(0xFF); //RF1101启动传输 } u8 SPI2_ReadWriteByte(u8 TxData) { u8 Rxdata; uint32_t SPITimeout =0x1000; while (SPI_I2S_GetFlagStatus(CC1101_SPI , SPI_I2S_FLAG_TXE) == RESET) //检测发送缓存区是否为空 { if((SPITimeout--) == 0) return 0; } SPI_I2S_SendData(CC1101_SPI,TxData); //发送一个字节 while (SPI_I2S_GetFlagStatus(CC1101_SPI , SPI_I2S_FLAG_RXNE) == RESET) //检测接收缓存区是否为空 { if((SPITimeout--) == 0) return 0; } Rxdata = SPI_I2S_ReceiveData(CC1101_SPI); //存储一个字节 return Rxdata; } } ---- HAL库: 以SPI1为例: SPI_HandleTypeDef SPI1_Handler; void SPI1_Init(void) { GPIO_InitTypeDef GPIO_Initure; __HAL_RCC_GPIOA_CLK_ENABLE(); //使能GPIOA时钟 __HAL_RCC_SPI1_CLK_ENABLE(); //使能SPI1时钟 //NSS配置成通用IO口 GPIO_Initure.Pin=GPIO_PIN_4; GPIO_Initure.Mode=GPIO_MODE_OUTPUT_PP; GPIO_Initure.Pull=GPIO_PULLUP; GPIO_Initure.Speed=GPIO_SPEED_HIGH; HAL_GPIO_Init(GPIOA,&GPIO_Initure); //SPI引脚初始化 GPIO_Initure.Pin=GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7; GPIO_Initure.Mode=GPIO_MODE_AF_PP; GPIO_Initure.Pull=GPIO_PULLUP; GPIO_Initure.Speed=GPIO_SPEED_HIGH; HAL_GPIO_Init(GPIOA,&GPIO_Initure); //SPI功能配置 SPI1_Handler.Instance=SPI1; //SPI1 SPI1_Handler.Init.Mode=SPI_MODE_MASTER; //主模式 SPI1_Handler.Init.Direction=SPI_DIRECTION_2LINES; //双线模式 SPI1_Handler.Init.DataSize=SPI_DATASIZE_8BIT; //发送接收8位帧结构 SPI1_Handler.Init.CLKPolarity=SPI_POLARITY_LOW; //时钟的空闲状态为高电平 SPI1_Handler.Init.CLKPhase=SPI_PHASE_1EDGE; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样 SPI1_Handler.Init.NSS=SPI_NSS_SOFT; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制 SPI1_Handler.Init.BaudRatePrescaler=SPI_BAUDRATEPRESCALER_256; //定义波特率预分频的值:波特率预分频值为256 SPI1_Handler.Init.FirstBit=SPI_FIRSTBIT_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始 SPI1_Handler.Init.TIMode=SPI_TIMODE_DISABLE; //关闭TI模式 SPI1_Handler.Init.CRCCalculation=SPI_CRCCALCULATION_DISABLE; //关闭硬件CRC校验 SPI1_Handler.Init.CRCPolynomial=7; //CRC值计算的多项式 HAL_SPI_Init(&SPI1_Handler); //初始化 __HAL_SPI_ENABLE(&SPI1_Handler); //使能SPI1 SPI1_ReadWriteByte(0xFF); //RF1101启动传输 } //SPI底层驱动,时钟使能,引脚配置 //此函数会被HAL_SPI_Init()调用 //hspi:SPI句柄 void HAL_SPI_MspInit(SPI_HandleTypeDef *hspi) { GPIO_InitTypeDef GPIO_Initure; __HAL_RCC_GPIOA_CLK_ENABLE(); //使能GPIOA时钟 __HAL_RCC_SPI1_CLK_ENABLE(); //使能SPI1时钟 //PB13,14,15 GPIO_Initure.Pin=GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7; GPIO_Initure.Mode=GPIO_MODE_AF_PP; GPIO_Initure.Pull=GPIO_PULLUP; GPIO_Initure.Speed=GPIO_SPEED_HIGH; HAL_GPIO_Init(GPIOA,&GPIO_Initure); } void SPI1_SetSpeed(u8 SPI_BaudRatePrescaler) { assert_param(IS_SPI_BAUDRATE_PRESCALER(SPI_BaudRatePrescaler)); //判断有效性 __HAL_SPI_DISABLE(&SPI1_Handler); //关闭SPI SPI1_Handler.Instance-》CR1&=0XFFC7; //位3~5清零,用来设置波特率 SPI1_Handler.Instance-》CR1|=SPI_BaudRatePrescaler; //设置SPI速度 __HAL_SPI_ENABLE(&SPI1_Handler); //使能SPI } u8 SPI1_ReadWriteByte(u8 TxData) { u8 Rxdata; HAL_SPI_TransmitReceive(&SPI1_Handler,&TxData,&Rxdata,1, 1000); return Rxdata; } 注:与HAL库有一定的区别;重点注意SPI3与其他两个的区别;务必要检测缓存区是否为空。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4209 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3263 浏览 1 评论
2796 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2228 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
15172 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3169浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1943浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2110浏览 3评论
2020浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2218浏览 3评论
/9
GMT+8, 2025-12-14 22:46 , Processed in 0.753287 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1753
