电子发烧友论坛|
您好,我使用的是DM8168,使用demo板的PCI2插槽,插上我的PCI2板卡,DM8168的demo板启动后运行lspci命令显示如下:
root@seed_dvs8168:~# lspci 00:00.0 Class 0604: 104c:8888 我试过不同类型的PCIE板卡,读出来的Vendorid都是104c:8888,这个是不对的,查看kernel的启动打印如下 谁能帮忙分析一下这是什么原因,应该如何修改。 Starting kernel ... Uncompressing Linux... done, booting the kernel. map_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda registered ti816x_vpss device registered ti816x_gpio_vr device registered TI816x on-chip HDMI device registered ti816x_sr device registered ti81xx_vidout device pm_dbg_init: only OMAP3 supported ti81xx_pcie: Invoking PCI BIOS... ti81xx_pcie: Setting up Host Controller... ti81xx_pcie: Register base mapped @0xd0820000 ti81xx_pcie: Starting PCI scan... PCI: bus0: Fast back to back transfers disabled PCI: bus1: Fast back to back transfers disabled PCI: bus2: Fast back to back transfers disabled PCI: bus3: Fast back to back transfers enabled PCI: bus4: Fast back to back transfers enabled PCI: bus5: Fast back to back transfers enabled PCI: bus6: Fast back to back transfers enabled PCI: bus7: Fast back to back transfers enabled PCI: bus8: Fast back to back transfers enabled pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x206fffff] pci 0000:00:00.0: BAR 9: assigned [mem 0x20700000-0x20cfffff pref] pci 0000:00:00.0: BAR 7: can't assign io (size 0x3000) pci 0000:01:00.0: BAR 8: assigned [mem 0x20000000-0x205fffff] pci 0000:01:00.0: BAR 9: assigned [mem 0x20700000-0x20cfffff 64bit pref] pci 0000:01:00.0: BAR 0: assigned [mem 0x20600000-0x2061ffff] pci 0000:01:00.0: BAR 0: set to [mem 0x20600000-0x2061ffff] (PCI address [0x20600000-0x2061ffff]) pci 0000:01:00.0: BAR 7: can't assign io (size 0x3000) pci 0000:02:01.0: BAR 8: assigned [mem 0x20000000-0x201fffff] pci 0000:02:01.0: BAR 9: assigned [mem 0x20700000-0x208fffff 64bit pref] pci 0000:02:05.0: BAR 8: assigned [mem 0x20200000-0x203fffff] pci 0000:02:05.0: BAR 9: assigned [mem 0x20900000-0x20afffff 64bit pref] pci 0000:02:09.0: BAR 8: assigned [mem 0x20400000-0x205fffff] pci 0000:02:09.0: BAR 9: assigned [mem 0x20b00000-0x20cfffff 64bit pref] pci 0000:02:01.0: BAR 7: can't assign io (size 0x1000) pci 0000:02:05.0: BAR 7: can't assign io (size 0x1000) pci 0000:02:09.0: BAR 7: can't assign io (size 0x1000) pci 0000:02:01.0: PCI bridge to [bus 03-03] pci 0000:02:01.0: bridge window [io disabled] pci 0000:02:01.0: bridge window [mem 0x20000000-0x201fffff] pci 0000:02:01.0: bridge window [mem 0x20700000-0x208fffff 64bit pref] pci 0000:02:04.0: PCI bridge to [bus 04-04] pci 0000:02:04.0: bridge window [io disabled] pci 0000:02:04.0: bridge window [mem disabled] pci 0000:02:04.0: bridge window [mem pref disabled] pci 0000:02:05.0: PCI bridge to [bus 05-05] pci 0000:02:05.0: bridge window [io disabled] pci 0000:02:05.0: bridge window [mem 0x20200000-0x203fffff] pci 0000:02:05.0: bridge window [mem 0x20900000-0x20afffff 64bit pref] pci 0000:02:06.0: PCI bridge to [bus 06-06] pci 0000:02:06.0: bridge window [io disabled] pci 0000:02:06.0: bridge window [mem disabled] pci 0000:02:06.0: bridge window [mem pref disabled] pci 0000:02:08.0: PCI bridge to [bus 07-07] pci 0000:02:08.0: bridge window [io disabled] pci 0000:02:08.0: bridge window [mem disabled] pci 0000:02:08.0: bridge window [mem pref disabled] pci 0000:02:09.0: PCI bridge to [bus 08-08] pci 0000:02:09.0: bridge window [io disabled] pci 0000:02:09.0: bridge window [mem 0x20400000-0x205fffff] pci 0000:02:09.0: bridge window [mem 0x20b00000-0x20cfffff 64bit pref] pci 0000:01:00.0: PCI bridge to [bus 02-08] pci 0000:01:00.0: bridge window [io disabled] pci 0000:01:00.0: bridge window [mem 0x20000000-0x205fffff] pci 0000:01:00.0: bridge window [mem 0x20700000-0x20cfffff 64bit pref] pci 0000:00:00.0: PCI bridge to [bus 01-08] pci 0000:00:00.0: bridge window [io disabled] pci 0000:00:00.0: bridge window [mem 0x20000000-0x206fffff] pci 0000:00:00.0: bridge window [mem 0x20700000-0x20cfffff pref] PCI: enabling device 0000:00:00.0 (0140 -> 0143) PCI: enabling device 0000:01:00.0 (0140 -> 0143) PCI: enabling device 0000:02:01.0 (0140 -> 0143) PCI: enabling device 0000:02:04.0 (0140 -> 0143) PCI: enabling device 0000:02:05.0 (0140 -> 0143) PCI: enabling device 0000:02:06.0 (0140 -> 0143) PCI: enabling device 0000:02:08.0 (0140 -> 0143) PCI: enabling device 0000:02:09.0 (0140 -> 0143) pci 0000:00:00.0: BAR 7: can't assign io (size 0x3000) pci 0000:01:00.0: BAR 7: can't assign io (size 0x3000) pci 0000:02:01.0: BAR 7: can't assign io (size 0x1000) pci 0000:02:05.0: BAR 7: can't assign io (size 0x1000) pci 0000:02:09.0: BAR 7: can't assign io (size 0x1000) bio: create slab regulator: VFB: 800 <--> 1025 mV at 920 mV vgaarb: loaded |
12 个讨论
只有小组成员才能发言,加入小组>>
545 浏览 0 评论
1609 浏览 0 评论
2045 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1507 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1331 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 18:47 , Processed in 1.452724 second(s), Total 78, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1095
