扫一扫,分享给好友
我用的是官方的EVM板,我的SW5的设置是off ,也就是拨码开关都设置为靠近PCIE插座。在这种设置下,当我插了PCIE网卡(x1),上电串口竟然无反应,此PCIE网卡我已经在PC机上测试过了,可以使用。以下是我不插PCIE网卡的时候串口打印信息。
Linux version 2.6.37 (root@ubuntu) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #21 Mon May 6 11:39:25 CST 2013 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: ti8168evm reserved size = 52428800 at 0x0 FB: Reserving 52428800 bytes SDRAM for VRAM Memory policy: ECC disabled, Data cache writeback OMAP chip is TI8168 2.0 On node 0 totalpages: 80384 free_area_init_node: node 0, pgdat c0590158, node_mem_map c05cc000 Normal zone: 728 pages used for memmap Normal zone: 0 pages reserved Normal zone: 79656 pages, LIFO batch:15 pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 pcpu-alloc: [0] 0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 79656 Kernel command line: console=ttyO2,115200n8 rootwait root=/dev/sda1 rw mem=364M@0x80000000 324M@0x9F900000 notifyk.vpssm3_sva=0xBF900000 ip=off noinitrd PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 314MB = 314MB total Memory: 312248k/312248k available, 60488k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0xd7000000 - 0xf8000000 ( 528 MB) lowmem : 0xc0000000 - 0xd6c00000 ( 364 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .init : 0xc0008000 - 0xc003d000 ( 212 kB) .text : 0xc003d000 - 0xc0546000 (5156 kB) .data : 0xc0546000 - 0xc0591b40 ( 303 kB) SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:407 IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts Total of 128 interrupts on 1 active controller GPMC revision 6.0 Trying to install interrupt handler for IRQ400 Trying to install interrupt handler for IRQ401 Trying to install interrupt handler for IRQ402 Trying to install interrupt handler for IRQ403 Trying to install interrupt handler for IRQ404 Trying to install interrupt handler for IRQ405 Trying to install interrupt handler for IRQ406 Trying to install type control for IRQ407 Trying to set irq flags for IRQ407 OMAP clockevent source: GPTIMER1 at 27000000 Hz Console: colour dummy device 80x30 Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584) pid_max: default: 32768 minimum: 301 Security Framework initialized Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok devtmpfs: initialized omap_voltage_early_init: voltage driver support not added regulator: core version 0.5 regulator: dummy: NET: Registered protocol family 16 omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting! omap_voltage_add_dev: VDD specified does not exist! OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 omap_mux_init: Add partition: #1: core, flags: 0 NOR: Can't request GPMC CS registered ti816x_gpio_vr device registered ti816x_sr device clk get on i2c3 fck failed _omap_mux_get_by_name: Could not find signal dcan0_tx.dcan0_tx _omap_mux_get_by_name: Could not find signal dcan0_rx.dcan0_rx pm_dbg_init: only OMAP3 supported registered ti81xx_vpss device registered ti81xx_vidout device registered ti81xx on-chip HDMI device registered ti81xx_fb device registered ti81xx_vin device ti81xx_pcie: Invoking PCI BIOS... ti81xx_pcie: Setting up Host Controller... ti81xx_pcie: Register base mapped @0xd7020000 ti81xx_pcie: Setting outbound translation for 0x20000000-0x2fffffff ti81xx_pcie: Starting PCI scan... pci_bus 0000:00: scanning bus ti81xx_pcie: Reading config[0] for device 0000:00:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:01:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:02:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:03:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:04:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:05:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:06:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:07:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:08:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:09:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:0a:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:0b:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:0c:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:0d:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:0e:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:0f:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:10:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:11:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:12:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:13:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:14:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:15:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:16:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:17:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:18:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:19:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:1a:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:1b:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:1c:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:1d:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:1e:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:1f:00.. failed. No link/device. pci_bus 0000:00: fixups for bus PCI: bus0: Fast back to back transfers enabled pci_bus 0000:00: bus scan returning with max=00 pci_bus 0000:00: resource 0 [mem 0x20000000-0x2fffffff] pci_bus 0000:00: resource 1 [io 0x40000000-0x402fffff] bio: create slab regulator: VFB: 800 <--> 1025 mV at 1010 mV vgaarb: loaded SCSI subsystem initialized libata version 3.00 loaded. u***core: registered new interface driver u***fs u***core: registered new interface driver hub u***core: registered new device driver u*** USBSS revision 4ea20809 registerd cppi-dma Intr @ IRQ 17 Cppi41 Init Done Advanced Linux Sound Architecture Driver Version 1.0.23. Switching to clocksource gp timer mu***-hdrc: version 6.0, host, debug=0 mu***-hdrc mu***-hdrc.0: dma type: dma-cppi41 MUSB controller-0 revision 4ea20800 TxFifo Empty intr disabled mu***-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) mu***-hdrc: MHDRC RTL version 2.0 mu***-hdrc: setup fifo_mode 4 mu***-hdrc: 28/31 max ep, 16384/16384 memory mu***-hdrc mu***-hdrc.0: MUSB HDRC host driver mu***-hdrc mu***-hdrc.0: new USB bus registered, assigned bus number 1 u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002 u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 u*** u***1: Product: MUSB HDRC host driver u*** u***1: Manufacturer: Linux 2.6.37 mu***-hcd u*** u***1: SerialNumber: mu***-hdrc.0 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected mu***-hdrc mu***-hdrc.0: USB Host mode controller at d701e000 using DMA, IRQ 18 Registered /proc/driver/mu***_hdrc.0 mu***-hdrc mu***-hdrc.1: dma type: dma-cppi41 MUSB controller-1 revision 4ea20800 TxFifo Empty intr disabled mu***-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) mu***-hdrc: MHDRC RTL version 2.0 mu***-hdrc: setup fifo_mode 4 mu***-hdrc: 28/31 max ep, 16384/16384 memory mu***-hdrc mu***-hdrc.1: MUSB HDRC host driver mu***-hdrc mu***-hdrc.1: new USB bus registered, assigned bus number 2 u*** u***2: New USB device found, idVendor=1d6b, idProduct=0002 u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 u*** u***2: Product: MUSB HDRC host driver u*** u***2: Manufacturer: Linux 2.6.37 mu***-hcd u*** u***2: SerialNumber: mu***-hdrc.1 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected mu***-hdrc mu***-hdrc.1: USB Host mode controller at d7026800 using DMA, IRQ 19 Registered /proc/driver/mu***_hdrc.1 NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. PCI: CLS 0 bytes, default 64 NetWinder Floating Point Emulator V0.97 (double precision) PMU: registered new PMU device of type 0 omap-iommu omap-iommu.0: ducati registered omap-iommu omap-iommu.1: sys registered JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc. msgmni has been set to 609 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) ti81xx_pcie_ep: No TI81xx PCIe EP [0xb800] found ti81xx_pcie_ep: No TI81xx PCIe EP [0xb801] found ti81xx_pcie_ep: No TI81xx PCIe EP found. Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0 omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 console [ttyO2] enabled brd: module loaded loop: module loaded ahci ahci.0: forcing PORTS_IMPL to 0x3 ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc scsi0 : ahci_platform scsi1 : ahci_platform ata1: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16 ata2: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x180 irq 16 m25p80 spi1.0: found w25q32, expected m25p80 m25p80 spi1.0: w25q32 (4096 Kbytes) Creating 4 MTD partitions on "spi_flash": 0x000000000000-0x000000040000 : "U-Boot" 0x000000040000-0x000000042000 : "U-Boot Env" 0x000000042000-0x0000002c2000 : "Kernel" 0x0000002c2000-0x000000400000 : "File System" omap2-nand driver initializing ONFI flash detected NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron ) Creating 5 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000260000 : "U-Boot" 0x000000260000-0x000000280000 : "U-Boot Env" 0x000000280000-0x0000006c0000 : "Kernel" 0x0000006c0000-0x00000cee0000 : "File System" 0x00000cee0000-0x000010000000 : "Reserved" davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 davinci_mdio davinci_mdio.0: detected phy mask fffffff9 davinci_mdio.0: probed davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown davinci_mdio davinci_mdio.0: phy[2]: device 0:02, driver unknown u***core: registered new interface driver cdc_ether u***core: registered new interface driver smsc95xx ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver uhci_hcd: USB Universal Host Controller Interface driver Initializing USB Mass Storage driver... u***core: registered new interface driver u***-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice u*** 1-1: new full speed USB device using mu***-hdrc and address 2 omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 u***core: registered new interface driver uvcvideo USB Video Class driver (v1.0.0) OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec u***core: registered new interface driver u***hid u***hid: USB HID core driver notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbf900000 u***core: registered new interface driver snd-u***-audio ALSA device list: No soundcards found. TCP cubic registered NET: Registered protocol family 17 VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 omap_voltage_late_init: Voltage driver support not added Power Management for TI81XX. smartreflex smartreflex: Driver initialized omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800) ata2: SATA link down (SStatus 0 SControl 300) mmc0: new high speed SD card at address cffe mmcblk0: mmc0:cffe SD02G 1.83 GiB u*** 1-1: New USB device found, idVendor=05e3, idProduct=0606 u*** 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 u*** 1-1: Product: USB Hub 2.0 u*** 1-1: Manufacturer: ALCOR mmcblk0: p1 p2 p3 hub 1-1:1.0: USB hub found hub 1-1:1.0: 4 ports detected u*** 1-1.2: new low speed USB device using mu***-hdrc and address 3 u*** 1-1.2: New USB device found, idVendor=0425, idProduct=0001 u*** 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0 u*** 1-1.2: Product: USB OPTICAL MOUSE input: USB OPTICAL MOUSE as /devices/platform/omap/ti81xx-u***ss/mu***-hdrc.0/u***1/1-1/1-1.2/1-1.2:1.0/input/input0 generic-u*** 0003:0425:0001.0001: input: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on u***-mu***-hdrc.0-1.2/input0 ata1: link is slow to respond, please be patient (ready=0) ata1: softreset failed (device not ready) ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) ata1.00: ATA-8: Hitachi HTS545032B9A300, PB3OC64G, max UDMA/133 ata1.00: 625142448 sectors, multi 0: LBA48 NCQ (depth 31/32) ata1.00: configured for UDMA/133 scsi 0:0:0:0: Direct-Access ATA Hitachi HTS54503 PB3O PQ: 0 ANSI: 5 sd 0:0:0:0: Attached scsi generic sg0 type 0 sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sda: sda1 sda2 sda3 sd 0:0:0:0: [sda] Attached SCSI disk EXT3-fs: barriers not enabled kjournald starting. Commit interval 5 seconds EXT3-fs (sda1): warning: maximal mount count reached, running e2fsck is recommended EXT3-fs (sda1): using internal journal EXT3-fs (sda1): recovery complete EXT3-fs (sda1): mounted filesystem with writeback data mode VFS: Mounted root (ext3 filesystem) on device 8:1. devtmpfs: mounted Freeing init memory: 212K udevd (90): /proc/90/oom_adj is deprecated, please use /proc/90/oom_score_adj instead. udev: starting version 141 minix: disagrees about version of symbol module_layout minix: disagrees about version of symbol module_layout FAT: bogus number of reserved sectors VFS: Can't find a valid FAT filesystem on dev mmcblk0. EXT3-fs (mmcblk0): error: can't find ext3 filesystem on dev mmcblk0. EXT2-fs (mmcblk0): error: can't find an ext2 filesystem on dev mmcblk0. FAT: bogus number of reserved sectors VFS: Can't find a valid FAT filesystem on dev mmcblk0. NET: Registered protocol family 10 ISOFS: Unable to identify CD-ROM format. EXT3-fs: barriers not enabled kjournald starting. Commit interval 5 seconds EXT3-fs (sda3): warning: maximal mount count reached, running e2fsck is recommended EXT3-fs: barriers not enabled EXT3-fs (sda3): using internal journal EXT3-fs (sda3): recovery complete EXT3-fs (sda3): mounted filesystem with writeback data mode kjournald starting. Commit interval 5 seconds EXT3-fs (sda2): warning: maximal mount count reached, running e2fsck is recommended EXT3-fs (sda2): using internal journal EXT3-fs (sda2): recovery complete EXT3-fs (sda2): mounted filesystem with writeback data mode EXT3-fs: barriers not enabled kjournald starting. Commit interval 5 seconds EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended EXT3-fs (mmcblk0p2): using internal journal EXT3-fs (mmcblk0p2): recovery complete EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode davinci_mdio davinci_mdio.0: resetting idled controller net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=282f014) ADDRCONF(NETDEV_UP): eth0: link is not ready net eth0: DaVinci EMAC: ioctl not supported net eth0: DaVinci EMAC: ioctl not supported net eth1: DaVinci EMAC: ioctl not supported SysLink version : 2.10.03.20 SysLink module created on Date:Apr 29 2012 Time:20:45:11 PHY: 0:01 - Link is Up - 100/Full ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready HDMI W1 rev 2.0 hdmi: Enter HDMI_W1_StopVideoFrame() found best resolution: 1680x1050 (31) Extension block present db 2 23 84 Extension block present db 1 23 84 Extension block present db 3 23 84 Extension block present db 3 23 84 Extension block present db 3 23 84 hdmi: Enter HDMI_W1_GlobalInitVars() hdmi: Enter HDMI_Core_GlobalInitVars() hdmi: Enter HDMI_W1_ConfigVideoResolutionTiming() hdmi: Enter HDMI_W1_ConfigVideoInterface() hdmi: HDMI_WP_AUDIO_CFG = 0x1030006 hdmi: HDMI_WP_AUDIO_CFG2 = 0x20c0 hdmi: HDMI_WP_AUDIO_CTRL = 0x20 hdmi: Enter DSS_HDMI_CORE_SW_RESET_ASSERT () hdmi: Enter DSS_HDMI_CORE_POWER_DOWN_DISABLE() hdmi: Enter DSS_HDMI_CORE_SW_RESET_RELEASE() hdmi: Enter HDMI_W1_StartVideoFrame () hdmi: Irqenable 60000011 hdmi: 40 hpd hdmi: -------------DEBUG------------------- hdmi: 1 hdmi_wp_irqstatus hdmi: 1 hdmi_core_intr_state hdmi: 60 hdmi_core_intr1 hdmi: 3 hdmi_core_intr2 hdmi: f hdmi_core_intr3 hdmi: 87 hdmi_core_sys_sys_stat hdmi: -------------DEBUG------------------- hdmi: first hpd net eth1: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:02, id=282f014) ADDRCONF(NETDEV_UP): eth1: link is not ready PHY: 0:02 - Link is Up - 100/Full ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready eth0: no IPv6 routers present eth1: no IPv6 routers present root@luhao:~# 求助...我的PCIE网卡是RTL8111C的。 |
24个回答
你好,
请参考:http://processors.wiki.ti.com/index.php/DM81xx_AM38xx_PCI_Express_Root_Complex_Driver_User_Guide 中的Taking care of PERSTn部分。 |
cmh8 发表于 2018-6-21 00:30 目前的情况是我的SW5的设置是off ,也就是拨码开关都设置为靠近PCIE插座。在这种设置下,当我插了PCIE网卡(x1),上电串口无反应,我的系统起不来,按照E2E上老外给的说法,当我连接PCIE网卡设备的时候,SW5应该就是这样设置的。 http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/t/106374.aspx OFF is towards the PCIe slot, that is farther to R195. The switch bank has written "ON" (small font) on it on the opposite side. 我的PCIE网卡在PC机上测试过的,可以用。 |
binro 发表于 2018-6-21 00:45 你好, 由于DM8168不支持PCIE设备的热插拔,而设置SW5为OFF的目的在于,保证EP设备优先于RC设备启动,使用EP设备的复位信号通过SLOT的A11来复位RC设备。 当你的网卡插PCIE slot的时候,你看一下,是否是A11脚的电平不正常,这样导致了DM8168一直处于复位状态,无法正常启动。 同时查一下,你的PCIE X1网卡是否用到了B10 3.3VAUX这个pin脚供电,在EVM上,这个脚是悬空的。 |
cmh8 发表于 2018-6-21 01:04 我给B11飞了一个3.3V供电,现在PCIE网卡能识别到了,也驱动起来了,可以给ethX来配置ip,但是ping不通,暂时不清楚原因,驱动我用的是官方下载的驱动。明天打算用官方推荐的BCM5751测试一下。 同时问一个问题,板子上的PCIE2X是不是可以扩两路千兆以太网? |
binro 发表于 2018-6-21 01:10 不行,只能支持一路PCIE2X或者一路PCIE1X。 |
好的,谢谢louis,我买的BCM5751明天会到公司进行测试,到时候通了我会再回复一下的。 |
http://processors.wiki.ti.com/index.php/DM81xx_AM38xx_PCI_Express_Root_Complex_Driver_User_Guide#Taking_care_of_PERSTn 按照官方推荐的,我使用了BCM5751,可是还不能工作。求助。以下是相关log: ti81xx_pcie: Invoking PCI BIOS... ti81xx_pcie: Setting up Host Controller... ti81xx_pcie: Register base mapped @0xd7020000 ti81xx_pcie: Starting PCI scan... PCI: bus0: Fast back to back transfers disabled PCI: bus1: Fast back to back transfers disabled pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x200fffff] pci 0000:00:00.0: BAR 9: assigned [mem 0x20100000-0x201fffff pref] pci 0000:01:00.0: BAR 0: assigned [mem 0x20000000-0x2000ffff 64bit] pci 0000:01:00.0: BAR 0: set to [mem 0x20000000-0x2000ffff 64bit] (PCI address [0x20000000-0x2000ffff]) pci 0000:01:00.0: BAR 6: assigned [mem 0x20100000-0x2010ffff pref] pci 0000:00:00.0: PCI bridge to [bus 01-01] pci 0000:00:00.0: bridge window [io disabled] pci 0000:00:00.0: bridge window [mem 0x20000000-0x200fffff] pci 0000:00:00.0: bridge window [mem 0x20100000-0x201fffff pref] PCI: enabling device 0000:00:00.0 (0140 -> 0143) bio: create slab regulator: VFB: 800 <--> 1025 mV at 1010 mV vgaarb: loaded SCSI subsystem initialized u***core: registered new interface driver u***fs u***core: registered new interface driver hub u***core: registered new device driver u*** USBSS revision 4ea20809 registerd cppi-dma Intr @ IRQ 17 Cppi41 Init Done omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz omap_i2c omap_i2c.2: bus 2 rev4.0 at 100 kHz Advanced Linux Sound Architecture Driver Version 1.0.23. Switching to clocksource gp timer mu***-hdrc: version 6.0, host, debug=0 mu***-hdrc mu***-hdrc.0: dma type: dma-cppi41 MUSB controller-0 revision 4ea20800 mu***-hdrc mu***-hdrc.0: MUSB HDRC host driver mu***-hdrc mu***-hdrc.0: new USB bus registered, assigned bus number 1 u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002 u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 u*** u***1: Product: MUSB HDRC host driver u*** u***1: Manufacturer: Linux 2.6.37 mu***-hcd u*** u***1: SerialNumber: mu***-hdrc.0 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected mu***-hdrc mu***-hdrc.0: USB Host mode controller at d701e000 using DMA, IRQ 18 mu***-hdrc mu***-hdrc.1: dma type: dma-cppi41 MUSB controller-1 revision 4ea20800 mu***-hdrc mu***-hdrc.1: MUSB HDRC host driver mu***-hdrc mu***-hdrc.1: new USB bus registered, assigned bus number 2 u*** u***2: New USB device found, idVendor=1d6b, idProduct=0002 u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 u*** u***2: Product: MUSB HDRC host driver u*** u***2: Manufacturer: Linux 2.6.37 mu***-hcd u*** u***2: SerialNumber: mu***-hdrc.1 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected mu***-hdrc mu***-hdrc.1: USB Host mode controller at d7026800 using DMA, IRQ 19 NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. NetWinder Floating Point Emulator V0.97 (double precision) PMU: registered new PMU device of type 0 omap-iommu omap-iommu.0: ducati registered omap-iommu omap-iommu.1: sys registered JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc. msgmni has been set to 609 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0 omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 console [ttyO2] enabled brd: module loaded loop: module loaded ahci ahci.0: forcing PORTS_IMPL to 0x3 ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc scsi0 : ahci_platform scsi1 : ahci_platform ata1: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16 ata2: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16 m25p80 spi1.0: found w25q32, expected m25p80 m25p80 spi1.0: w25q32 (4096 Kbytes) Creating 4 MTD partitions on "spi_flash": 0x000000000000-0x000000040000 : "U-Boot" 0x000000040000-0x000000042000 : "U-Boot Env" 0x000000042000-0x0000002c2000 : "Kernel" 0x0000002c2000-0x000000400000 : "File System" omap2-nand driver initializing NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron ) Creating 5 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000260000 : "U-Boot" 0x000000260000-0x000000280000 : "U-Boot Env" 0x000000280000-0x0000006c0000 : "Kernel" 0x0000006c0000-0x00000cee0000 : "File System" 0x00000cee0000-0x000010000000 : "Reserved" davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 davinci_mdio davinci_mdio.0: detected phy mask fffffff9 davinci_mdio.0: probed davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown davinci_mdio davinci_mdio.0: phy[2]: device 0:02, driver unknown e1000e: Intel(R) PRO/1000 Network Driver - 1.2.7-k2 e1000e: Copyright (c) 1999 - 2010 Intel Corporation. tg3.c:v3.115 (October 14, 2010) PCI: enabling device 0000:01:00.0 (0140 -> 0142) u*** 1-1: new full speed USB device using mu***-hdrc and address 2 tg3 0000:01:00.0: eth0: Tigon3 [partno(BCM95751A519) rev 4101] (PCI Express) MAC address 00:10:18:24:41:ac tg3 0000:01:00.0: eth0: attached PHY is 5750 (10/100/1000Base-T Ethernet) (WireSpeed[1]) tg3 0000:01:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1] tg3 0000:01:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit] u***core: registered new interface driver cdc_ether u***core: registered new interface driver smsc95xx ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver uhci_hcd: USB Universal Host Controller Interface driver Initializing USB Mass Storage driver... u***core: registered new interface driver u***-storage Configuring network interfaces... ADDRCONF(NETDEV_UP): eth0: link is not ready eth0 no wireless extensions. /bin/sh: udhcpc: not found done. Setting up IP spoofing protection: rp_filter. Thu May 9 15:54:00 CST 2013 INIT: Entering runlevel: 5 Starting system message bus: dbus. Starting Hardware abstraction layer hald Starting Dropbear SSH server: dropbear. Starting telnet daemon. Starting network benchmark server: netserver. Starting syslogd/klogd: done tg3 0000:01:00.0: eth0: Link is up at 100 Mbps, full duplex tg3 0000:01:00.0: eth0: Flow control is on for TX and on for RX ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready 我lspci -v ,如下信息打印: 00:00.0 Class 0604: Device 104c:b800 (rev 01) Flags: bus master, fast devsel, latency 0 Memory at Memory at Bus: primary=00, secondary=01, subordinate=01, sec-latency=0 Memory behind bridge: 20000000-200fffff Prefetchable memory behind bridge: 20100000-201fffff Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+ Capabilities: [70] Express Root Port (Slot-), MSI 00 Capabilities: [100] Advanced Error Reporting 01:00.0 Class 0200: Device 14e4:1677 (rev 11) Subsystem: Device 14e4:1677 Flags: bus master, fast devsel, latency 0, IRQ 48 Memory at 20000000 (64-bit, non-prefetchable) [size=64K] Expansion ROM at 20100000 [disabled] [size=64K] Capabilities: [48] Power Management version 2 Capabilities: [50] Vital Product Data Capabilities: [58] MSI: Enable- Count=1/8 Maskable- 64bit+ Capabilities: [d0] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [13c] Virtual Channel > Kernel driver in use: tg3 配置IP,但是ping不通,已经排除网线的问题。 |
binro 发表于 2018-6-21 01:55 你好, 打印一下:lspci -v 的信息,检查一下是不是有类似下面的打印: Memory at Bus: primary=00, secondary=01, subordinate=01, sec-latency=0 Memory behind bridge: 20000000-200fffff Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+ Capabilities: [70] Express Root Port (Slot-), MSI 00 Capabilities: [100] Advanced Error Reporting 01:00.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5751 Gigabit Ethernet PCI Express Subsystem: Broadcom Corporation NetXtreme BCM5751 Gigabit Ethernet PCI Express Flags: fast devsel, IRQ 48 Memory at 20000000 (64-bit, non-prefetchable) [disabled] [size=64K] Capabilities: [48] Power Management version 2 Capabilities: [50] Vital Product Data Capabilities: [58] MSI: Enable- Count=1/8 Maskable- 64bit+ Capabilities: [d0] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [13c] Virtual Channel |
binro 发表于 2018-6-21 01:55 从log信息来看,PCIe 网卡BCM5751已经找到,并且网络link已经建立。PCIe应该没有什么问题,问题应该在网络驱动和使用方面。 网络连接使用dhcp还是静态IP?从log信息看dhcp应该不能工作。你的网络是怎么配置的? /bin/sh: udhcpc: not found 01:00.0 Class 0200: Device 14e4:1677 (rev 11) …….. tg3 0000:01:00.0: eth0: Link is up at 100 Mbps, full duplex tg3 0000:01:00.0: eth0: Flow control is on for TX and on for RX ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready |
60user112 发表于 2018-6-21 02:21 我工作的时候是设置的静态的IP。 dhcp其实是可以使用的,只是我把udhcpc这个命令去掉了,所以log里面有这么一句/bin/sh: udhcpc: not found。 我也还疑过是驱动的问题,所以我另外尝试了RTL8111C和INTEL82574这两款PCIE 网卡,情况基本是一样的,我觉得不大可能是三家公司的驱动同时有问题。 TI的原理图上,wake脚没有接,我不清楚这个会不会带来大的影响?我看了几个其他平台的PCIE包括笔记本的,都是接了的。 |
60user112 发表于 2018-6-21 02:21 root@luhao:~# ethtool eth0 Settings for eth0: Supported ports: [ TP ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Supports auto-negotiation: Yes Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Advertised pause frame use: No Advertised auto-negotiation: Yes Speed: 100Mb/s Duplex: Full Port: Twisted Pair PHYAD: 1 Transceiver: internal Auto-negotiation: on MDI-X: Unknown Supports Wake-on: g Wake-on: g Current message level: 0x000000ff (255) drv probe link timer ifdown ifup rx_err tx_err Link detected: yes root@luhao:~# 这是ethtools 检测到了的eth0的相关信息,eth0是BCM5751 root@luhao:~# ifconfig -a eth0 Link encap:Ethernet HWaddr 00:10:18:0B:3B:76 inet addr:192.168.1.18 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fe80::210:18ff:fe0b:3b76/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:1307 errors:0 dropped:1759 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:137257 (134.0 KiB) TX bytes:321920 (314.3 KiB) Interrupt:48 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:3 errors:0 dropped:0 overruns:0 frame:0 TX packets:3 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:336 (336.0 B) TX bytes:336 (336.0 B) 谢谢Dong Yang的回复,这是我提供的进一步的信息。 |
60user112 发表于 2018-6-21 02:21 包括SW5的设置,无论是on还是off都尝试过了。 包括这一段 Controlling PERSTn Using I2C Writes Note that this description assumes the above mentioned EVM modification is already done. As mentioned earlier, the PERSTn line on the A11 pin of PCIe slot on the EVM can be toggled by controlling I2C0 writes to IOEXPANDER port 14. This corresponds to performing i2c writes to address 0x20 bit 12. • Setting this bit to 1 makes PERSTn pin high (EP reset de-asserted). • Setting this bit to 0 means PERSTn pin low (reset asserted) and EP will remain in reset. As an example, following commands at U-Boot prompt will toggle reset to EP during boot: TI8168_EVM# i2c mw 0x20 ff ef <--- Set bit 12 to 0 to assert PERSTn (default is 1, de-asserted) TI8168_EVM# i2c mw 0x20 ff ff <--- Set bit 12 to 1 to de-assert PERSTn and get EP out of reset The above sequence can be set as part of U-Boot's bootcmd as shown below to ensure it is executed on every reset and before booting the kernel (assuming kernel is flashed in NAND @0x280000 offset): TI8168_EVM# setenv bootcmd 'i2c mw 0x20 ff ef; i2c mw 0x20 ff ff; nand read.i 81000000 280000 500000; bootm 81000000' TI8168_EVM# saveenv This sequence can also be added to Kernel board file to perform similar i2c writes at boot up. 能尝试的都尝试了。 Dong Yang 谢谢你对这个帖子的关注。 不知道TI能否在DM8168平台上对 TI81XX PCI Express Root Complex Driver User Guide 这篇手册上针对BCM5751的例子再做一次测试,是否能够在寻找网网卡设备的情况下,进一步ping通, |
Louis你好,我有进一步测试,我像eth0发送原始包,发现可以接受到数据,RX bytes:689363584 (657.4 MiB)。 root@luhao:~# ifconfig eth0 Link encap:Ethernet HWaddr 00:10:18:24:40:0C inet addr:193.168.252.10 Bcast:193.168.252.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:538053 errors:0 dropped:538017 overruns:0 frame:1 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:689363584 (657.4 MiB) TX bytes:0 (0.0 B) Interrupt:48 但就是不支持协议栈收发。 |
binro 发表于 2018-6-21 03:22 你好, 请问你使用的NetXtreme BCM5751 Gigabit Ethernet PCI Express 是GEN1 speeds with x1 link,并且版本是(rev 01)么? 下面是TI使用该网卡时候的测试数据。 http://processors.wiki.ti.com/index.php/TI81XX_PSP_04.04.00.02_Feature_Performance_Guide#Performance_and_Benchmarks_6 |
物是人非aaa 发表于 2018-6-21 03:38 这个rev 01 好像片子上看不出来啊,是这样的,我一共买了3款BCM5751的网卡,其中一款是博通原装的,另外两个是国内厂家生产的,目前的一个结果都是一样的,设备可以识别到,就是ping不通,我也好郁闷。 |
物是人非aaa 发表于 2018-6-21 03:38 root@luhao:/luhao/5.05# lspci -v 00:00.0 Class 0604: Device 104c:b800 (rev 01) Flags: bus master, fast devsel, latency 0 Memory at Memory at Bus: primary=00, secondary=01, subordinate=01, sec-latency=0 Memory behind bridge: 20000000-200fffff Prefetchable memory behind bridge: 20100000-201fffff Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+ Capabilities: [70] Express Root Port (Slot-), MSI 00 Capabilities: [100] Advanced Error Reporting 01:00.0 Class 0200: Device 10ec:8168 (rev 02) Subsystem: Device 10ec:8168 Flags: bus master, fast devsel, latency 0, IRQ 368 I/O ports at Memory at 20000000 (64-bit, non-prefetchable) [size=4K] Memory at 20120000 (64-bit, prefetchable) [size=64K] [virtual] Expansion ROM at 20100000 [disabled] [size=128K] Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+ Capabilities: [70] Express Endpoint, MSI 01 Capabilities: [b0] MSI-X: Enable- Count=2 Masked- Capabilities: [d0] Vital Product Data Capabilities: [100] Advanced Error Reporting Capabilities: [140] Virtual Channel > Capabilities: [160] Device Serial Number 00-00-00-00-68-4c-e0-00 Kernel driver in use: r8168 这是我使用rtl8111c PCIE网卡的信息。依然是ping不通。 |
binro 发表于 2018-6-21 04:03 从你的打印信息上看,RTL8111C并没有在PCI Scan中扫描到,你用的是TI的EVM么?请在PCI SCAN的时候把LTSSM寄存器打印一下。 |
Louis 你好, RTL8111C已经初始化并加载成功,你可以看到这句01:00.0 Class 0200: Device 10ec:8168,Kernel driver in use: r8168 .realtek 8111X系列网卡使用的是RTL8168的驱动,所以这里显示是8168,实际上这是我插的RTL8111C。 系统启动的时候,有这些log: ti81xx_pcie: Invoking PCI BIOS... ti81xx_pcie: Setting up Host Controller... ti81xx_pcie: Register base mapped @0xd7020000 ti81xx_pcie: Starting PCI scan... PCI: bus0: Fast back to back transfers disabled PCI: bus1: Fast back to back transfers disabled pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x200fffff] pci 0000:00:00.0: BAR 9: assigned [mem 0x20100000-0x201fffff pref] pci 0000:00:00.0: BAR 7: can't assign io (size 0x1000) pci 0000:01:00.0: BAR 6: assigned [mem 0x20100000-0x2011ffff pref] pci 0000:01:00.0: BAR 4: assigned [mem 0x20120000-0x2012ffff 64bit pref] pci 0000:01:00.0: BAR 4: set to [mem 0x20120000-0x2012ffff 64bit pref] (PCI address [0x20120000-0x2012ffff]) pci 0000:01:00.0: BAR 2: assigned [mem 0x20000000-0x20000fff 64bit] pci 0000:01:00.0: BAR 2: set to [mem 0x20000000-0x20000fff 64bit] (PCI address [0x20000000-0x20000fff]) pci 0000:01:00.0: BAR 0: can't assign io (size 0x100) pci 0000:00:00.0: PCI bridge to [bus 01-01] pci 0000:00:00.0: bridge window [io disabled] pci 0000:00:00.0: bridge window [mem 0x20000000-0x200fffff] pci 0000:00:00.0: bridge window [mem 0x20100000-0x201fffff pref] PCI: enabling device 0000:00:00.0 (0140 -> 0143) r8168 Gigabit Ethernet driver 8.035.00 loaded PCI: enabling device 0000:01:00.0 (0140 -> 0142) eth%d: RTL8168C/8111C at 0xd708a000, 00:e0:4c:a2:06:a1, IRQ 368 r8168: This product is covered by one or more of the following patents: US5,307,459, US5,434,872, US5,732,094, US6,570,884, US6,115,776, and US6,327,625. r8168 Copyright (C) 2012 Realtek NIC software team This program comes with ABSOLUTELY NO WARRANTY; for details, please see This is free software, and you are welcome to redistribute it under certain conditions; see ALSA: Restoring mixer settings... Configuring network interfaces... r8168: eth0: link down eth0 no wireless extensions. udhcpc (v1.13.2) started Sending discover... r8168: eth0: link up r8168: eth0: link up Sending discover... Sending discover... No lease, forking to background done. Setting up IP spoofing protection: rp_filter. 这里的eth0就是我的RTL8111c root@luhao:~# ifconfig eth0 Link encap:Ethernet HWaddr 00:E0:4C:A2:06:A1 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:1 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:234 (234.0 B) TX bytes:0 (0.0 B) Interrupt:112 Base address:0xa000 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) root@luhao:~# 从这两句eth%d: RTL8168C/8111C at 0xd708a000, 00:e0:4c:a2:06:a1, IRQ 368 eth0 Link encap:Ethernet HWaddr 00:E0:4C:A2:06:A1 MAC地址可以看到,我的eth0的确就是RTL8111C。 |
只有小组成员才能发言,加入小组>>
458 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
310 浏览 1 评论
906 浏览 0 评论
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
2081 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3823 浏览 4 评论
CC3100BOOST使用CC3200lunchXL进行烧录
863浏览 2评论
99浏览 2评论
134浏览 2评论
111浏览 2评论
132浏览 2评论
GMT+8, 2024-9-1 10:23 , Processed in 1.357148 second(s), Total 85, Slave 77 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
